Need help with my delta please.
@phaedrux ; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Feb 14 2022 15:51:11 GMT-0600 (hora estándar central); General preferences
M550 P"My Printer" ; set printer name
M665 R155 L397.19 B155 H520 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them; Network
M551 P"TLM" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S1 ; enable FTP
M586 P2 S1 ; enable Telnet; Drives
M92 X80.00 Y80.00 Z80.00 E400.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1200 Y1200 Z1200 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; set minimum Z; Endstops
M574 X2 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
M574 Z2 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y20 Z5 ; set Z probe trigger value, offset and trigger height
M557 R150 S45 ; define mesh grid; Z-Probe
;M307 H3 A-1 C-1 D-1 ; Disable Heater 3 for use with BLTouch
;M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
;M558 P9 C"^zprobe.in" H5 F120 T12000 ; set Z probe type to bltouch and the dive height +
;G31 P500 X-40 Y2 Z2.5 ; set Z probe trigger value, offset and trigger height
;M557 R150 S45 ; define mesh grid; Heaters
M305 P0 T100000 B4350 R4700
M307 H0 A139.8 C532.3 D4.7 S1.00 V24.1 B0 ; enable bang-bang mode for the bed heater and set PWM limit
M308 S1 P"e0temp" Y"thermistor" T100000 B4138
M305 P1 T100000 B4350 R4700 ; configure sensor 1 as thermistor on pin e0temp
M307 H1 R1.885 C176.8 D11.62 S1.00 V23.8 ; disable bang-bang mode for heater and set PWM limit
M307 H1 B0 S1.00; Heaters
;M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 R4700 ;configure sensor 0 as thermistor on pin bedtemp
;M305 P0 T100000 B4350 R4700
;M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0
;M307 H1 R1.885 C176.8 D11.62 S1.00 V23.8 ; enable bang-bang mode for the bed heater and set PWM limit
;M307 H0 A139.8 C532.3 D4.7 S1.00 V24.1 B0
;M140 H0 ; map heated bed to heater 0
;M143 H0 S100 ; set temperature limit for heater 0 to 100C
;M308 S1 P"e0temp" Y"thermistor" T100000 B4750 R5200 ; configure sensor 1 as thermistor on pin e0temp
;M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to ;sensor 1
;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P0 S0.3 H-1 ; set fan 0 value. Thermostatic control is turned off
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off; Tools
M563 P0 D0 H1 F0:1 ; define tool 0
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Custom settings
M591 D0 C3 P2 E6.0; Miscellaneous
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
@azaelaguirre said in PROBLEM WITH BLTOUCH:
@fcwilt I already did it, when sending m401 it does nothing
Does your deployprobe.g file still have the M280 160 in it?
If so remove that line and remove the I1 from the line above it.
@fcwilt okey thats works !!! thanks a lot, but now i have another problem hahaha when im send auto calibration this happen:
15/2/2022, 19:26:57 Error: Probe was not triggered during probing move
15/2/2022, 19:26:11 Error: Compensation or calibration cancelled due to probing errors
Warning: Skipping grid point X=-45.0, Y=-135.0 because Z probe cannot reach it
Warning: Skipping grid point X=0.0, Y=-135.0 because Z probe cannot reach it
Warning: Skipping grid point X=45.0, Y=-135.0 because Z probe cannot reach it
15/2/2022, 19:25:41 Error: Probe was not triggered during probing move
15/2/2022, 19:25:35 G32
Error: Probe was not triggered during probing move -
Error: Probe was not triggered during probing moveHi,
Please post all of your homing files (4) using the </> tag - one tag per file.
Also post your bed.g file, if you have one and your mesh.g file, if you have one.
G31 P500 X0 Y20 Z5
Is your Bltouch trigger height really 5mm? It must be measured.
