BLTouch issue Duet 3 Mini
@asimitabi Its been along time since ive used a bl touch, but I`m pretty sure you will need the brown wire connected to make it work as its the ground to the servo, have a read through this
https://docs.duet3d.com/en/User_manual/Troubleshooting/BLTouch_troubleshooting
@asimitabi said in BLTouch issue Duet 3 Mini:
3.3RC2
You should also update your firmware to 3.3 final and then 3.4 final.
@jumpedwithbothfeet I already tried to connect it to GND on another Pin of the board but then when I try to home z it says the probe is already triggered at the start even if its not. I will try to find a solution in this but on my Duet 2 Wifi everything is working normal with the BLTouch (another printer). I did everything like it is described here: https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
I will also update the firmware if this will make a difference
Edit: Im on the latest firmware now (3.4) but still the same problem.
Where should I plug in the brown cable? I think GND on one of the io pins in the near of i02 should work? -
@asimitabi This is the current documentation page: https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_connecting#bltouch
Remove the space between the C and pin name on both commands. If I send it with the space, I get an error, without it works fine:
M950 S0 C"io3.out" ; this is accepted M950 S0 C "io3.out" ; this generates following error Error: M950: expected string expression
You can also check your config.g by sending
M98 P"config.g"
. It will probably show the same error.Generally you should not need to send M280 commands to control the BLTouch in homez.g.
Please post your deployprobe.g and retractprobe.g.Ian
@droftarts In the config file I have it without the space sorry I got this wrong here but it is fine in the actual file.
M98 is showing:
M98 P"config.g" Error: Height map file 0:/sys/heightmap.csv not found HTTP is enabled on port 80 FTP is disabled TELNET is disabled Warning: Heater 0 predicted maximum temperature at full power is 346°C Warning: Heater 1 predicted maximum temperature at full power is 527°C Warning: Macro file config-override.g not found
So this should be fine regarding the BLTouch.
My Deployprobe.g:
M280 P0 S10 ; Deploy the BLTouch pin
My Retractprobe.g:
M280 P0 S90 ; Retract the BLTouch pin
Thanks!
@asimitabi In that case, I'd suspect a continuity problem on the white servo control wire. Check it's connected to the right pin on the connector, too.
@droftarts I double checked it now its connected and there is no cable/connection problem.
Here is a photo of the i02 pin:
Also:
The z-Probe status is "1000" all the time -
@asimitabi To me it looks like you have it connected to io4.
Or am I looking at the wrong picture ?
@gixxerfast holy sh*t I am so dumb where can I give back my engineering degree?
Thank you guys and sorry for that...with the two large plugs, I apparently looked a pin row later...
Thanks again and regards!
@asimitabi
Also make sure to have a look in here (or newer docs preferably)// https://duet3d.dozuki.com/Wiki/Duet_3_Mini_5plus_Hardware_overview#Section_IO_port_pin_capabilities
https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Mini_5+_Hardware_Overview
I guess you want the pwm capability.
