Short-to-ground reported by driver 1 2
@gabinnan said in Short-to-ground reported by driver 1 2:
@jay_s_uk still it says the same. My wiring with nema17 :
- Red to 2B
- Blue to 2A
- Green to 1A
- Black to 1B
what is wrong?
Do the wires come directly out of the stepper motor, or is it a separate cable that plugs into the motor? If it's a separate cable then you can't trust the colours.
@jay_s_uk it think my wiring is right. I am using Nema 17HS16-2004S1.
It says the same error even the is no motor connected
@dc42 they are separated cables
@gabinnan can you post a photo of the end that goes into the motor?
Looking at the stepperonline page, they should be cables that come directly out of the motor, not with a separate plug. -
@gabinnan can you therefore confirm the stepper phases using a multimeter, ignoring the colours of the wires. The link I gave you should guide you in that.
red & blue same phase
black & green same phase -
@jay_s_uk solution?
@gabinnan try a different driver and see if the error follows it.
if not, when was your duet purchased? -
@jay_s_uk it is not working. it was purchase on june 14th 2021
@gabinnan also, where did you purchase it from?
@jay_s_uk filafarm in germany
It would seem likely that you have 2 failed drivers.
Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
Sorry for the inconvenience.
