PID problems
@stephen6309 How do I know the B value my resister? For some reason when I try the M303 T0 S80 the extruder starts to tune instead of the bed and on the duet panel the extruder is showing T0.
@stephen6309 yes its a 24V bed
@stephen6309 I'm getting 24.2v from the PSU and I'm reading 23.4V on the heat bed side of the mosfet.
@stephen6309 I'm reading 23.66V on the bed connector on the duet wifi 2 board going to the mosfet
@blitzreg said in PID problems:
M303 T0 S80 is to tune the tool heater as a tool including the associated fan.
M303 H0 is correct for tuning heater 0 which you have assigned as the bed heater.
Can you send M122 and M98 P"config.g" in the gcode console and post the results here?
So you are using an external mosfet for the bed heater?
What does the temp graph look like during the tuning process? Can you snap a screen shot?
B4138
If your bed thermistor is bog standard the B value is probably 3950 instead.
@phaedrux Hi, ok I'll try that! This is my 2nd hypercube I have built and both have the same thermistor and bed in them. The first one has firmware 1.21 and M303 H0 S90 works good. Both machines are setup identical except firm ware version difference. Bellow is the working printers config.g
m122
5/5/2022, 2:20:12 PM m122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0 (2022-03-15 18:58:31) running on Duet WiFi 1.02 or later
Board ID: 08DJM-9178L-L2MS8-6J1FL-3S06N-KBHGP
Used output buffers: 3 of 24 (13 max)
Static ram: 23868
Dynamic ram: 74568 of which 40 recycled
Never used RAM 13604, free system stack 184 words
Tasks: NETWORK(ready,13.1%,236) HEAT(notifyWait,0.0%,332) Move(notifyWait,0.0%,364) MAIN(running,86.8%,440) IDLE(ready,0.0%,30), total 100.0%
Owned mutexes: WiFi(NETWORK)
Last reset 01:05:34 ago, cause: software
Last software reset at 2022-05-05 13:14, reason: User, GCodes spinning, available RAM 13604, slot 0
Error status: 0x00
Aux0 errors 0,0,0
Step timer max interval 0
MCU temperature: min 21.9, current 23.6, max 24.0
Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
Events: 0 queued, 0 completed
Driver 0: standstill, SG min n/a
Driver 1: standstill, SG min n/a
Driver 2: standstill, SG min n/a
Driver 3: standstill, SG min n/a
Driver 4: standstill, SG min n/a
Driver 5:
Driver 6:
Driver 7:
Driver 8:
Driver 9:
Driver 10:
Driver 11:
Date/time: 2022-05-05 14:20:10
Slowest loop: 4.93ms; fastest: 0.18ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.6ms, write time 0.0ms, max retries 0
DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
=== AuxDDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty
=== Network ===
Slowest loop: 15.75ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.26
WiFi MAC address 84:0d:8e:b2:1e:40
WiFi Vcc 3.42, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 25976
WiFi IP address 192.168.86.101
WiFi signal strength -47dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
- WiFi -
@phaedrux said in PID problems:
M98 P"config.g"
5/5/2022, 2:21:34 PM M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Error: Heater 7 not found -
@phaedrux yes external mosfet
@phaedrux I'm running pid tune now on the bed. The bed with a IR gun is 10C higher then what the thermistor is showing
Yes, just looked up what I purchased and they are 3950. So , do I put B3950 ?
Yes.
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950
@phaedrux hi so no C0 R4700 behind B3950? I'm running it now
@phaedrux right now the thermistor in phase 3 reads 84 and the IR gun shows 96. Makes me wonder if the thermistor is bad
Where is the thermistor positioned to get the reading?
Are you measuring with the IR temp gun in the same location?
@phaedrux no, I actually testing it all 4 corners and in the middle where the thermistor is located
@phaedrux Almost 1 hour on phase 3. My other hypercube has already tuned using firm ware 1.21. now I'm wondering when I tell the extruder to heat to 220C its actually 220C. My first prints off them looked like they got pretty hot. I am using the e3d hemeria w/volcano direct drive. I also have their REVO
For the hotend you have a known thermistor and the correct values from E3D, so it should be as accurate as you can expect.
As for the bed, at 24v it takes a long time to heat up and it does many cycles, so it can take quite a while. Rather than tuning to 90c, try a more reachable temp like 60.
@phaedrux Hi, the problem was the thermistor in the bed. I swapped it out and now the temps are almost the same between the panel and the IR Gun. Now the gremlin has move to the extruder. I have a REVO Hermera direct drive and it keeps getting heater faults. I have ver 3.4.0 and ran M303 T0 S240 and it tunes fine. But I noticed the the temp rises above the print temperature I set and keeps going until there is a heater fault.
