Solved InputShaping Plugin shows only zeros with Toolboard 1lc
@dc42 the response ist M955 P20.0
@Heartleander81 can you share the acceleroemter csv file with the new config (without R12 parameter)?
@mfs12 from your is plugin I doun't find the file. In the Folder Accelerometer is only the csv files from manuelly test.
@heartleander81, please run the manual test again and share the file.
ACC from duet
IS Plugin
Sorry for the Bad Picture Quality
The plugin behaves here correctly as the file reports a sample rate of zero. This is why only zeros are displayed. I am not sure why RRF reports a sample rate of zero despite recording all those samples.
From https://forum.duet3d.com/assets/uploads/files/1633689320062-20_2021-10-08_12.32.09.csv:
998,-0.031,-0.125,1.039 999,-0.031,-0.125,1.039 Rate 0, overflows 0
@heartleander81 did you resolve this issue, or are you still getting only zeros along the bottom of the plot?
@dc42 There are still zeros displayed. Unfortunately.
Another user reported a similar issue.
@mfs12 I have See it, thanks.
Good Morning.
I have now updated to 3.4 Beta 6 and Pre 7.
Unfortunately the problem that the frequencies are not displayed is still there. -
@heartleander81 please can you attach the latest .csv file that was generated when you ran the IS plugin.
@Heartleander81, i added now an option in the "record tab" to not delete the generated files by the IS plugin.
@mfs12 When I look at the IS file in the Duet accelerometer, it shows frequencies.
for some reason your device report a rate of 0. which is strange and causing the problems.
@mfs12 OK. What could be the trigger for this?
Is there a way to do tests to find out what might be the cause? -
@heartleander81 I am still trying to work out how this could happen.
@Heartleander81 I've managed to reproduce this by disconnecting the interrupt signal from the accelerometer. So I think your board has a hardware fault. Which revision of tool board is it? If it is a rev. 1.1 board, does it have a diode soldered on the underside in one corner of the board?
