M291 S3 not blocking when called with M98
@educatingsavvas Can you please share the output of M122 when it gets stuck in a loop?
@chrishamm Hiya - I'm not able to send the M122 command as the send button is displaying a spinning wheel of doom.
@educatingsavvas can you try through USB instead?
@jay_s_uk Do you mean using YAT?
@educatingsavvas yep. that should use another stream so won't be blocked in the same way DWC is
@educatingsavvas which Duet are you running on, and are you running it standalone or in SBC mode?
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta7+7 (2022-01-14 08:59:56) running on Duet WiFi 1.02 or later
Board ID: 0JD0M-9P6B2-NJ4S8-6J9D8-3S46P-TV6AM
Used output buffers: 2 of 24 (15 max)
Static ram: 23844
Dynamic ram: 73496 of which 324 recycled
Never used RAM 11488, free system stack 130 words
Tasks: NETWORK(ready,13.2%,258) HEAT(notifyWait,0.0%,353) Move(notifyWait,0.0%,307) MAIN(running,86.8%,362) IDLE(ready,0.0%,30), total 100.0%
Owned mutexes: USB(MAIN)
Last reset 00:06:52 ago, cause: power up
Last software reset at 2022-01-24 13:29, reason: User, GCodes spinning, available RAM 11272, slot 2
Error status: 0x00
Step timer max interval 0
MCU temperature: min 31.9, current 32.8, max 33.3
Supply voltage: min 24.2, current 24.3, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/24/24, gc cycles 0
Events: 0 queued, 0 completed
Driver 0: pos 400, standstill, SG min n/a
Driver 1: pos 400, standstill, SG min n/a
Driver 2: pos -400, standstill, SG min n/a
Driver 3: pos 400, standstill, SG min n/a
Driver 4: pos 0, standstill, SG min n/a
Driver 5: pos 0
Driver 6: pos 0
Driver 7: pos 0
Driver 8: pos 0
Driver 9: pos 0
Driver 10: pos 0
Driver 11: pos 0
Date/time: 2022-01-24 14:02:19
Slowest loop: 3.90ms; fastest: 0.20ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.3ms, write time 0.0ms, max retries 0
DMs created 83, segments created 3, maxWait 0ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
Scheduled moves 11, completed 11, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
=== AuxDDARi
ng ===
Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is ready with "m122" in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty
=== Network ===
Slowest loop: 201.05ms; fastest: 0.10ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(1), 1 sessions
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi module is providing access point
Failed messages: pending 0, notready 0, noresp 2
WiFi firmware version 1.23
WiFi MAC address 26:a1:60:2d:e2:6e
WiFi Vcc 3.45, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 23448
WiFi IP address 10.10.10.10
Connected clients 1
Clock register ffffffff
Socket states: 2 0 0 0 0 0 0 0
ok
- WiFi -
@educatingsavvas you'll need to change a few settings to get the full M122 output (unless @dc42 or @chrishamm say thats enough)
Heres some info https://duet3d.dozuki.com/Wiki/YAT -
@jay_s_uk Just done it
@educatingsavvas you may want to change the line endings to make it a little more readable
@dc42 It's a Duet 2 Wifi in stand alone mode.
@educatingsavvas said in M291 S3 not blocking when called with M98:
Not really related, but your wifi server is a bit out of date. How have you been updating the firmware? Regardless, you should be able to update just the wifi firmware by uploading the latest version.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/DuetWiFiServer.bin
