Heater fault on heated bed because it's rising to slow.
@gloomyandy thanks for digging! looks like known issues that will be resolved in the next beta/rc
Well there you go, just have to adjust the heating rate until b7 / RC1 sees day then
@gloomyandy Thanks for the info.
I thought that my Nevermore carbon recirculation filter with fans was responisble for the heater errors.
Looking forward to the next beta release then
@gixxerfast Just to be clear, I'm not saying that the above changes will fix the problem, just that some things have been changed! Will need to be tested with the next release I guess?
@gloomyandy said in Heater fault on heated bed because it's rising to slow.:
@dc42 Guess this is something you could either confirm or deny?
Heater 0 fault: temperature rising too slowly: expected 0.44°C/sec measured 0.21°C/sec
Build the new source code after Beta6, the same.
@hestiahuang did you run M303 heater tuning on the bed heater, and save the M307 result?
yes, I did. Ran Auto PID and saved, also restarted. But still failed, even I used bangbang mode, full speed, I mean.
After above, I got this tooThen I changed the code and built Beta7 version, everything looks good now.
I adjusted the factor 0.5 to small value simplely => RepRapFirmware\src\Heating\LocalHeater.cpp => Line#317 => if (actualTemperatureRise < expectedTemperatureRise * 0.5)
@dc42 I guess this should be new good feature, it will be perfect if it is better to enlarge the limitation. Or can have parameter to set expected rate.
Need to resume my printer can print first, so I call it simple way...
Read from change history, issue is involved from Beta3 and keeping improving.
@hestiahuang we have made changes in 3.4.0beta 7 that we believe resolve the majority of these cases.
@dc42 You did great! Thank you so much!
now with beta7 i also get this error. with rrf 3.3 all was fine
undefined joeko referenced this topic
@joeko
Have you re tuned the heater after upgrading to b7? I haven't gotten around to test mine btw, so just asking out of curiosity -
@exerqtor said in Heater fault on heated bed because it's rising to slow.:
@joeko
Have you re tuned the heater after upgrading to b7? I haven't gotten around to test mine btw, so just asking out of curiosityyes after update from 3.3 to this beta7 i did an pid tuning for bed and hotend with m500. with 3.3 there was no problem. i reduced the r in 307 to 0.19 and was able to heat the bed and print
@joeko said in Heater fault on heated bed because it's rising to slow.:
@joeko
Well in that case it looks like the heater tuning needs more work @dc42
Actually, I have more heater problems as well with the b7 than I had with the b6. Instead of one error while heating up that just could be restarted I now have to restart it three times. And I have done the heater tuning (pid calibration).
Thing is a have a active carbon filter under the bed where the fans kicks in at 65C. Although it's a very low airflow it seems to disturb the heating process.
I would like an option to just turn all this control off. Max temp supervision is enough for me as far as I can understand it now.
Sorry to hog in in this thread.
Short feedback from my side, the problem is not solved
The Result from the pid tuning with RFF 3.4.b6:
M307 H0 R0.460 C286.278:286.278 D0.90 S1.00 V24.3 B0 I0and the result from PID tuning with RRF 3.4.b7:
M307 H0 R0.484 K0.438:0.000 D0.85 E1.35 S1.00 B0and the error:
Error: Heater 0 fault: temperature rising too slowly: expected 0.43°C/sec measured 0.19°C/sec
