Unsolved [3.4.0b7] Firmware update changes 1LC temp
I’m running one V1.0 toolboard and one V1.1, both with thermistors
M308 S2 P"020.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin 121.temp0
M308 S3 P"021.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 3 as thermistor on pin 121.temp0On the upgrade to b7 from b6 the first toolboard immediately threw a fault saying the circuit was open circuit showing the temp as -273.1
M122 also claimed the board didn’t have an accelerometer
Reflashing that board to b6 it shows within a degree of the other board at room temp.
But still no accelerometer
@fumble Just to clarify. When downgrading the toolboard to b6 you do so with the main board as well and vice versa?
@Alex-cr @Fumble @Gixxerfast @jay_s_uk please can you try connecting the thermistor or PT1000 to temp1 on the tool board, change config.g appropriately, and see whether the problem persists. This will help me identify the cause.
@dc42 Yes same using temp1 reports 18.5 with b6 and open circuit with b7
@gixxerfast Downgrading I only updated the one toolboard. While I realise it might not be able to collect data using different firmware versions, I would have expected M122 to detect it ok
@dc42 Oh, mine is working fine with the v1.1 toolboard with a generic pt1000 and b7. I'm just butting in because it's interesting as I have the same setup and it's working fine ...
@dc42 I notice Alex-cr is running SBC+6HC+1LC as am I while Gixxerfast is Mini5
@dc42 said in [3.4.0b7] Firmware update changes 1LC temp:
@dc42 I have confirmed that moving the PT1000 to temp1 did not resolve the issue. The problem persists.
Additional issues are occurring now. Once I performed a new heater tuning on this extruder to test the new algorithm I cannot get the heater to turn on.The M303 completed correctly and I updated my M307 command in my config. Now when I use DWC, G10,M568, or M109/M104 commands the heater will just sit there and not heat.
Sending an M105 command confirms that the temps were requested.
If I send the appropriate M303 command the system will heat/tune and act correctly. Reuploading B6 to the 1LC restores the ability to use the heater. -
I can confirm the erratic temperature reading after upgrading to B7 with 1LC v1.1. SBC + 6HC + 1LC. Flashing back to B6 returns thermistor readings to normal. Slice Engineering Hight Temp thermistor (450C).
@dc42 same here. Dyze 450€ thermistor temp0 on toolboard. Reports open circuit after upgrade
Thanks. Please can those of you with the problem try the following:
Install the modified beta7 tool board firmware from https://www.dropbox.com/sh/5ubjszy9fmlvzwu/AAAeOMGP-Yi-Gn9LZwQoPfita?dl=0.
Check that the temperature reading is still incorrect.
Send M122 B# where # is the CAN address of the tool board.
Send M308 S# where # is the sensor number of the thermistor or PT1000 on the tool board.
Post the M122 and M308 responses here.
@dc42 Hi,
for me beta7+1 fixed the issue.
