duet3 mb6hc accelerometer wiring?
I'm just about ready to wire a LIS3DSH to my MB6HC but I've noticed a discrepancy in the guide;
It calls to connect CS to SPI.CS4 but there doesn't appear to be such pin on the board doc; it goes from CS0 to CS3
How are the pins actually assigned on the MB6HC?
Thanks!
@fractalengineer
This is what works for me, with the same gear:; Accelerometer M955 P0 C"spi.cs3+spi.cs2"
Use the pins with those names on the temperature daughterboard connector.
@fractalengineer the new documentation at https://docs.duet3d.com/en/User_manual/Connecting_hardware/Sensors_Accelerometer is correct.
@rjenkinsgb Yep that worked; should have read further I would have found my answer in the doc hehe
Thank you!
undefined dc42 marked this topic as a question
undefined dc42 has marked this topic as solved
