Poor surface finish
This post is deleted! -
@arnold_r_clark fair enough....
Are you running a print cooling fan? How large is the print? What is the acceleration setting? How big is the nozzle and what is the printing line width?
If you're trying to print a small object super fast you need to have a LOT of cooling capability. Otherwise the extruder keeps dumping hot plastic on top of hot plastic and that can cause all sorts of problems.
If you're trying to print a line width smaller than the nozzle diameter all bets are off. It is going to come out bad at any speed.
Try printing two or three of the prints at the same time to allow some time for the plastic to cool before the extruder comes around again for the next layer.
@mrehorstdmd, no cooling fan, print is roughly 100*150 mm and 130 mm tall, I tried many different acceleration settings with the latest one being 5000 (IIRC), 0.4 mm nozzle, 0.4 line width, 0.2 mm line height, layer time is in the one minute area depending on speed of course. The entire print takes around 9 hrs more or less depending on speed.
I have an excess of printed models now so I have designed something much faster to print. I was also getting extremely frustrated with this issue. There are other issues but this one seemed the easiest to solve (famous last words). First attempt is a round hollow tube, 75 mm diameter, 75 mm tall, 1.2 mm wall thickness printed spiralized for the first attempt, 200 mm/sec with 5000 acceleration, 0.4 nozzle, 0.4 wide line, 0.2 mm line height, cooling at 30%, estimated print time 20 minutes. This is a sort of baseline print for me and I will tweak the speed to begin with - lower if I have the pockmarks, faster if it comes out as a clean print. Next will be to switch to normal, non spiralized mode.
My thought here is that printing a round object avoids sudden acceleration changes in spiralized mode and limited opportunity to screw up in the regular mode with three layer width for the wall. After that I will probably try a square model and various speeds/accel/jerk/etc settings.
I have to get this sorted somehow .... a friend prints with an almost bog straight CR10 and gets a perfect finish while my friggin' expensive Jubilee can't print even basic stuff correctly. Yes the CR10 prints a lot slower and I get a good finish if I print at CR10 speeds but the CR10 is a bed slinger with lots of mass while I am only moving a small light tool. I should in theory be able to print at 300 mm/sec with 600 mm/sec travel moves with a 0.2 mm thickness line, 400 mm/sec print speed if I go down to a 0.15 mm line height. These speeds should max out the capability of the hot end but be doable without weird artifacts in the print. -
So it turns out that I obviously have no clue of what I am doing ..... I printed my spiralized tube with specifying 200 mm/sec for speed in Cura. DWC shows a speed factor of 100% yet the 'requested speed' in DWC is only 81 mm/sec. For the life of me, I can not figure out why when the slicer is set for 200 mm/sec, the printer is only been asked to print at 81 mm/sec. Acceleration is at 5000 so IMHO, the acceleration shouldn't limit the print speed.
So yeah, testing isn't going to show anything until I figure out the very basics of printingBTW, I did increase the speed factor and although print quality went to crap from under extrusion, I was able to run the printhead around at 200 mm/sec .... which seems to suggest that there isn't some hidden limit that I somehow manage to hit.
Somewhat aside, this article is interesting: Investigating the effect of fabrication temperature on mechanical properties of fused deposition modeling parts using X-ray computed tomography. It is about experiments printing with PLA between 180C and 260C, and shows that PLA can benefit from being printed at temperatures as high as 260, leading to higher density, lower internal porosity and improved interlayer adhesion, making for stronger parts.
Of course you need a hotend that can do this and probably appropriate cooling setup (or print parts slow enough that they can cool down by themselves). But it certainly is not only possible but art times a good idea to print PLA at elevated temperatures.
@oliof interesting ......
I am packing it in for now. The more I try to figure out why the speed that is being called for is 81 mm/sec when the slicer is set to 200 mm/sec, the more I am screwing things up.
The first print was perfect (other than slow), now about 3/4 of the tube is perfect and 1/4 has terrible layer alignment. That and some early moves that are not related to the layer issue now make really weird noises. -
Well crap ..... minimum layer time was set at 3 seconds and I guess that the layers tried to print faster than that ..... dropped it down to 1 second and it is running nicely at the set speed of 100 mm/sec.
Odd though that increasing the speed factor allowed the speed to go higher .... I guess because the minium layer time is enforced in the slicer and the speed factor setting is strictly on the printer.
It appeared though that adjusting the speed factor did not seem to change the extruder speed as increasing the speed resulted in under extrusion. Very odd .... -
Apparently as of RRF 31. speed factor does not affect extrusion speed. I am not sure why this was changed from the earlier versions of RRF where speed factor modified all speed settings including extruder speed.
@jens55 a low jerk setting could be limiting speed on a circular print.
@mrehorstdmd, the speed limiting happened because of layer time. Once that was reduced from 3 sec to 1 sec, the speed was back up to what it was set to in Cura.
In the past I had set jerk to 25 but as it turns out, I had turned off jerk control for some reason or another. -
@jens55 said in Poor surface finish:
I'm still at 3.3b4, but up to that version, I can assure that extrusion follows the speed factor precisely. Apparently, with your apparatus, other factors play a role
@infiniteloop, well that is quite possible since making assumptions and jumping to conclusions is one of my fav past-times
It just seemed to fit - proper extrusion at the original speed, increase 'speed factor' and see under extrusion. While it is possible that I was pushing the extruder too much, in this case I was going relatively slow and would not have thought that I was anywhere near the hot end limit. -
@jens55 From the way the defects occur at similar locations in different consecutive layers, I suspect something mechanically sticking - eg a bit of grit in a bearing or a dry bearing.
That could explain the blob or melting effect, if the nozzle momentarily pauses them jumps past that spot once the drive system has wound up enough??
Speed factor is not applied to extruder-only moves, i.e. retraction, reprime, filament loading and unloading.
@dc42, thanks for the clarification !
@rjenkinsgb I had an extruder motor cable failure several years ago when I used a too small bend radius in a drag chain. It would cause the extruder to cut out momentarily at specific XY locations in the prints. It took a while to figure out what was happening. The wires had fractured inside their own insulation, the result of being bent too many times.
