BL Touch Issues... Again and Again...
@fcwilt If you say so.... regardless your of no assistance to my issue if you can't figure out what's going on here LOL. Duet3D support will understand just fine as they always do and have a non condescending reply that addresses my direct issue.
@kwad3d-0 said in BL Touch Issues... Again and Again...:
1
Well I do know what I am talking about. I have four custom printers and they print just fine. Two of them use BLTouch devices and they work as they should.
He is one of the heightmaps generated with a BLTouch.
@fcwilt my height map looks better then that however still lifts off on one side by about 1mm. So You don't know what your talking about and are just trolling at this point. You have not contributed anything at all besides criticizing my terminology I use. I don't want you to comment any longer and be on your way now...
I think you are confused about who may be a troll.
But since you are so wise I'm sure you can solve this simple problem on your own.
Have a great day!
@fcwilt No confusion. You have nothing positive to add and are only here to argue with the poster. Just trolling. The only one confused here is the guy who can't figure out what I meant when I said Mesh...
It's hard to help when there is not enough information provided to determine the cause of the problem.
How about you post your height map image and CSV file along with your config.g file.
@fcwilt Oh Your still here??? Thought I said you could leave.....
Since you are having troubling solving your problem, I and the rest of us are here to help.
But you have to let us by providing additional relevant information.
@fcwilt Your not here to help so I will just hang out for a Mod who knows what there talking about and what Im talking about. Like I said earlier.... If you don't know what the word "Mesh" is referring to then you don't have the mental capacity to be of any assistance. However I don't believe this is the case. I think that you know what I referred to and are just playing a childish game to pass some time....
@fcwilt is one of the experienced users who really knows this stuff and spends a lot of time helping. But to help he must first understand what the problem is.
I can not get such an attitude ...Edit:
Yes and sometimes he is also very accurate about terms. But that is certainly not to bother... -
- Can you describe what you are doing to probe the shape of the bed? Sometimes there are simple errors in probing that can cause issues and it would be good to know you are doing everything the right way.
- Can you post a screenshot of your heightmap after probing? Sometimes that helps see something strange going on.
- Can you post your config.g?
- Can you describe in a little more detail what problem you are having? It sounds like if you go to Z=0 on the left-side of the bed that the nozzle is very close to the bed, and if you move to the right in the X axis and go to Z=0 that the nozzle is 1mm off the bed. Is that right?
- Can you tell us what kind of printer you have?
- Can you tell us what version of firmware you have?
- Can you tell us what specific Duet board(s) you are using?
All those things help you get a quick correct set of things you can do to work towards getting better prints.
I can a spot a wind up when I see one. OP joined 28th at 17:30 then spent the next hour and half insulting anyone who tried to help. If this is such a big recurring problem, with multiple duet boards, how come we haven't seen any posts apart from this single thread?
@deckingman said in BL Touch Issues... Again and Again...:
What is a "wind up"?
I'm not familiar with that phrase.
@fcwilt said in BL Touch Issues... Again and Again...:
That is very difficult to explain to a non- native English speaker. A wind up can mean many things but In this context, the best explanation I can give is - to say or do something with the deliberate and sole purpose of annoying or angering other people.
That sounds spot on.
Thanks for the explanation.
@kwad3d-0 post your config.g and response to M115, please. And what layout the printer is, eg Cartesian bedslinger, CoreXY, etc. I’d expect the probe is offset in Y axis, and your X carriage rotates around the x axis as it goes from one end to the other, causing probe to lift or drop relative to the nozzle.
Thanks for responding. Its a Core XY machine. The leveling performs just fine besides being off on one side consistently. I can see the Z motors adjusting as it progresses across the bed. The amount of lift is consistent enough that all I have to do after finishing a probe is reach down and clock the one Z motor one click and the desired affect is achieved. There may be a simpler solution as the only reason I have to re level is due to the bed being heavier then normal and drooping when the motors go to idle. So is it possible to simply adjust the idle current to provide more support to the bed between prints? Then the minor inconvenience of manually adjusting the one Z axis would only have to be done after the printer is shut down... which is only like once a month.
This post is deleted! -
@kwad3d-0 please, config.g, response to M115, and ideally the macro you’re running for bed levelling. Without these a useful answer is all but impossible. See points mentioned here https://forum.duet3d.com/post/53522
@droftarts Ok I will provide that info soon as I get back to the Office. Regardless I would like to increase the idle strength of the motors to prevent the bed droop between prints. Is that possible?
