Duet3D 1HCL - Closed Loop Controller Beta test
@cloudseeds we have dispatched some to Compass-DHM and Dold Mechatronic , I hope both of them will list them soon.
@madmattco the EXP1HCL uses the TMC2160A because it supports the direct coil current control that we need for closed loop node. The TMC2160A does not support an encoder. In any case, reading the encoder using the built-in encoder support in the MCU is faster than reading from the stepper driver over SPI.
I have a question can I use mini with 1HCL board ?
@martin7404 yes you can use it with any of the Duet 3 Mainboards (6HC, 6XD and Mini 5+)
Hi @t3p3tony,
Are there any 1HCL units on the way to UK resellers? I've checked E3D and Oozenest and nothing is showing there at the moment.Many thanks
Barry M -
Any one using EXP1HCL boards with firmware 3.4.0RC1, please upgrade the EXP1HCL firmware to 3.4.0RC1+2 available at https://www.dropbox.com/sh/2dt7sbqpx6l74np/AADn4-lpcil1iqnWKkiVri3Ia?dl=0.
Has there been any progress on simultaneous tuning of two motors driven by individual 1HCL? Iām looking to control a dual motor Y axis gantry with auto squaring.
Thanks -
@tristanryerparke said in Duet3D 1HCL - Closed Loop Controller Beta test:
ThanksSame Here
When is the 1HCL slated for production resale?
@tristanryerparke
Same here! -
@wayneosdias depending on where you are some resellers will already have them or will get them shortly.
@T3P3Tony Im located in Monterey CA USA, Ive been buying Duet stuff from Matterhackers in SoCal and PrintedSolid. Im willing to buy from any auth'd reseller and will by 4 now, preferebly within the USA...
@wayneosdias https://www.filastruder.com/products/duet-3-expansion-1hcl Plenty in stock at Filastruder.
@elmoret Awesome, I just ordered
@dc42 Hello;
I just installed the latest firmware RC1. On my machine it disabled the 1HCL boards and then I installed the v0_3(1) driver and it made my X axis drive into the limit switch and then drive to the end of travel where it stopped. I rolled back to 3+1 and it is working fine with the latest MB6 and web control -
@supertb1 please see my earlier post in this thread and use the updated files at https://www.dropbox.com/sh/2dt7sbqpx6l74np/AADn4-lpcil1iqnWKkiVri3Ia?dl=0.
@dc42 What is the difference between the 1HCL.bin/.map and the v0_3.bin/map?
@supertb1 the v0_3 version is for version 0.3 EXP1HCL boards (it has to be renamed to remove the V0_3 suffix). The other is for the version 1.0 boards.
@dc42 OK so the .3 version was for the original beta boards, and the 1.0 is for the production boards that are being sent out now. I will give these a try and get back to you
@t3p3tony we confirm the first batch of 1HCL has just arrived here at Compass DHM projects!
Shipping all over Europe: https://www.dhm-online.com/schede-di-controllo/7869-duet-3-expansion-1hcl.html
The ones already back-ordered will be ship out today.
