Unsolved PT100 amplifier board - redaings seems to be 30 degrees below
@dc42 I’m using a Fluke. I have 3 others. I’ll try them all. However, how would we ever be able to come up with a reference for resistors if all multimeters give us such a diverse readings?
@dc42 I can’t attach a picture, it will not let me however I can tell you R1 is marked”102” while R2,R3,R4 are all marked “201”
On my precision bench meter both resistors measure R1-199.50 and R2-199.52
I also have 3 PT100 cartridges in the same room measuring within 1° of each other. By that I mean looking at a PT 100s resistance table and measuring each one’s resistance, according to the table they are within 1° of each other.
Also curious, if the channel 1 on the daughter board is “spi.cs1”
And you have one daughter board with the two ports, then is the second port for the same card “spi.cs2”? -
This post is deleted! -
@tony449777 said in PT100 amplifier board - redaings seems to be 30 degrees below:
Why can't you attach a picture?
Do both channels give the wrong reading when you connect the 100 ohm resistor to each in turn?
And you have one daughter board with the two ports, then is the second port for the same card “spi.cs2”?Yes.
@dc42 yes
@dc42 I’m using the phone application. Every time I try to attach a picture it just says undefined.
@tony449777 it's easier from a PC, you can just drag and drop a .jpg file into your post.
@dc42 Update. Switched out the daughter board for another one I purchased from filastruder and it works fine. It must be the board.
I believe I got this daughterboard from Filastruder. It was purchased a while ago, but never used until this build.
How long is a while ago?
@dc42 my 2nd channel died :I( i will be replaceing the chip, on the way want to check other parts. there are 2 pairs of capacitors - c1/c2 + c5/c6 what its default capacity should be?
also there is small black SMD element in between C1 and R1. what is it? what are the parameters?
many thanks!
@c310 the schematic for the board is here:
https://github.com/Duet3D/TempDaughterboards/blob/master/MAXTempRTD/MAXTempRTDv1.1.pdfI assume you are refering to the inductor L1:
two screen shots depending on the version of the PT100 db you have.it is an inductor such as LB2012T101K
@t3p3tony said in PT100 amplifier board - redaings seems to be 30 degrees below:
LB2012T101K
thank you @T3P3Tony !!!!
