1HCL 1.0 closed loop controller
If you send M115 on the paneldue does it respond?
You can use this method to flash the desired firmware directly to the 6HC.
https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware
Can you also check what firmware version you have running on the PanelDue in the setup page? You should probably update it as well using USB and similar procedure.
https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDue
@phaedrux
No response, and to boot the status light on the main board is dimly lit, the status on the 1HLC boards are flashing red....so at this point is my best coarse of action to connect my computer directly to the Main Board and use BOSSA to flash the firmware? or am I someplace else?
what is the correct board sequence to flash? What have I done to this thing? so exciting to have messed this thing up and now I get to learn how to fix it -
@phaedrux one last thing, while using BOSSA what is the correct order to install the software?
@supertb1 said in 1HCL 1.0 closed loop controller:
I'm not sure what you mean by correct order. Have you looked at this link yet? https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware
@phaedrux Have you guys made a video someplace demonstrating a BOSSA or other method of erasure through firmware install... this is making me a little nervous never having done this before
It's pretty straightforward.
https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#fallback-procedure-2
Fit the erase jumper, power it up, remove the jumper. The firmware is erased and will show up as a bossa port.
Select the port in Bossa, select the firmware file, select the options to match those shown in the picture and flash and verify.You can't damage the board with a firmware update even if it fails in the middle.
@phaedrux is the diagnostic light rite next to the micro USB port?
@phaedrux
OK I used BOSSA to install Duet3Firmware_MB6HC... not Duet2and3Firmware-3.4.0 and it worked... I have access to DWC... so is it at this point I can install Duet2and3Firmware-3.4.0 or is there something else I should do to make sure I don't have another system lock up.
If you now have access to DWC you can upload the full 3.4 zip file to ensure you have all the right files in place for future updates.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.0/Duet2and3Firmware-3.4.0.zip
Upload that zip file as is to the system tab in DWC. Don't extract it first. Once done, check the firmware version again with M115. It may prompt to update any attached expansion boards as well. You can check those with M115 B# where # is the CAN bus address of the expansion board.
Same errors as before, it is Duet2and3Firmware-3.4.0 causing the system to lock up, I'm going to start over here, this next time I will record and post a youtube video of the update as it happens. Hopefully I can glean some idea as to why or when exactly the fail happens. unless you have a better idea?
@phaedrux do you think it would help to disconnect everything from the board except the panel Due?
@phaedrux I erased the board again and then used BOSSA to re-install Duet3Firmware_MB6HC.bin. At startup the first error I get on my panel due is "ERROR Bad model parameters". Then it posts the IP address and then it posts connected.
That suggests a problem with one of your M307 commands in config.g, or a missing M307 command.
@dc42 ; General preferences
M550 P"Hemera" ; set printer name; Network
M552 P192.168.1.74 S1 ; enable network and acquire dynamic address via DHCP
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
G4 S1 ;wait for expansion boards to start
M569.1 P50.0 T2 C5 E5:10 ; Configure the 1HCL board at CAN address 50 with a quadrature encoder on the motor shaft that has 20 steps per motor full step.
M569.1 P51.0 T2 C5 E5:10 ; Configure the 1HCL board at CAN address 51 with a quadrature encoder on the motor shaft that has 20 steps per motor full step.
