Only probe where printed. Solution here!
Doesn't look like cura has anything that is set as a user variable for print position max that I can find
Poked around in a sliced gcode from cura - it passes MIX/MAX as comments in beginning of gcode.
;FLAVOR:RepRap ;TIME:1813 ;Filament used: 2.3164m ;Layer height: 0.28 ;MINX:124.335 ;MINY:124.335 ;MINZ:0.24 ;MAXX:175.665 ;MAXY:175.664 ;MAXZ:21.45 ;Generated with Cura_SteamEngine 4.12.1
Looking to see if those are values that can be used in start... if not, may be able to write a small plugin that set variables
min and max for X and Y are also available as macro variables in the recent kiri:moto 3.1 development release.
Found a post processing script for cura here: https://forum.duet3d.com/topic/14994/f-r-auto-define-m557-mesh-bounds-from-gcode/5?_=1637506151764
It would be nice if we could have the firmware parse this as defining it in every tool i use is a pain
easier solution
- (Cura slicer plugin) To make the macro to work in Cura slicer, you need to install the post process plugin by frankbags - In cura menu Help -> Show configuration folder. - Copy the python script from the above link in to plugins folder. - Restart Cura - In cura menu Extensions -> Post processing -> Modify G-Code and select Mesh Print Size (PLUGIN)
the
M557 X%MINX%:%MAXX% Y%MINY%:%MAXY% S8
@pcr So awesome! Thanks!!
FYI, if its not loading for you, rename the file to match exactly the class name - it is CaSE SenSiTive "LevelingMeshOptimizer.pl"
@dc42 said in Only probe where printed. Solution here!:
Alternatively, to default to probing the whole bed, put this in your start GCode (example shown for IdeaMaker):
var minPrintX = {print_pos_min_x} var maxPrintX = {print_pos_max_x} var minPrintY = {print_pos.min_y} var maxPrintY = {print_pos_max_y}
Then in your mesh.g file:
var m557MinX = -100; ; put your default here var m557MaxX = 100; ; put your default here var m557MinY = -100; ; put your default here var m557MaxX = 100; ; put your default here if exists(var.minPrintX) set m557MinX = var.minPrintX if exists(var.maxPrintX) set m557MaxX = var.maxPrintX if exists(var.minPrintY) set m557MinY = var.minPrintY if exists(var.maxPrintY) set m557MaxY = var.maxPrintY M557 X{var.m557MinX,var.m557MaxX} Y{var.m557MinY,var.m557MayY} S8 ; put your required spacing here G29 S0
Caution: I have not tested this!
I'm using parts of your example now and it it ALMOST works! if i try to run the mesh.g manually it picks up the default size and probe the full bed. But it don't look like it's picking up the actual print area for some reason if i try to do a print.
This is what it my slicer outputs, and it seems right to me:
var minPrintX = 243.659 var maxPrintX = 278.245 var minPrintY = 56.6481 var maxPrintY = 91.2335
I've gotten my slicer setup so that it output's this in the very start of the custom start Gcode, long before the G29.
__
But just a little headsup it's a couple typos in the code
You've set "MaxX" two times in the default section, instead of "MaxY".
And in the M577 you're checking for " m557May" instead of "m557MaxY" -
Shouldn't the code be:
if exists(var.minPrintX) set var.m557MinX = var.minPrintX if exists(var.maxPrintX) set var.m557MaxX = var.maxPrintX if exists(var.minPrintY) set var.m557MinY = var.minPrintY if exists(var.maxPrintY) set var.m557MaxY = var.maxPrintY
@exerqtor said in Only probe where printed. Solution here!:
Correct! I did say it was untested.
Yeah np, just trying to get why it don't work lol. For some reason still won't probe just the print area.
Looks like it might be a scope issue, even though "var minPrintX = 88.6323" (for example) is in the start gcode of an ongoing print I get this3.12.2021, 13:47:51 set var.m557MinX = var.minPrintX Error: meta command: unknown variable 'minPrintX'
when entered in DWC console.
@exerqtor each GCode input channel has its own set of local variables. So a local variable created by a print file will not be visible from the console.
@pcr said in Only probe where printed. Solution here!:
easier solution
the
Not sure if you can help, but running the python plugin and enabling the M557 in start gcode I always get a huge max X
For example:
looking at the gcode output:
M557 X131.900:1500.000 Y131.900:168.100 S35.000 ; Leveling mesh defined by LevelingMeshOptimizer
Not sure where 1500 comes from.. any idea where to look for in fixing/address that? Or anyone getting this in latest cura?
Well in that case I have no idea what to do except declare them as global instead of local, and reset them to the default in the end of each probing session.
@exerqtor yes that should work.
Found the issue, I have some commands to set speed on layers and it shows up as X1500 which the regex catches... maybe i'll try and see if i can limit/exclude it lol
I'm trying to do this on my printer right now, but somehow I can't get S3D to output the min/max XY for the file to be printed.
Anyone have a tip on how to do this with S3D? -
undefined engikeneer referenced this topic
This post is deleted!
