Issues after prime
You said that the following axis suddenly causes problems after the extrusion? Then I think of a "misprint" that I made with the toolboard. The paragraph should not be but a plan. See the following picture -
ok i misunderstood something. I will gradually comment out and test each line from top to bottom.
With line 14 have I the issuse and without is all ok
G90 M83 M302 P1 ;;dc T-1 ;;dc M106 S0 G4 S1 ;;dc ;;M140 S50 ;;M190 S50 ;;M104 S240 T0 ;;M109 S240 T0 T0 M83 G1 X5 Y5 Z30 F6000.0 ;G1 Y50 Z0.2 F3000 after comment out this line looks out run without issuse G1 Y90 E20 F300 G1 Y120 F1200 G92 E0.0 ; process CR3D 0.4 ; layer 1, Z = 0.200 T0 G1 E-0.6000 F1200 ;SB ; feature skirt ; tool H0.200 W0.440 G1 Z0.200 F600 G1 X118.950 Y122.494 F12600 ;G1 X19.489 Y53.567 F12600 ;G1 E0.6000 F1200 ;G1 X280.511 Y53.567 E8.9768 F1800 ; layer end T0 ;;dc M98 P"endGcode"
@heartleander81 thanks again. What about lines 17 and 20: if they are commented out and line 14 reinstated, does the problem occur?
After I comment out Line 20 its all good -
@heartleander81 thanks again!
I was able to issolate / fix the error by going to Z0.3 in line 14 with the long code.
I also tested things at the same time. Maybe that will help you
@dc42 Thank you very much for your effort and patience with me.
@heartleander81 said in Issues after prime:
Thank you for testing!
@phaedrux
very gladly. I work as a department service employee in a company. So I know how important troubleshooting and testing are. -
@heartleander81 unfortunately I still can't reproduce the problem. I've run it with and without line 20 (the T0 command) commented out, and analysed the moves in both cases. The only difference between them is that with line 20 present, there is a slight pause at that point, because RRF will wait for all preceding moves to complete and then wait until a few moves are in the queue (or no more are forthcoming) before executing the next one.
The effect of changing line 14 to Z0.3 is that line 24, which was previously a null move, is now a move in Z. So the problem may just have moved to the Z axis.
If you have time, please can you revert to the file that you posted in this post https://forum.duet3d.com/post/246160 that did show the problem, then check that it still does. Then replace the T0 command in line 20 by M400 and check whether the problem persists.
Please also try the effect of commenting out line 24 (the null Z move) just in case it is having an effect.
@dc42 I like to do
@dc42 Using M400 instead of T0 is the same problem
Thanks! so tool change is not part of the problem.
Does the problem still occur if you comment out the G1 Z0.200 F600 line 24 ?
Have it do, G1 Z0.2 F600 comment out problem is there -
@heartleander81 thanks! So your file should look almost like this (I have commented out a few more commands that I don't think are relevant):
G90 M83 M302 P1 ;;dc T-1 ;;dc M106 S0 ;;G4 S1 ;;dc T0 M83 G1 X5 Y5 Z30 F6000.0 G1 Y50 Z0.2 F3000 ;;after comment out this line looks out run without issuse G1 Y90 E20 F300 G1 Y120 F1200 ;;G92 E0.0 ; process CR3D 0.4 ; layer 1, Z = 0.200 M400 ;;dc was T0 G1 E-0.6000 F1200 ;SB ; feature skirt ; tool H0.200 W0.440 ;; G1 Z0.200 F600 G1 X118.950 Y122.494 F12600 ;G1 X19.489 Y53.567 F12600 ;G1 E0.6000 F1200 ;G1 X280.511 Y53.567 E8.9768 F1800 ; layer end ;;T0
Please confirm that the problem is present using this file, and not present if you comment out the M400 at line 16.
This post is deleted! -
@dc42 yes with the code and the line 16 M400 the error is there and if I comment out the line 16 M400 the error is gone
@heartleander81 thanks again. My current theory is that the problem occurs when a move sequence (after e.g. M400 or tool change) starts with a move that doesn't involve the main board. If that's the case, then inserting any axis move command (e.g. G1 Y120.1) after the M400 line and before the G1 E-0.6000 line should avoid the problem.
@dc42 Yes that is correct after M400 the command G1 Y120.1 removes the problem.
