Duex5 fan voltage
@resh said in Duex5 fan voltage:
M950 F3 C"fan3" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P3 S1 H-1
The M106 should be
M106 P3 S1 H1 T45
assuming H1 is the heater number -
@jay_s_uk said in Duex5 fan voltage:
The M106 should be
M106 P3 S1 H1 T45
assuming H1 is the heater numberThis will turn hotend fan on when needed instead of on all the time?
Yes it will turn on fan3 when heater1 is over 45c.
@phaedrux Thanks for the help. I'm not getting fan3 to turn on when heater1 is over 45c. The part fan is always on so something might be wrong there.
On duet I have the fan jumper on V_fan and VIN, and the part fan(24v) is connected to FAN0. On the duex5 I have the jumper on 12V and the hotend fan(12V) connected to FAN3.
; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Feb 26 2021 10:46:02 GMT-0500 (Eastern Standard Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"My Printer" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards s1 is forward s0 backwards M569 P5 S1 M569 P6 S0 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 M569 P4 S1 ; physical drive 3 goes forwards M584 X0 Y5:6 Z2:4 E3 ; set drive mapping M671 X-20:290 Y0:0 S5 ;leadscrews at left (connected to Z) and right (connected to E1) of X axis M208 X10:300 Y0:180 ;X carriage moves from -5 to 270, Y bed goes from 0 to 130 M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y53.33 Z397.6143 E420.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z400 E1200.00 ; set maximum speeds (mm/min) M201 X600.00 Y600.00 Z100 E250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X310 Y310 Z180 S0 ; set axis maxima ; Endstops M574 X2 S1 P"!xstop" ; configure active-high endstop for high end on X via pin !xstop M574 Y2 S1 P"!ystop+!e0stop" ; configure active-high endstop for high end on Y via pin !ystop M574 Z2 S2 ; configure Z-probe endstop for high end on Z ; Z-Probe ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds M950 S0 C"duex.pwm5" G31 P500 X-31.5 Y7 Z4.627 ; set Z probe trigger value, offset and trigger height M557 X0:155 Y0:155 S20 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 R0.135 C738.7 D1.34 S1.00 V23.5 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 R2.039 C177.8 D6.23 S1.00 V24.0 ; disable bang-bang mode for heater and set PWM limit M143 H1 S285 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F3 C"fan3" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P3 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 S"Extruder" ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M575 P1 S1 B57600 ;enable support for PanelDue T0 ; Select first tool
@phaedrux said in Duex5 fan voltage:
No luck with the change. I checked wiring again and it looks good.
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Feb 26 2021 10:46:02 GMT-0500 (Eastern Standard Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"My Printer" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards s1 is forward s0 backwards M569 P5 S1 M569 P6 S0 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 M569 P4 S1 ; physical drive 3 goes forwards M584 X0 Y5:6 Z2:4 E3 ; set drive mapping M671 X-20:290 Y0:0 S5 ;leadscrews at left (connected to Z) and right (connected to E1) of X axis M208 X10:300 Y0:180 ;X carriage moves from -5 to 270, Y bed goes from 0 to 130 M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y53.33 Z397.6143 E420.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z350 E1200.00 ; set maximum speeds (mm/min) M201 X600.00 Y600.00 Z90 E250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X310 Y310 Z180 S0 ; set axis maxima ; Endstops M574 X2 S1 P"!xstop" ; configure active-high endstop for high end on X via pin !xstop M574 Y2 S1 P"!ystop+!e0stop" ; configure active-high endstop for high end on Y via pin !ystop M574 Z2 S2 ; configure Z-probe endstop for high end on Z ; Z-Probe ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds M950 S0 C"duex.pwm5" G31 P500 X-31.5 Y7 Z4.627 ; set Z probe trigger value, offset and trigger height M557 X0:155 Y0:155 S20 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 R0.135 C738.7 D1.34 S1.00 V23.5 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 R2.039 C177.8 D6.23 S1.00 V24.0 ; disable bang-bang mode for heater and set PWM limit M143 H1 S285 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F3 C"duex.fan3" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P3 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 S"Extruder" ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M575 P1 S1 B57600 ;enable support for PanelDue T0 ; Select first tool
If you send
M106 P3 S1 H-1
does the fan turn on? -
@phaedrux No, it didn't turn on
Are you sure you're connected to fan3 on the Duex?
Can you try with a different Duex fan port?
Does that fan work at all?
@phaedrux Changed to F4 but I also checked voltage out of the pins when hotend was above 45 and I'm getting no voltage. It's a brand new board. Also checked the jumper connection and it's good.
Are you saying it worked on fan4?
@phaedrux Sorry, it did not work on fan4. No voltage out of any fan headers on duex.
@resh what position do you have the DueX fan voltage selection jumper in? If it's in the 12V position, have you fitted the 12V regulator enable jumper?
@dc42 said in Duex5 fan voltage:
Duex fan voltage jumper is in the 12v position. I haven't done anything with a 12v regulator jumper. I see on the diagram jumper:INT 12V EN. If that's the jumper there's nothing in it. Thanks for the help.
Found the jumper and everything is working properly. I really appreciate everyone's help and patience with me.
