Solved Unofficial RRF 3.4.0beta7+4 files
@joeko I'm sorry your BLTouch didn't deploy. What type of Duet main board or expansion board is the BLTouch connected to? I am currently investigating an issue with M280 when the port is on an CAN-connected expansion or tool board.
RRF 3.4.0beta7+4 has the following bug: the M280 command does not work properly if the servo or BLTouch device is connected to a Duet 3 expansion or tool board. In particular, this will prevent a BLTouch attached to a tool board or expansion board from deploying.
I expect to have a fix for this later today. [Edit: see next post.]
I have replaced the Duet 3 MB6HC and Duet 3 Mini main board binaries at https://www.dropbox.com/sh/i5vox3xmkd55gaz/AAC19mI0WEC5GmEjLOBRbKs-a?dl=0 with build 3.4.0beta7+5. This corrects the problem with servos and BLTouch connected to expansion and tool boards.
@dc42 said in Unofficial RRF 3.4.0beta7+4 files:
yes this combination i use.
duet3 6hc with toolboard -
@dc42 thankyou
I have updated to b7+5,
i will let you know how I get on later -
@dc42 Curious if anything was done about the chamber heater faults we've reported in 3.3b7+5? I see some changes from around the same time you released it in the repository, but don't know what they targeted. Thanks
@dc42 Looks like there's something wrong with calling filament_error.g. I'm for sure have both files (with _ and with -) but still pause.g is called when fillament error. (6HC + 1LC + SBC) In beta7 work OK. beta7+5 no.
@joeko
It does not help you now but I lower my currents to about 60% during homing or probing moves so the motors never have enough torque to cause damage. -
@oozebot said in Unofficial RRF 3.4.0beta7+4 files:
We've reduced the occurrence of spurious heater files in RRF 3.4b7 and further increased the tolerances allowed before reporting a heater fault on a bed or chamber heater in 3.4beta7+2.
When you turn the chamber heater on, how long does it take before the associated sensor shows a temperature rise; and at what rate does the temperature then rise? You can measure these when you start a heater tuning cycle.
@petrkroupa said in Unofficial RRF 3.4.0beta7+4 files:
Thanks, I've put this on my list to try to reproduce.
@dc42 The fault always seems to occur 15-20 minutes after heating. The temp begins rising almost immediately upon enabling the heater, but does take a long time to reach the target temperature.
Please watch this 25s movie I've linked below where it was ramping to 60c. Note the temp jumps around by .1-.2c. That's pretty typical while heating and what I feel is the cause of the fault.
What I can't wrap my head around is the error states Heater 0 faults, but Heater 2 is the chamber and is what really faults. Maybe that is an unrelated issue..
Have installed the firmware due to file upload issues. Now I get the following errors on every move which make it impossible to work:
Error: Driver 0.2 error: ok
Error: Driver 0.3 error: ok
Error: Driver 0.0 error: ok
Error: Driver 0.1 error: ok
Error: Driver 0.5 error: okFurthermore an event notification window appears.
FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.4.0beta7+6 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2022-01-13 18:24:07
@romeofox this is now fixed in the 3.4.0beta7+7files at https://www.dropbox.com/sh/i5vox3xmkd55gaz/AAC19mI0WEC5GmEjLOBRbKs-a?dl=0.
In 3.4.0b7+7, filament_error.g is not being called.
pause.g is run immediately.
It was working correctly in earlier 3.4b versions -
@owend I think the file has gone back to filament-error.g with a "-" rather than "_" do you have one of those?
@gloomyandy
You nailed it, but it's the other way around in the release notes.
I renamed to filament-error.g and it ran the macro when the sensor tripped.RepRapFirmware 3.4.0beta7
Upgrade notes:
The handling of filament errors have changed. When a filament error occurs, an event is created. To handle the event, RRF runs macro file filament_error.g without appending the extruder number to the file name and without pausing the print first. The extruder number is passed as param.D along with some other parameters. If filament_error.g is not found then the print is paused (running pause.g) and the error is reported.
@owend It used "_" in the original beta7 but has changed back to "-" in the most recent builds (and will be this way in RC1)....
https://github.com/Duet3D/RepRapFirmware/commit/3ac3345333659785dcd21088ae0b9b93ec914a4dRepRapFirmware 3.4.0RC1 This release is still in preparation. Further items may be added before the release. The macro files run after events are now heater-fault.g, filament-error.g (as in RRF 3.3), driver-error.g, driver-warning.g and driver-stall.g instead of these names with the '-' character replaced by '_'
a little confusing!
@gloomyandy
Thanks for that.
I had both files until yesterday.
I couldn't remember which to use, so I looked at the release notes, but in honesty I do now recall reading the snippet you posted, so my fault. -
@dc42 - UPDATE: in BETA7+7 is called filament-error.g . Not filament_error.g.
(6HC + 1LC + SBC + MFM) -
