Ender 3 RRF v1.1 setting up BLtouch
@gixxerfast Oh alright, so its gonna be this in the config.g:
G31 P500 X-44 Y-18 Z3.55
this in the mesh.g:
var xoffset = -44 var yoffset = -18 var xpos = {117.5 - var.xoffset} var ypos = {117.5 - var.yoffset}
But for some strange reason my nozzle homes to X130 Y160
@re_tour That looks better.
Well, that's where you go in your homez.g
G1 X130 Y160 F6000
You can change it to the same as in the mesh.g
@gixxerfast Oh my god I'm starting to get really exhausted
@re_tour Yeah, take a break. Start again tomorrow
It will work now as it is. Maybe not perfectly but good enough to print PLA and stuff.
With PC, ABS and ASA it need to be pretty spot on but with PLA it should work fine.
You should not print those others anyway with your PTFE lined hotend.
@gixxerfast You're right, I'll leave it be for today. I can't thank you enough for all the help, I would be nowhere without your assistance.
@re_tour No problems, happy to help out when I can
@gixxerfast I'm bosting everythin here so that it won't get lost somehow and I can better check it tomorrow Maybe someone can find it helpful as well
homez.g:; homez.g ; called to home the Z axis ; do nothing if XY is not homed yet if !move.axes[0].homed || !move.axes[1].homed echo "XY are not homed yet. Aborting" abort ;end if G91 G1 H2 Z5 F6000 G90 G1 X117.5 Y117.5 F6000 G30 K0 Z-99999 ; Probe the Z pin at the back G1 Z10 F9000
homex.g:
; homex.g ; called to home the X axis ; G91 if !move.axes[1].homed ; raise Z a bit G1 H2 Z5 G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-240 F3000 ; move quickly to X axis endstop and stop there (first pass) G1 H2 X5 F6000 ; go back a few mm G1 H1 X-240 F240 ; move slowly to X axis endstop once more (second pass) G90 ; absolute positioning
homey.g:
; homey.g ; called to home the Y axis ; G91 if !move.axes[0].homed ; raise Z a bit G1 H2 Z5 G1 H1 Y-240 F3000 ; move quickly to Y axis endstop and stop there (first pass) G1 H2 Y5 F6000 ; go back a few mm G1 H1 Y-240 F240 ; move slowly to Y axis endstop once more (second pass) G90 ; absolute positioning
homeall.g:
; homeall.g ; called to home all axes ; M98 P"/sys/homex.g" M98 P"/sys/homey.g" M98 P"/sys/homez.g"
config.g:
; Configuration file for SKR-RFF-E3-v1.1 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.1-LPC-STM32+2 on Tue Dec 28 2021 01:07:55 GMT+0100 (közép-európai téli idő) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Ender3" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S0 ; physical drive 0 goes backwards using TMC2209 driver timings M569 P1 S0 ; physical drive 1 goes backwards using TMC2209 driver timings M569 P2 S1 ; physical drive 2 goes forwards using TMC2209 driver timings M569 P3 S1 ; physical drive 3 goes forwards using TMC2209 driver timings M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm M566 X1200.00 Y1200.00 Z60.00 E360.00 ; set maximum instantaneous speed changes (mm/min) M203 X9000.00 Y9000.00 Z1800.00 E6000.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2) M906 X1000 Y1000 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X235 Y235 Z260 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop ; Z-Probe M950 S0 C"servo0" ; create servo pin 0 for BLTouch M558 P9 C"^probe" H5 F300:120 A3 T6000 ; set Z probe type to bltouch and the dive height + speeds,the F300:120 first speed 300 second 120 G31 P500 X-45 Y-7 Z3.55 ; set Z probe trigger value, offset and trigger height M557 X30:190 Y30:190 P5 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bed" T0 ; create bed heater output on bed and map it to sensor 0 M307 H0 B0 R0.365 C296.6 D3.97 S1.00 V24.0 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 R2.845 C121.4:119.4 D5.71 S1.00 V24.0 ; disable bang-bang mode for heater and set PWM limit M143 H1 S245 ; set temperature limit for heater 1 to 245C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 C"Part Cooling Fan" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 C"Hotend Fan" S0.01 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined M918 P1 E4 E1000000