M569 P50.0 D4 S1 ; Configure the motor on the 1HCL at can address 50 as being in closed-loop drive mode (D4), Open loop (D2) and not reversed (S1) X axis
M569 P51.0 D4 S1 ; Configure the motor on the 1HCL at can address 51 as being in closed-loop drive mode (D4), Open loop (D2) and not reversed (S1) Y axis
M584 X50.0 Y51.0 Z0.0 E0.1 ; set drive mapping
M92 X106.50 Y106.50 Z400.00 E420.00 ; set steps per mm
M906 X1000 Y1000 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout
M917 X10 Y10 ; Set the closed loop axes to have a holding current of zero; Axis Limits
M208 X235 Y235 Z235 S0 ; set axis maxima; Endstops
M574 X1 S1 P"io1.in" ; configure active-high endstop for low end on X via pin !^io1.in
M574 Y1 S1 P"io2.in" ; configure active-high endstop for low end on Y via pin !^io2.in
M591 D0 P7 C"io5.in" L7 R55:150 E22 S1 ;Bigtree smart filament moniter v2 set to moniter between 55%-150% of 7 counts over a distance of 22mm; Z-Probe
M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
M558 P9 C"io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X60 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:200 Y15:200 S20 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 Bed Heater
M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
M307 H0 B1 S5.00 ; enable bang-bang mode for the bed heater and set PWM limit
M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
M950 H1 C"out2" T1 ; create nozzle heater output on out2 and map it to sensor 1
M950 F0 C"out8" Q500 ; create fan 0 on pin out8 and set its frequency
M106 P0 C"Tool Fan" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
;M950 F1 C"out6" Q500 ; create fan 1 on pin out6 and set its frequency
M950 F1 C"!out6+out6.tach" ; Fan 1 uses out6, but we are using a PWM fan so the output needs to be inverted, and using out6.tach as a tacho input
M950 F2 C"out7" Q500 ; create fan 2 on pin out7 and set its frequency
M106 P1 C"Extruder" S1 H1 T50 ; set fan 1 name and value. Thermostatic control is turned on; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
@supertb1 looks like you haven't run M303 heater tuning on either of your heaters, so you have incomplete M307 commands.
@dc42 OK thanks... I will get that done... any idea why Duet2and3Firmware-3.4.0 is causing the board to lock up? or do you think the heater tune is the answer?
@dc42 This is what I came up with on my heater calibrations:
M307 H0 R0.395 K0.368:0.000 D5.05 E1.35 S1.00 B0
M307 H1 R4.905 K0.241:0.035 D7.64 E1.35 S1.00 B0 V24.0
Do I try and perform Duet2and3Firmware-3.4.0.zip again? or is there something else I need to do? -
Just to verify, you are uploading the whole zip file to the system tab in DWC? Correct?
Can you send M122 and M98 P"config.g" in the gcode console and copy and paste the results here?
Are you using a raspberry pi?
@phaedrux
To answer your question I am using the DWC to upload the Zip file as is with out unziping it in any way and no there is no Raspberry Pi or any other kind of USB handler. It is strictly Duet equipment in a stand alone format in the control box. Incedently I did get a good response back on the Y axis in closed loop so I am excited to get to that part. Let me know your thoughts please.
M122
RepRapFirmware for Duet 3 MB6HC version 3.4.0 (2022-03-15 18:57:24) running on Duet 3 MB6HC v1.01 or later (standalone mode)
Board ID: 08DJM-956BA-NA3TJ-6J9F2-3SD6J-9B9AT
Used output buffers: 1 of 40 (13 max)
Static ram: 151000
Dynamic ram: 96256 of which 0 recycled
Never used RAM 103416, free system stack 200 words
Tasks: NETWORK(ready,25.4%,237) ETHERNET(notifyWait,0.0%,184) HEAT(notifyWait,0.0%,321) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,797) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,8.0%,92) MAIN(running,66.4%,1101) IDLE(ready,0.1%,30), total 100.0%
Owned mutexes:
Last reset 00:01:45 ago, cause: power up
Last software reset at 2022-04-19 16:25, reason: User, GCodes spinning, available RAM 103216, slot 2
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
Error status: 0x00
Aux0 errors 0,0,0
Step timer max interval 127
MCU temperature: min 19.7, current 30.8, max 31.0
