Pausing during printing
I just finished my toolchanger using duet 3 with hemera toolboards. I installed superslicer (latest stable version) and am facing an issue, pausing during printing. I'm trying to print a benchy and im having blops constantly on one side from all the pausing being done during the print. I decreased the processing limit (g1 per second)from 1000 to 150, and the minimum extrusion length up to 0.05 but results remained the same. It's not minimum layer time as I noticed that sometimes it stops multiple times per layer.
Do you know what maybe is the cause?
Thanks,
Terence
@terencemuscat In addition, I also reduced the speed and the problem is still there. Pausing points are almost in the same place but not exactly, meaning not a problem from the Gcode.
@terencemuscat do you have a filament runout sensor installed?
Please try another browser. I've actually noticed some issues with Super slicer lately where certain combinations of settings will produce movement sequences with basically 0 movement speed which makes it seem to pause randomly.
Inspect the gcode preview in the speed view and see if there are any oddly slow sections.
@phaedrux do you mean a different slicer?
@engikeneer yes.
@phaedrux same problem with simplify 3D. I noticed it only happens in complicated surfaces, such as rounds.
@qdeathstar no
We'd need to see some more detailed information to help further.
Can you share the results of M122 and M98 P"config.g"?
Also share your config.g and homing files. A sample sliced gcode file that has the problem would be helpful as well.
