Smart Effector replacement LEDs
Is there something similar to replacement parts for duet3d but for smart effector?
I'll need to replace LEDs (D1, D9 and D7) as I was switching from 24v to 12v and then back and forgot to remove 12v jumper for LEDs so they were working w/o extra resistor for some time. -
I suggest you check whether it is one of the LEDs that has failed or the series resistor R8. Both will have been overloaded, but especially the resistor.
The LED part number is CLM3C-WKW-CWBYA153. The resistor values are shown on the schematic at https://github.com/T3P3/SmartEffector/blob/master/SmartEffector/SmartEffector_v1.3/SmartEffector_Schematic_v1.3.pdf.
Thank you.
Only got my hands to it now. Sadly 140R resistor burned out so badly that there are no traces left to put replacement component. LEDs are fine though. Has anyone tried using silver tracing pen to re-draw traces? Will it work properly with moving part like effector?
@cdoe You don't by any chance have a link to the resistor that you bought?
