Attempt to move motors when VIN is not in range
@dc42 said in Attempt to move motors when VIN is not in range:
Something odd is happening if connecting the PanelDue causes the VIN reading reported by DWC to drop. My best guess is that in the cable connecting PanelDue to the Duet, the Dout pin is shorted to the +5V pin. Or perhaps you are connecting the PanelDue cable to the wrong connector on the Duet?
Due to the risk of damaging the Duet, I recommend that you do not connect the PanelDue until you have resolved that.
I found the problem. It was the two jumpers which were on the second z step. After I removed them the web shows 24V and the PanelDue is also pluged in. Maybe there is some issue in the circuit. But now everything seems to be fine. fingers crossed
Edit: Not the two jumpers are the issue. It's the 10pin cable from the PanelDue if I connect it to the Duet 2 then the voltage drops. The other 4 pin cable have no effect on the voltage.
Edit 2: Oh man shame on me... I connected the 10pin cable to the conn_lcd because of his labeling but it should connect to the conn_sd. I'm so sorry.
so glad you got it sorted, sounds like your super lucky you didnt take any thing out, sounds like a dead short caused by the wrong connection was your issue
yeah luckily nothing got toasted and everything is fine. Homing, moving and endstops works very well. Now i must figure out to outher issues and if I'm done with everything I'll make a How to wire and configure the Tronxy X5S
I think that will help other people to get it run easier and prevent them to make the same mistake.Thanks everybody and shame myself for misreading the labeling.
Maybe a hint in the wiring diagram would be nice. Something like don't connect PanelDue to conn_lcd and on the conn_sd the hint that you can connect it there. I think that will help a lot of people.
I've added a note to the PanelDue fitting instructions, and we will get the wiring diagram updated too.
I really love the duet. its working more and more. all your hints in this boards helps me to solve issue for issue and now to fix my last issue I need to buy a new 1A fuse because the one that is in is 100% dead. I can see a gap in the wire. If my first print will success (I am very confident) I'll write the how to for the tronxy x5s.
Glad you got this sorted!
@aimrabbit DANG! And I was wondering whats wrong with it! had the same issue for days.
I thought my PanelDue was broken... now we know! -
I'm getting this error message too. My Duet3 6HC shows 3.0V for V12, and 31.5V for Vin. What are the likely causes for this?
Status is "Off" and I can't move steppers.
@jrow ok, so I had 2x24v fans using a voltage step up converter on the 12v rail ... been working fine for a while. But after shutting down, during a travel move, this rail appears to have suffered. I unplugged the fans and V12 is back to 12.2v.
@jrow said in Attempt to move motors when VIN is not in range:
And after successfully moving, I plugged the fans back in, and V12 didn't dip. However, turning the machine off, then on again produces the same problem, and unplugging then plugging the fans in again resolves it.