I suggest you work your way through this guide for getting your probe working now that the pin is functioning.
https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing
This post is deleted! -
@fcwilt
this is my home files, i dont have mesh.g</> ; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool on Tue Oct 09 2018 13:27:56 GMT+0300
G91 ; relative positioning
G1 Z5 F6000 H2 ; lift Z relative to current position
G1 H1 X-355 Y355 F6000 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X-355 ; home X axis
G1 H1 Y355 ; home Y axis
G1 X5 Y-5 F6000 ; go back a few mm
G1 H1 X-355 F360 ; move slowly to X axis endstop once more (second pass)
G1 H1 Y355 ; then move slowly to Y axis endstop
G90 ; absolute positioning
;G1 X152 Y166.4 F6000 ; go to first bed probe point and home Z
G1 X121.5 Y155 F6000 ; Move Probe to middle of bed
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 S2 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioning
</></>; homedelta.g
; called to home all towers on a delta printer
G1 H1 X705 Y705 Z705 F1800 ; move all towers to the high end stopping at the endstops (first pass)
G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
G1 X0 Y0 F6000 ; move X+Y to the centre
</></>; homex.g
; called to home the X axis
G1 Z5 F1000 H2 ; lift Z relative to current position
G1 H1 X-355 F6000 ; move quickly to X axis endstop and stop there (first pass)
G1 X5 F3000 ; go back a few mm
G1 Z-5 F1000 H2 ; lower Z again
</></>; homey.g
; called to home the Y axis
G1 H1 Y355 F6000 ; move quickly to Y axis endstop and stop there (first pass)
G1 Y-5 F3000 ; go back a few mm
G1 H1 Y355 F360 ; move slowly to Y axis endstop once more (second pass)
G90 ; absolute positioning</>
</>; homez.g
; called to home the Z axis
;G1 X152 Y166.4 F6000 ; go to first probe point
</></>; bed.g
; called to perform automatic delta calibration via G32
G28
M98 Pdeployprobe.g
; Probe the bed at 6 peripheral and 6 halfway points, and perform 6-factor auto compensation
; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
G30 P0 X0 Y132.28 H0 Z-99999
G30 P1 X121 Y69.86 H0 Z-99999
G30 P2 X129.9 Y-75 H0 Z-99999
G30 P3 X0 Y-150 H0 Z-99999
G30 P4 X-125.9 Y-75 H0 Z-99999
G30 P5 X-121 Y69.86 H0 Z-99999
G30 P6 X0 Y59.15 H0 Z-99999
G30 P7 X56.09 Y32.38 H0 Z-99999
G30 P8 X64.95 Y-37.5 H0 Z-99999
G30 P9 X0 Y-75 H0 Z-99999
G30 P10 X-64.95 Y-37.5 H0 Z-99999
G30 P11 X-56.09 Y32.38 H0 Z-99999
G30 P12 X0 Y0 H0 Z-99999 S6
; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
M98 Pretractprobe.g
G29
@phaedrux I already did that I have the trigger in .79mm
Then you need to update your G31 Z value with your trigger height as well as the XY offsets.
@phaedrux how i can send you a vid3o ?
What commands are you running in that video? G32?
@phaedrux I only select the auto calibrate option in the DWB I suppose it is G32
Are you getting any error messages along with whatever is happening at the end of the video?
Have you updated your G31 in config.g to reflect the Z probe trigger height you measured of 0.7? That value also seems very low for a BLTouch. The Bltouch should be mounted with the base of the probe body ~8mm above the nozzle tip which leads to a trigger height of ~2mm.
You should remove these commands from your bed.g
M98 Pretractprobe.g
M98 Pdeployprobe.g -
@phaedrux I already removed the lines from bed.g
In the calibration it performs 5 calibration points and then fails.
I got the height of the probe going down to z5 and then sending G30 S-1 and it gives me that result.I already removed the lines from bed.g
In the self-calibration, it performs 5 calibration points and then fails.
Is there any chance that one of the motors is damaged?
You've used this to get the trigger height?
Do the motors seem to move correctly otherwise?
If you remove the G29 from the end of bed.g does it complete successfully?
@phaedrux
yes I adjust the height of the probe with those instructions.here is the problem that repeats and repeats always.
https://drive.google.com/file/d/1CRUkoarxwDTyzyN0s4D9dpJEInlRXRzh/view?usp=sharing
im delet G29 from bed.g and nothing change
If looks like you're having some mechanical binding issues on that one tower. If you disconnect the belts are you able to move the carriage freely? If you disconnect the rods you can use G1 H2 commands to test individual towers.
A good place to start would be double checking all assembly and wiring.
https://docs.duet3d.com/en/User_manual/Tuning/Delta_calibration
2 weeks ago I had already been able to print, but I had a problem in z that did not go up correctly and the nozzle collided with the print.
From that I started to make modifications, updates and that was when it started to fail like this
