Firmware 1.19RC5 released - last chance to report issues
I cancel print jobs from the panel due all the time.
It works. -
I have noticed an issue that has existed for some time but just confirmed it really does exist….
Power on, run Auto Delta Calibration from the panel due - the button.
Now run it again.The second time seems to honor the dive height whereas on the first run it sort-of does. I mean, I have recently had to set my dive depth to 10m, which takes forever to complete a pass, but without 10m set the IR probe goes wonky between probe points.
This is a change from 7mm I had set in earlier firmware releases.The first pass does not go 10mm dive height, the second does. I know this because the first pass completes is about 3/4 the time the second pass does.
M558 P1 X0 Z0 H10
Granted, I may need to dial my Z height in (again). First run result is something like 6.778 second and future calibrations ar 0.091 or so. Still, I seem to recall this pattern for quite awhile, maybe since an early beta.
My current settings (heh):M92 X100 Y100 Z100 E150:150:150:95:95:95:95 ; Set axis steps/mm
M665 R88 L215 B100 H355.00 ; tweaking height
G31 X0 Y0 Z2.704 P500 ; Set the zprobe height and threshold (put your own values here) - for Z, bigger number means closer to bedCan someone with a delta and a ir probe double check what I am saying??
Yes, it sounds to me that you need to adjust your M665 parameters in config.g to the values you get after running auto calibration twice. Or you can use M500 to write them to config-override.g.
Today tried to update to the final 1.19 I seen on the github.
I still can't find a way to connect to my router. I followed every single step and still can't put my router info on the N587, it has only letters and numbers caps and minus, but nothing special. I can't figure out how to insert my router wifi on this 1.19
But if I run my SetNetwork macro, it doesn't work, and it doesn't even write it on the M588 list. I'm really lost on what to do.
I suppose the old adhock method of configuring it is out of the table right?
Things I did:
- Follow step by step to the letter. bins are updated and all ok.
- Printrun connect to the duet3d by usb.
- Executed the network macro with my Router info
- I do a M98 P/macros/NET and I get a
Wifi module started - I do a M587 to check the networks and I get
"No remembered networks"
So… I'm truly lost
I can manually insert a fake M587 S"ONODUET" P"WOCAWOCA"
I also did a M588 S"*" to check and I can remove the fake info, but the macro doesn't feed the data to the network list.Is there any MANUAL way to edit this? I really can't care les about security if it's something that can be done by usb. I just want to connect and use the new version
It's there ANY way to set caps/minus directly by USB connection? Because when I do that manually the fake info goes in. And I really CANT change the modem password to something simple, that would defeat the pourpose of this extra security of now having the adhoc now? Dunno...
Any suggestions??
BTW for MAC users. If you guys edit the TXT files with TexEdit, remember to DISABLE automatic Quotation marks or it will change the " to the writters style, killing the macro info.
Things I did:
So… I'm truly lost
Any suggestions??
Ok all fixed.. Nothing like taking a break to check everything again. I was using M589 on the macro… So dumb me. Working, connected, super!
Btw the MAC user thing, that did happen to me for 1h and I was lost as hell until I noticed that the TextEdit was changing the " with the Writter style ", and that was so dumb too.
Thanks for the great Duet3D firmware!
with out reading all pages
i just want to say
the z-offset is not 100%
it only works when z-hop i active and is not calculated on first move
at least it like that for mefor example when using (-minus values in g10) it drags to nozzle to place then it activates the offset
i by pass this by adding a move down in the post/free files
i can make a video if you like ?<
_–---------------Firmware Name: RepRapFirmware for Duet WiFi
Firmware Electronics: Duet WiFi 1.0
Firmware Version: 1.19beta11 (2017-07-25)
WiFi Server Version: 1.19beta10
Web Interface Version: 1.17+2 -
You need to activate the tool before the first G1 move is executed, then the offset will be applied to that move.
My first impressions after updating to the 1.19 is that the wifi is way more unstable than before. I can't get the connection stable and I have to turn off/on the machine to get access back. What can be done to make it more stable? With the 1.18 latest version it was working quite nicely for the last months.
For example. Launched a print (after turning it off/on to get access back). Then now that the print has finish I tried to get access again but even the ping gives 'Host is down'.
Neotko the WiFi web server was changed between 1.18 and 1.19. what sort of WiFi issues are you getting?
The service disappears, so I cant connect to the ip of the printer. Even doing pings the service shows that's down.
So before 1.18 sometimes the service went off, but only after launching a print. Now with 1.19 the connection disappears suddenly.
I'll test changing my router settings to see if it's something related to that, but it's weird. Will do more tests to see if remains unstable or get's back to normal.
Someone else reported that the connection was unstable when they configured the router to use channel 1 or 2, but they had much better results on channel 6. I don't know whether this was due to their local circumstances or not.
With firmware 1.19, the M122 diagnostic report includes the received WiFi signal strength (RSSI). See http://www.metageek.com/training/resources/understanding-rssi.html for a description of RSSI.
If you do lose the connection and you have a PanelDue or USB connection, sending M552 S0 followed by M552 S1 may get it back again.
Weird and weird. Changing to channel 6, rather than the auto made a huge difference. Will keep testing but seems that that’s. Ofc I did test resetting the router before changing that.
The weird part imo is that before 1.19 was working ok.
Anyway very glad with the update the webcontrol 1.19 works much faster.
Perhaps I just did something wrong or in wrong order, but I dropped the duetWifi Firmware onto the webbowser update files section, it updated, and now I get "Wifi module started Error:failed to initialize wifi module, code -10"
Typing M551 S0 M552 S1 isn't starting it.
Can you link me to a wiki page or other instructions for fixing ?
Never mind, found the instructions here https://www.duet3d.com/forum/thread.php?id=2290#p21818
Sounds like you didn't do the simultaneous update of the main firmware and the WiFi firmware. So you will have to copy the WiFi firmware to the SD card on a PC instead, then install it using M997 S1.
Good deduction skills, that was my error exactly, I've now fixed it and am redoing the height map.
Sorry to bother you -
I'm closing this thread now. Anyone still using a 1.19 beta or RC, please update to the 1.19 release and report any related issues in the thread about that release.
