firmware 3.3
Hi, after updating my firmware from 2.05 to 3.3 my duet wifi board will not home. I get an error the g28 failed to enable endstops. my printer was working just fine until the update. I did get an error that my G1 S is obsolite and need to use H. But even fixing that I still can't home. When I hit home all the z axis drops a step or 2 every time I hit the home all. Any help would be great! Thanks, Larry
Have you updated your config.g? There are many important changes from RRF2 to RRF3!
Have you gone through the conversion process step-by-step and completed each successfully?
@blitzreg please check your M574 endstop configuration in config.g carefully. In particular, if your endstops are active low (e.g. normally-open switches) then the way you specify inverted endstop operation in the M574 commands has changed between RRF 2.x and 3.x.