(theres a small typo in your post - 3. Send M121 B#)config.g - not changed
M308 S1 P"20.temp0" Y"thermistor" T100000 B4725 C7.06e-8
[3.4.0b7]:
M122 B20 Diagnostics for board 20: Duet TOOL1LC rev 1.0 or earlier firmware version 3.4.0beta7 (2021-12-16 12:25:01) Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1) Never used RAM 3648, free system stack 2788 words Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.2%,115) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) TMC(delaying,3.0%,57) MAIN(running,91.8%,351) IDLE(ready,0.0%,40) AIN(delaying,4.9%,142), total 100.0% Last reset 00:02:33 ago, cause: software Last software reset time unknown, reason: AssertionFailed, available RAM 4592, slot 1 Software reset code 0x0120 ICSR 0x00000000 SP 0x20003cac Task Freestk 130 bad marker Stack: 00000544 00023174 00019cb5 20003044 00016e33 20003044 00016505 20000ed0 00000000 00000001 0000828d 200071c8 200071c8 200071e0 00000000 20000f50 000116b3 00022530 000225e8 00021c40 00019c55 200071c8 200071c8 20000f50 00008405 200071d8 000009c6 Driver 0: pos 0, 419.2 steps/mm,standstill, SG min 0, read errors 0, write errors 1, ifcnt 24, reads 10980, writes 12, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0 Peak sync jitter 5/8, peak Rx sync delay 213, resyncs 0/0, no step interrupt scheduled VIN voltage: min 24.2, current 24.2, max 24.3 MCU temperature: min 33.2C, current 35.9C, max 35.9C Last sensors broadcast 0x00000002 found 1 97 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 3054, send timeouts 0, received 1386, lost 0, free buffers 37, min 37, error reg 0 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0 Accelerometer: none I2C bus errors 4509, naks 4509, other errors 4509
M308 S1 Sensor 1 type Thermistor using pin 20.temp0, reading 13.5, last error: success, T:100000.0 B:4725.0 C:7.06e-8 R:2200.0 L:0 H:0
Readings:
[3.4.0b7+1]:
M122 B20 Diagnostics for board 20: Duet TOOL1LC rev 1.0 or earlier firmware version 3.4.0beta7+1 (2021-12-18 13:47:42) Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1) All averaging filters OK Never used RAM 3648, free system stack 2788 words Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.2%,115) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) TMC(notifyWait,3.0%,57) MAIN(running,91.8%,341) IDLE(ready,0.0%,40) AIN(delaying,4.9%,142), total 100.0% Last reset 00:04:12 ago, cause: software Last software reset time unknown, reason: AssertionFailed, available RAM 4592, slot 1 Software reset code 0x0120 ICSR 0x00000000 SP 0x20003cac Task Freestk 130 bad marker Stack: 00000544 00023174 00019cb5 20003044 00016e33 20003044 00016505 20000ed0 00000000 00000001 0000828d 200071c8 200071c8 200071e0 00000000 20000f50 000116b3 00022530 000225e8 00021c40 00019c55 200071c8 200071c8 20000f50 00008405 200071d8 000009c6 Driver 0: pos 0, 419.2 steps/mm,standstill, SG min 0, read errors 0, write errors 1, ifcnt 51, reads 60503, writes 11, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0 Peak sync jitter 4/9, peak Rx sync delay 214, resyncs 0/1, no step interrupt scheduled VIN voltage: min 24.2, current 24.2, max 24.3 MCU temperature: min 37.2C, current 37.6C, max 37.6C Last sensors broadcast 0x00000002 found 1 137 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 4866, send timeouts 0, received 2276, lost 0, free buffers 37, min 37, error reg 50000 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0 Accelerometer: none I2C bus errors 4509, naks 4509, other errors 4509
M308 S1 Sensor 1 type Thermistor using pin 20.temp0, reading 25.5, last error: success, T:100000.0 B:4725.0 C:7.06e-8 R:2200.0 L:0 H:0
Readings:
After installing that firmware and rebooting everything it gave the correct temperatureChecked I loaded the firmware ok as I'm not the best on linux
@dc42 I can confirm that the modified firmware also works for me
M308 S1 Sensor 1 type Thermistor using pin 20.temp0, reading 20.6, last error: sensor not ready, T:100000.0 B:4725.0 C:7.06e-8 R:2200.0 L:0 H:0
m122 b20 Diagnostics for board 20: Duet TOOL1LC rev 1.0 or earlier firmware version 3.4.0beta7+1 (2021-12-18 13:47:42) Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1) All averaging filters OK Never used RAM 3624, free system stack 2788 words Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.2%,115) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) TMC(delaying,3.0%,57) MAIN(running,91.9%,293) IDLE(ready,0.0%,40) AIN(delaying,4.9%,142), total 100.0% Last reset 00:01:28 ago, cause: software Last software reset data not available Driver 0: pos 0, 397.5 steps/mm,standstill, SG min 0, read errors 0, write errors 1, ifcnt 37, reads 44066, writes 13, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0 Peak sync jitter 11/15, peak Rx sync delay 196, resyncs 0/0, no step interrupt scheduled VIN voltage: min 27.0, current 27.0, max 27.0 MCU temperature: min 34.2C, current 35.0C, max 35.0C Last sensors broadcast 0x00000002 found 1 198 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 1743, send timeouts 0, received 1132, lost 0, free buffers 37, min 37, error reg 0 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0 Accelerometer: none I2C bus errors 4509, naks 4509, other errors 4509
All, thanks for trying the new version. It's somewhat annoying to me that it works, because all I did was to add some extra M122 debug! So I'm no nearer finding the cause.
