3D GCode Viewer integrated with DWC
What might cause the cursor to be offset from the rendered preview?
I'm using a Toolchanger, so each of the tools have offsets with respect to the Z-probe. Perhaps the offset is not being referenced?
I’ll need to look i believe the code currently uses the machine position and not the tool position which could be the issue.
@t3p3tony said in 3D GCode Viewer integrated with DWC:
;PRINTING
[...] G1 F3600 X138.747 Y111.877 E0.7349 ;PRINTING: 3mm_hinge_a_with_logo_x2(1).stl ;PRINTING_ID: 1 G1 F1500 E-2.0000 [...]
but "show object selection" is disabled:
I'm using Ideamaker 4.1.1.5050 and RRF 3.3-RC2.
@martinnyhc If you are using RRF 3.3-RC2 in SBC mode, please try to delete
/opt/dsf/conf/config.json
once and restart the Pi. I forgot to update the default DCS config in RC2 which contains a change for object detection for IdeaMaker. By deleting that file DCS will use the new defaults automatically. -
This post is deleted! -
@chrishamm said in 3D GCode Viewer integrated with DWC:
once and restart the Pi. I forgot to update the default DCS config in RC2 which contains a change for object detection for IdeaMaker. By deleting that file DCS will use the new defaults automatically.Still not working.
@martinnyhc AFAIR parts of the second object have to be printed before the object selection starts working. If it still doesn't work, make sure you are on DSF 3.3-RC2 and that "PRINTING" is part of the
FirmwareComments
field in/opt/dsf/conf/config.json
. That file should have been regenerated after the reboot. -
@chrishamm OK, will try. Thanks.
After deleting /opt/dsf/conf/config.json it works Thanks!
@sindarius said in 3D GCode Viewer integrated with DWC:
@sindarius Did you have a chance to look into this?
I was working on someone else's E3D tool-changer today and experienced the same thing, so I wanted to check in.
DWC & Firmware Version: 3.3
