InputShaping-Plugin-0.2.0-pre4 released
Hey,
last time I ran into trouble with with boards not having CAN support at all. So fingers crossed things are working now. As i do have only a mini5+ setup which doesn't cover all possible setups out in the wild.
Looking forward to your feedback. And one more time thanks to the people reporting and helping me testing.
As this plugin is still experimental in its early phase please take the time and read at least through the howto section.
Have a nice weekend.
release notes for inputshaping plugin 0.2.0-pre4
This work is based on the original acceleration plugin. Input shaping plugin tries to take
the input shaping calibration to a next level.The current state is still EXPERIMENTAL!!!
Although it's experimental it brings already some handy features which is why i
am doing this release. Therefore please comment, give feedback, report bugs and share your
ideas.requirements
- Duet Web Control 3.4.0-b4
- RepRap Firmware 3.4.0-b4
features
- restructre plugin to use vue components
- added test configuration component
- added recorder component
- added chart component
- use object model to determine status of test
- added add/delete of algorithm configurations
- added add/delete/select of records
- added add/delete/select of sessions
- display test parameters in chart component
- allow records with differing samples rates of up to 1%
- cleaned up debugging output
- added localization
- home device only if not homed
- improved ui layout
- added component to manage multiple sessions
- added more parameter validation for test and algorithm
- disable tab record tab when no algorithms defined
- disable tab chart when no records available
- improved error reporting
bugs
- fixed initial filtering of records by axis
- fixed session cleanup when session is deleted
- fixed data handling when swapping sessions
- fixed can address handling (needs more testing)
- fixed record integrity when referenced algorithm is changed
- fixed CAN address handling when address is null
known issues
- parameter validation doesn't cover every situation
downloads
howto
initialize session
- switch to tab "initialize"
- create a new session or
- select an available session
configure session
- switch to tab "configure"
- configure your session session
- configure test parameters
- add as many input shaping algorithm configurations as you like
- more than one per algorithm are allowed
- this is good to compare different input shaping configuration of the same algorithm
- CAUTION: once a record in a session exists test parameters can't be changed anymore.
record profiles
- switch to tab "record profiles"
- press "run" button and wait until recording is done
frequency analysis
- switch to tab "frequency analysis"
- in "acceleration records" section you see a list of profiles recorded
- clicking on the entry DELETEs it form the session!!! (it is lost!!!)
- in "filter" section the show/hidden graphs are displayed
- un-checking an axis will hide or show all charts of an axis group
- in chart section
- individual graphs can be shown or hidden by pressing the colour next to the name
- press "FFT" button to show FFT representation of the graph
- press "Time" button to show time representation of the graph
limitations
- currently no data is stored permanently!!!
- everything is volatile so avoid hitting browser's reload
what's next?
Potential next steps are
- store session in a local file or in browser's local storage or
- load session from local file or browser's local storage
- recommend input shaping parameters
- improve input validation
- add translations
changes from pre3 to pre4:
1c1 < # release notes for inputshaping plugin 0.2.0-pre3 --- > # release notes for inputshaping plugin 0.2.0-pre4 29a30 > - home device only if not homed 31a33,36 > - added more parameter validation for test and algorithm > - disable tab record tab when no algorithms defined > - disable tab chart when no records available > - improved error reporting 35c40,53 < - fix initial filtering of records by axis --- > - fixed initial filtering of records by axis > - fixed session cleanup when session is deleted > - fixed data handling when swapping sessions > - fixed can address handling (needs more testing) > - fixed record integrity when referenced algorithm is changed > - fixed CAN address handling when address is null > > ## known issues > > - parameter validation doesn't cover every situation > > ## downloads > > - https://github.com/mfs12/DuetWebControl/releases/tag/inputshaping-plugin-0.2.0-pre4
@Heartleander81, can you test the updated release if this sorted out your problem? I would be interested in your feedback.
can't install itsomething was going wrong, I'm sure that I have installed the latest DWC but today is the old DWC shown ?!?!?!
@SIam, you need to upgrade RRF and DWC to 3.4.0-b4.
@mfs12 for now, it's working but i have a new error for you
@siam, please check that all parameters are set in configure tab. I think you didn't set any axis to test.
BTW this is an known issue which I am trying to find a good solution.
@mfs12 reloading the DWC (F5) solved it
@mfs12 home device only if not homed seems not to work:
and here you can see that the machine always will be homed
@SIam, can you send me you browser dev tools console log?
this might be helpful. best would be to share it via pastebin.
@mfs12
here we go -
@SIam i am a little clueless. On my device it skips that stage. what happens when you hit the run button a second time?
@mfs12 said in InputShaping-Plugin-0.2.0-pre4 released:
The printer will be first homed every time i press the run button
@siam check your PM please.
@mfs12 now the homing is gone but i will get no output in the console when i start the test.
@siam try uninstalling the plugin and reinstalling it
please check the new release...
https://forum.duet3d.com/topic/25351/inputshaping-plugin-0-2-0-pre5-released/
