Can a LIS3DH be installed on a duet 3mini 5+ ran from a duetPI?
A small capacitor (100 to 500pF?) connected between the CS and ground pins of the LIS module might work too.
3/31/2022, 10:40:32 AM M997
Error: Operation has been cancelled -
@dc42 the cable run is 75inches long, I’ll take pics tonight and post them as soon as I figure out how to make them URL’s
@ratrig0331 the long cable is probably the problem. I only tested up to 1 metre.
You could try reducing the SPI data rate, for example to 1MHz by including Q1000000 in the M955 command.
@dc42 I’ll give that a shot when I get home to at the “q” value, I can’t go much shorter than 75 inches my set up is a 500x500x500 xy core printer
@ratrig0331 Some folks have reported using up to 3m connections when using a USB3.0 style cable. See: https://forum.duet3d.com/topic/22878/software-package-3-3beta3-released/57?_=1624809172098 This seemed to work well when other cables (like cat5) did not.
@ratrig0331 I run a 2.7m USB3 cable quite happily
@dc42 tryed the m955 p0 c”io3.out+io3.in” q1000000 and same result I ordered a set of “pf” sizes100-10000 off Amazon for $7usd due in this Saturday so I will give that a try
@dc42 my new multimeter can in today, my lines still show good connection from the duet to the chip I’m also getting the following on the chip side
G to vcc 3.296v
G to scl 1.815v
G to sda 3.296v
G to sdo 2.661v
G to cs 3.296v
G to int1 3.283v -
@dc42 looks like I was fighting a bad chip the first one was no good the second one I tryed was no good and than the third one lit it’s little beacon of the success led right off the bat and the duet found it, however is it normal if I send the m955 p0 c”io3.out+io3.in” over and over it will find it than the next it won’t, than once more it will find it than if I send it once mor it won’t
