Thermistor Temperatur od T2 and T3 are not correct
@mike-0 what firmware version are you running?
M115 will tell you -
@jay_s_uk It is 3.2.2
IRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.2.2 ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2021-02-11
@mike-0 In terms of stuttery movement, i'm pretty sure something got fixed between 3.2.2 and 3.3 for that so I would suggest upgrading (and have a skim through the notes just in case).
Can't help you with the thermistor issue though -
@jay_s_uk, thanks a lot. That sound promising. I will check how to do an update. I might wait till Someone from duet come back to me regarding the Thermistor thing.
I honestly think the problem of the thermistors is Hardware (or firmware) related. Because it seems nobody else had this issue.
@mike-0 it may well be hardware related. the duex is the only board I don't have.
Updating the firmware is as easy as uploading this zip to the system tab https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet2and3Firmware-3.3.zip
and the changelog is here https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x#reprapfirmware-33 -
@jay_s_uk Thanks a lot. I will give it a try tonight.
@jay_s_uk I just updated the firmware. It was very easy. But the stuttering and the Thermistor problem is still there.
@mike-0 can you post your whole config?
@mike-0 M667 S1 has been replaced by M669 K1.
Your M566 speed for Z is really low. Increase it to 60 or 120. That may fix your issue -
@mike-0 what is the PCB revision of the DueX board? It's written on the top, next to the ribbon cable connector. If it's revision 0.11 then you need to add parameter R2200 to the two M308 commands that refer to thermistors connected to the DueX.
@dc42 That did the trick. Yes the version was 0.11.
Thanks a lot. I'm super happy for the quick support. Thanks again
@jay_s_uk I think that solved the problem. It is much smoother now. But i will monitor it.
Thanks again for your help.
undefined Mike 0 has marked this topic as solved
@SignPostMan said in Thermistor Temperatur od T2 and T3 are not correct:
@dc42 said in Thermistor Temperatur od T2 and T3 are not correct:
R2200
Same problem, Same Fix
Firmware 3.4 and later detect the DueX version automatically and adjust the default R parameter for M308 accordingly.