bed.g:
; bed.g ; called to perform automatic bed compensation via G32 ; ; generated by RepRapFirmware Configuration Tool v3.3.1-LPC-STM32+2 on Tue Dec 28 2021 01:07:55 GMT+0100 (közép-európai téli idő) M561 ; clear any bed transform G29 ; probe the bed and enable compensation
mesh.g:
if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed G28 M290 R0 S0 ; clear baby stepping G29 S2 ; move to the center of the mesh with the PROBE (mind affset in Y is 25 above noozle) G90 var xoffset = -45 var yoffset = -7 var xpos = {117.5 - var.xoffset} var ypos = {117.5 - var.yoffset} G1 X{var.xpos} Y{var.ypos} Z15 F6000 echo "Setting Probe Offset now" G30 K0 G1 Z15 F3000 G29 S0
@gixxerfast Hey there! So today I've tried the mesh and it works! This is what I see after running it:
So now all is left is to slice the things I want in Cura and upload the gcode which I get? -
So I started the print, and the filament started to go in the opposite direction. I haven't the slightest clue why.
@re_tour Hi there, reverse the extruder motor
M569 P3 S0
@gixxerfast said in Ender 3 RRF v1.1 setting up BLtouch:
M569 P3 S0
Thank you so much. Do I have to reverse it every time I turn the printer on or was it just an initial setting mistake I didn't pay attention to?
@re_tour No, just change it once in config.g and it wasn't a mistake. Really hard to know how the wires are supposed to be, just as long as the pairs are correct it's good. Many has to adjust that AFAIK.
@gixxerfast Thank you very much!
@gixxerfast So I didn't input that change into the config.g yet, but wrote it into the console. Printed 2 things, the strange thing is that at the end of each print the mechanism pulls the filament all the way out. Why could that be?
@re_tour You must have something wonky in your slicer. Check if there some custom end print gcode in Cura (it was Cura you were using, right?)
@gixxerfast Yes sir, let me check.
@gixxerfast This is the last few lines of the first gcode:
;TIME_ELAPSED:2311.874865 G1 F2700 E788.98313 M140 S0 M107 G91 ;Relative positioning G1 E-2 F2700 ;Retract a bit G1 E-2 Z0.2 F2400 ;Retract and raise Z G1 X5 Y5 F3000 ;Wipe out G1 Z10 ;Raise Z more G90 ;Absolute positioning G1 X0 Y235 ;Present print M106 S0 ;Turn-off fan M104 S0 ;Turn-off hotend M140 S0 ;Turn-off bed M84 X Y E ;Disable all steppers but Z M82 ;absolute extrusion mode M104 S0 ;End of Gcode
and the end of the second gcode:
;TIME_ELAPSED:10192.122505 G1 F2700 E523.83295 M140 S0 M107 G91 ;Relative positioning G1 E-2 F2700 ;Retract a bit G1 E-2 Z0.2 F2400 ;Retract and raise Z G1 X5 Y5 F3000 ;Wipe out G1 Z10 ;Raise Z more G90 ;Absolute positioning G1 X0 Y235 ;Present print M106 S0 ;Turn-off fan M104 S0 ;Turn-off hotend M140 S0 ;Turn-off bed M84 X Y E ;Disable all steppers but Z M82 ;absolute extrusion mode M104 S0 ;End of Gcode
@re_tour said in Ender 3 RRF v1.1 setting up BLtouch:
I really don't have a clue. I'm just guessing but...
Try to find where these are inserted
And comment them out /remove them.
See if it makes any difference.
@gixxerfast You were right, G1 E-2 F2700 pulls the filament nearly all the way out. Thank you (once again)
@re_tour That's great!
Happy printing!I think you might have to revisit the offset configuration. The mesh looked a bit shifted. But that's for another day
and as long as it prints and you get the first layer right, it works
