Duet 3. ? faulty Driver0. Post requested by Duet
@davidsimcock I would rename the current homey.g to homey.g.backup then make a new homey.g with the contents above. then yes G28 X, then G28 Y
@t3p3tony said in Duet 3. ? faulty Driver0. Post requested by Duet:
OK...I've done that. The result is that the x axis motor is de-energised at the end of the process.
After homing is complete can you send M906 and M913 by itself and report back what it says?
Another thing to try is to completely backup your current config, remove it all, and start with a fresh basic config from the online tool.
@phaedrux said in Duet 3. ? faulty Driver0. Post requested by Duet:
Thanks. Here are the M906 and M913
@davidsimcock from your config-axes.g file:
; Axes configuration executed by config.g
M584 X0.0 Y0.1:0.3 Z0.2:0.4
M669 K0 X1:0:0:0 Y0:1:0:1 Z0:0:1:0You are defining 3 physical axes but your M669 command assumes 4. Try changing the M669 command to this:
M669 K0 X1:0:0 Y0:1:0 Z0:0:1
@dc42 said in Duet 3. ? faulty Driver0. Post requested by Duet:
Right...I've revised the M669 as suggested. Homing now functions as it should, with the x axis motor holding torque. Thanks for the suggestion!
@davidsimcock The issue does seem to be resolved with changing the kinematics M669 command.
A BIG THANKS to all who have made suggestions to resolve the issue. It is much appreciated. -
@davidsimcock thanks for confirming this. May I ask where the config came from?
@t3p3tony I took it from the Ooznest Workbee configuration that I had on a duet 2 wifi, and adapted it for the parameters of my machine. Why there should have been those kinematis commands I don't know. And I confess to not really understanding why there were 4 entry's...
@davidsimcock thanks, I will follow up with Ooznest. Thanks agin with your patience as we worked through this.
@t3p3tony M669 was also a feature of this workbee config https://forum.duet3d.com/topic/27923/x-axis-stops-working-after-moving-y
@jay_s_uk thank you for linking these two together I did not see that post.
We have captured the issue with M669 to review.
I've added the behaviour when M669 has too many entries per matrix row to the bug list.
