Rotating Magnetic Sensor - Keeps Pausing Printer
@thedragonlord yes thanks
@thedragonlord @wouldstain thanks the mounting arrangements look good. I hope be be able to investigate this with the gcode you uploaded here later in the week.
@t3p3tony said in Rotating Magnetic Sensor - Keeps Pausing Printer:
ok, thanks
@t3p3tony this one is interresting:
Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 26.50mm/rev, allow 20% to 130%, check every 3.0mm, version 3, mag 132 agc 76, measured sensitivity 19.53mm/rev, min 100% max 100% over 12.0mm
happening repeatedly on a smaller print.Drywall_Anchor.gcode
@wouldstain @TheDragonLord please also provide your config.g files, to help us reproduce this.
@dc42 said in Rotating Magnetic Sensor - Keeps Pausing Printer:
sure! here's mine!
Thanks
If it could help I've discovered that the Magnetic sensor "doesn't like" theese two Ideamaker settings (that's the slicer I use). Unchecking both of them the false errors reduces a lot but, of course, this can't be the solution because in this way you get bad prints....
@thedragonlord I have been working on replicating the very fast error print you sent through
Please can you send through the two macros that are called by your start gcode:
M98 P"Print_gcodes/print_petg_pressure_advance.g" ;pressure advance M98 P"Print_gcodes/print_start_gcode.g" ; start gcode operations
I get not "great" results but not nothing like as wide a variation as you see
measured sensitivity 24.45mm/rev, min 70% max 103% over 219.2mm
measured sensitivity 24.53mm/rev, min 71% max 103% over 140.2mm
measured sensitivity 24.64mm/rev, min 71% max 104% over 100.9mm
measured sensitivity 24.89mm/rev, min 72% max 104% over 61.5mmas an aside, you may have already resolved this but this is an error in your config.g (its not related to this issue):
M350 E16:E16 I0
The second E should not be there
@thedragonlord said in Rotating Magnetic Sensor - Keeps Pausing Printer:
Yes, these settings probably cause a lot of short moves with retraction which may be related to the issue.
M350 E16:E16 I0
Here are the g files and thanks for the M350!
print_petg_pressure_advance.g.txt
print_start_gcode.g.txt -
@thedragonlord thanks, sorry to be a pain but can I also have your heightmap.csv file.
basically looking for anything at impacts the print process.
You don't need to apolgize, you are helping me so it's all ok!
Here's the file:
have you discovered something? The sensor are almost completely unuseful because they keep om pausing even without the two settings...
EDIT:
I was thinking about a thing....could it be that this issue depends from the pressure advance? I'm using it with 0.4 value... -
@thedragonlord I managed to get some testing done this week and have passed the results on to @dc42. I have some more tests to do though. I made a cut down version of your print file, with as little movement as possible to see some of the effect and got 64% to 106% which for movement with no major retractions I find odd. So in summary its not forgotten, but not pinned down yet.
I've also been seeing some unusual behaviour with my 600ppr encoder based filament sensor but didn't have time to investigate so I've disabled it for now.
If there is any significant updates on this I'll reactivate my DIY sensor.
ok, thanks! I think the key is PA...Let me know
@thedragonlord I have been testing magnetic filament monitor reporting yesterday and today with a view to discovering why some users are experiencing this type of problem. As part of this I am putting together a set of test files. Here are the first three (more will follow). Please try them on your machine. In each case:
- Select a tool and preheat it to your normal extrusion temperature, or a little higher (to make sure the extruder doesn't skip steps)
- Ensure that the MFM is disabled (use M591 D0 S0 if you are testing extruder 0)
- Run the file. It will home the printer if it hasn't already been homed, then extrude 10mm above the bed between X0 Y0 and X0 Y50. So it should be OK to run on almost any printer.
- At the end it will use M591 to report the calibration data. Report the results here.
- For the third one, the results may depend on your pressure advance setting. I get good results with PA=0.2 (my usual setting) and also with PA=1 but your results may vary.
- The default extrusion speed is 1mm/sec. You can run the tests at a higher extrusion speed using the speed multiplier or the extrusion factor multiplier.
