Printing problem with filament or set up?
You mentioned something about setting the Extruder offsets to X150 and Y100.
That is very likely wrong.
ok at this point i have cleaned out all the slicer files from the last month of trying to get this to work.
I also took out the slicer completely from my machine and reinstalled a new fresh copy of the Prusa slicer 2.3.3.
i did mover the origin back to the front front left corner in the slicer as well. so this is where it homes for now. i would like it to home in the center but this is not practical at this time.
now i have ran through the slicer again with the factory settings and put the basic information in and now the Z works pushing the nozzle closer or away with the touch screen baby steps. Plus the printer now increments for the layers where before it did not.
what part of the slicer settings you need to see?
@testpro said in Printing problem with filament or set up?:
Not practical - what does that mean?
Homing does not have to mean moving to X=0 Y=0. Homing is simply the process by which the firmware determines where things are on the X,Y,Z axes.
One of my printers homes to Xmax and Ymax, one homes to Xmin and Ymax but they all have the origin (X=0 Y=0) at the center of the bed.
Having the origin be the center isn't too hard. See here:
https://duet3d.dozuki.com/Wiki/Centering_the_bed_or_setting_the_bed_origin
One way or another, the firmware and the slicer just need to agree on where the 0,0 point is and what the size of the bed is.
Ideally everything. If you load a small STL and then do a file save project as .3mf and upload it here we can see all of your settings.
ok first test print incremented as it should while printing the first layer and fine tuning it.
once i confirmed the Z was incrementing for the steps of adjustments and for the second layer. i did another test print but this time i added in the bed compensation and now it will not let the Z axis increment and will not increment on second layer either.
[0_1629147063561_100mm_Rounded_Cube.3mf](Uploading 100%)
Either the file is too large or not allowed by the forum software. If it's more than 4mb, upload it to a cloud drive and share a link, if it's less than 4mb, try adding a .txt extension to the file and upload again.
Do you still have that weird 5mm z offset for the tools?
the file format is not allowed. and no more offsets for the tools at this time.
still can not figure out why z will not increment with the bed compensation working.
@testpro
after doing the manual bed leveling several times my height map is -0.22 to 0.021.so pretty even at this point.
at this point the objects are now printing in the center of the bed. so that is cleared up for now.
i have found the reason why the Z axis was bit incrementing. in the slicer Prusa 2.3.3 under print settings. Custom G code i had the following:
G28 ;home all axes
G29 S1 ;allows bed compensation
G1 Z5 F5000 ; lift nozzlethis would not let the Z axes increment while printing but i changed it to this :
G28 ;home all axes
G29 S1 ;allows bed compensationand it now works just fine. why is this an issue? or did i just stumble on to a bug?
While printing any normal Z move is going to be affected by mesh compensation.
Enabling mesh compensation is the very last step in my "print start" code.
That doesn't make much sense to me either.
Can you share the actual gcode file now?
I had a look at the 3mf you uploaded and your settings look ok. Though I would suggest enabling relative extrusion in the slicer printer settings tab. Relative E distances I think they call it there.
@phaedrux
100mm_Rounded_Cube.gcode 1_MAKE_Robot_V6.gcodeok i have gave you the gcode for the Cube which printed very well and then the make robot which is not printing so well at this time.
@testpro
100mm_Rounded_Cube.gcode BB.gcodeSorry this is the latest and best print file i have at this time. the one above is an older version of this file.
It looks like your retraction settings could use some attention in addition to enabling relative extrusion.
Retract on layer change, yes
Retract always on travels, not just when crossing perimeters
Retraction length is 2mm, which may be too much or not enough depending on the hotend and extruder. What do you have on there by the way?Retraction should reduce the oozing.
Retractions speeds and extruder jerk and accel should be tuned as well.
Based on your last config that was posted I would use
M566 X900 Y900 Z60 E3000:3000 P1 M203 X12000 Y12000 Z600 E6000:6000 M201 X600 Y600 Z200 E3000:3000
I would also add
M204 P600 T2000
to that section of config.g to allow faster acceleration on travel moves for less oozing, but lower on print moves for quality.That should allow the retractions and layer changes to be a bit quicker which can help with the layer seam bulges.
Your print and travel speeds are also quite slow. 20mm/s on solid infill, 15mm/s on top solid. Even your first layer is faster at 30mm/s. Travel speed only 100.
Try setting these speeds.
Retraction: 50mm/s length 1mm
travel speed: 200
inner and outer perimeter 50
solid infill: 50
infill: 50
top solid: 40If those speeds work ok, bump the 50s to 60s
