Duet3 Homing failed
@dc42 I measured the 5V to make sure I'm getting a stable 5V. I'm measuring just a few mV. The board is only connected to the PC using a high quality USB cable from ANKER.
@hammad said in Duet3 Homing failed:
The Duet3 can be quite particular about USB cable and port. Please try some different combinations. Also make sure you remove the jumper after the erase.
@phaedrux 3 different laptops and over 15 cables and still nothing. I removed the bridge from erase before resetting the board. I'm not sure what to do now. nothing seems to be working.
@hammad do you have a powered hub you can try with?
@jay_s_uk Do you think this will solve the problem?
@hammad it has for people in the past. i've seen instances where standard USB doesn't provide enough power, especially laptops
@jay_s_uk Thank you for the idea. Ill let you know in few minutes if this actually works.
@jay_s_uk Thank you so much! this actually worked. It is writing the Firmware right now. It's been at 34% for a while now. I'm just glad that it connected!
@hammad one step forwards and all that
@jay_s_uk Do you think it is normal, that it's taking that long?
@hammad no, its not normal for it to take very long. last time I flashed one the increase in % was fairly uniform and only took a minute or so.
maybe try again? -
@jay_s_uk Same thing. it gets stuck at 35%. I've tried it from a different Laptop.
It might be worth trying the modified version of Bossa that I released recently. See the fork of Bossa at https://github.com/Duet3D/BOSSA/releases/tag/1.9.1a-duet3d.
@dc42 It does the same and gets stuck at 34% of the writing process. Any other ideas? I hope this isn't the only way.
Can you confirm that you have the same write options checked?
@phaedrux Yes, I followed the instructions in the documentation. I've tried from many different PCs and cables. The board gets detected but the writing process doesn't finish. I even left it over night and it stayed at 34%. I tried older versions of the Firmware and it doesnt get beyond 34% for some weird reason.
@hammad when and where did you purchase the Duet? Which country are you in?
@dc42 From Dold Mechatronik in Germany.
I received the board like a month ago.