Supply voltage: min 24.2, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0
Events: 0 queued, 0 completed
Driver 0: standstill, SG min 0, mspos 8, reads 59917, writes 14 timeouts 0
Driver 1: standstill, SG min 0, mspos 8, reads 59917, writes 14 timeouts 0
Driver 2: standstill, SG min 0, mspos 8, reads 59920, writes 11 timeouts 0
Driver 3: standstill, SG min 0, mspos 8, reads 59920, writes 11 timeouts 0
Driver 4: standstill, SG min 0, mspos 8, reads 59920, writes 11 timeouts 0
Driver 5: standstill, SG min 0, mspos 8, reads 59921, writes 11 timeouts 0
Date/time: 2022-04-19 20:48:29
Slowest loop: 2.39ms; fastest: 0.05ms
=== Storage ===
Free file entries: 10
SD card longest read time 1.5ms, write time 0.0ms, max retries 0
DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
=== AuxDDARing ===
Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty
=== Filament sensors ===
Extruder 0 sensor: no data received
=== CAN ===
Messages queued 957, received 1698, lost 0, boc 0
Longest wait 6ms for reply type 6018, peak Tx sync delay 6, free buffers 50 (min 49), ts 526/525/0
Tx timeouts 0,0,0,0,0,0
=== Network ===
Slowest loop: 4.39ms; fastest: 0.02ms
HTTP sessions: 1 of 8-
Ethernet -
State: active
Error counts: 0 0 1 0 0
Socket states: 5 2 2 2 2 0 0 0M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
M122 B50.0
Diagnostics for board 50:
Duet EXP1HCL firmware version 3.4.0 (2022-03-15 08:58:59)
Bootloader ID: SAME5x bootloader version 2.4 (2021-12-10)
All averaging filters OK
Never used RAM 52288, free system stack 192 words
Tasks: Move(notifyWait,0.0%,152) HEAT(notifyWait,0.0%,88) CanAsync(notifyWait,0.0%,70) CanRecv(notifyWait,0.0%,79) CanClock(notifyWait,0.0%,72) TMC(notifyWait,34.6%,360) CLSend(notifyWait,0.0%,152) MAIN(running,63.7%,407) IDLE(ready,0.0%,30) AIN(notifyWait,1.7%,265), total 100.0%
Last reset 00:04:37 ago, cause: power up
Last software reset data not available
Closed loop enabled: yes, pre-error threshold: 5.00, error threshold: 10.00, encoder type rotaryQuadrature, reverse polarity: no, position 1, raw count = 0, tuning mode: 0, tuning error: 0x1, collecting data: no
Control loop runtime (ms): min=0.003, max=0.012, frequency (Hz): min=11364, max=17045
Driver 0: pos 0, 106.5 steps/mm,not tuned, SG min 0, mspos 8, reads 2343, writes 34 timeouts 0, steps req 0 done 0
Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
Peak sync jitter -7/7, peak Rx sync delay 195, resyncs 0/0, no step interrupt scheduled
VIN voltage: min 24.3, current 24.3, max 24.4
V12 voltage: min 12.1, current 12.1, max 12.1
MCU temperature: min 22.7C, current 25.6C, max 25.8C
Last sensors broadcast 0x00000000 found 0 45 ticks ago, 0 ordering errs, loop time 0
CAN messages queued 2258, send timeouts 0, received 2511, lost 0, free buffers 37, min 37, error reg 0
dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0M122 B51.0
Diagnostics for board 51:
Never used RAM 52288, free system stack 182 words
Tasks: Move(notifyWait,0.0%,152) HEAT(notifyWait,0.0%,88) CanAsync(notifyWait,0.0%,70) CanRecv(notifyWait,0.0%,79) CanClock(notifyWait,0.0%,72) TMC(notifyWait,34.6%,360) CLSend(notifyWait,0.0%,152) MAIN(running,63.7%,417) IDLE(ready,0.0%,30) AIN(notifyWait,1.7%,265), total 100.0%
Last reset 00:05:21 ago, cause: power up
Control loop runtime (ms): min=0.003, max=0.011, frequency (Hz): min=11364, max=17442
Driver 0: pos 0, 106.5 steps/mm,not tuned, SG min 0, mspos 8, reads 655, writes 34 timeouts 0, steps req 0 done 0
Peak sync jitter -4/4, peak Rx sync delay 195, resyncs 0/0, no step interrupt scheduled
V12 voltage: min 12.2, current 12.2, max 12.2
MCU temperature: min 22.1C, current 25.8C, max 25.8C
Last sensors broadcast 0x00000000 found 0 140 ticks ago, 0 ordering errs, loop time 0
CAN messages queued 2610, send timeouts 0, received 2909, lost 0, free buffers 37, min 37, error reg 0
dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0 -
At least it looks like all of the boards are up to date now, so it did apply the firmware.
It may help to see a video of the entire firmware zip file upload process so we can see what it's doing along the way.