Not sure if it's related but for some reason last night I started having an issue where my Duet 2 wiFi would reboot after trying to use the input shaping plugin.
M122 showed last restart reason was something like HeatStuck (don't remember exact words)
I saw no stack errors or other obvious issues.
After several attempts reinstalling the plugin and restarting the duet2 from DWC, I did a cold restart (turned off power) and the problem disappeared. -
@dc42 I know that feeling
i case you are wondering.
going back to 3.4.0b7 will come up with low temperature again.m122 b20 Diagnostics for board 20: Duet TOOL1LC rev 1.0 or earlier firmware version 3.4.0beta7 (2021-12-16 12:25:01) Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1) Never used RAM 3648, free system stack 2788 words Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.2%,115) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) TMC(delaying,3.0%,57) MAIN(running,91.8%,351) IDLE(ready,0.0%,40) AIN(delaying,4.9%,142), total 100.0% Last reset 00:00:47 ago, cause: software Last software reset time unknown, reason: AssertionFailed, available RAM 4592, slot 1 Software reset code 0x0120 ICSR 0x00000000 SP 0x20003cac Task Freestk 130 bad marker Stack: 00000544 00023174 00019cb5 20003044 00016e33 20003044 00016505 20000ed0 00000000 00000001 0000828d 200071c8 200071c8 200071e0 00000000 20000f50 000116b3 00022530 000225e8 00021c40 00019c55 200071c8 200071c8 20000f50 00008405 200071d8 000009c6 Driver 0: pos 0, 419.2 steps/mm,standstill, SG min 0, read errors 0, write errors 1, ifcnt 24, reads 23875, writes 12, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0 Peak sync jitter 4/9, peak Rx sync delay 579, resyncs 0/1, no step interrupt scheduled VIN voltage: min 24.2, current 24.2, max 24.3 MCU temperature: min 29.2C, current 31.4C, max 31.4C Last sensors broadcast 0x00000002 found 1 65 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 919, send timeouts 0, received 437, lost 0, free buffers 37, min 37, error reg 0 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0 Accelerometer: none I2C bus errors 4509, naks 4509, other errors 4509
Hi, same issue with me
20/12/2021, 14:25:59 M122 B20
Duet TOOL1LC rev 1.1 or later firmware version 3.4.0beta7+1 (2021-12-18 13:47:42)
Never used RAM 2576, free system stack 2788 words
Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.2%,115) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(delaying,3.0%,57) MAIN(running,91.9%,351) IDLE(ready,0.0%,26) AIN(delaying,4.9%,142), total 100.0%
Last reset 00:05:17 ago, cause: software
Driver 0: pos 0, 830.0 steps/mm,standstill, SG min 0, read errors 0, write errors 1, ifcnt 35, reads 27864, writes 12, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0
Peak sync jitter 1/5, peak Rx sync delay 214, resyncs 0/0, no step interrupt scheduled
VIN voltage: min 24.6, current 24.7, max 24.7
MCU temperature: min 30.6C, current 30.7C, max 30.8C
Last sensors broadcast 0x00000002 found 1 184 ticks ago, 0 ordering errs, loop time 0
CAN messages queued 6288, send timeouts 0, received 2853, lost 0, free buffers 37, min 37, error reg 0
Accelerometer: LIS3DH, status: 00
I2C bus errors 0, naks 3, other errors 0
@serge
20/12/2021, 14:29:43 M308 S1 H999
Measured H correction for port "20.temp0" is -6
