Duet 2 Wifi Random Resets
@mrawesome987 said in Duet 2 Wifi Random Resets:
I am not using ferrules on the power connectors, I just used the bare wire.
Might want to give those a tighten, just in case. Bare wire can loosen over time. However the M122 doesn't say that the power was lost, so that might not be it at all.
Will have to see if there is anything useful from that M122 report for DC42.
@phaedrux Ok, thanks for the information. I will certainly tighten the power connectors. Hopefully DC42 may have some more info on this.
Just to further reduce points of failure, I think I will get a replacement SD card. I am not using the shipped SD card, as it was so small. I believe I am running a full size SD card in the PanelDue.
What is the recommended model for a larger Micro SD? Would this work?
Thanks again!
Yes that would be a good SD card choice. Be sure to format it as FAT32.
Do you mean to say you are using an SD card in the PanelDue to print from?
@phaedrux said in Duet 2 Wifi Random Resets:
I believe that is correct. I can check when I get home tonight, but I'm fairly certain I used a 16 or 32 gb card in the PanelDue to print from, since it was on hand.
Can you also compare uploading a gcode file to print directly to the SD card internal to the Duet and see if it still resets?
I will do this tonight. I also ordered a tool for the ferrules you recommended, just for peace of mind.
Ok, I was wrong. I am not using an SD card in the PanelDue, I was, however, using a no name brand SD card in the Duet. I have now followed the SD card setup instructions and used a different card (although still a no name 128mb one, until my new one gets here).
I am starting the print now, and will let you know what happens.
Thanks again for your help!
@mrawesome987 those no name 128mb ones that probably came with a BTT are only good for one thing ... throwing in the bin.
They ALWAYS cause trouble on the LPC/STM port of RRF -
@jay_s_uk said in Duet 2 Wifi Random Resets:
They ALWAYS cause trouble on the LPC/STM port of RRFGood news! The printer completed a print last night, it was about a 5-6 hour print. This is with the no name 128mb card, but I'll swap it out for the new one when it gets here.
On the card I had in the Duet prior, I tried the same exact print (same gcode) 3 or 4 times, and it failed within 2 hours every time.
I'll continue to test and update.
I got the new SD card yesterday and formatted it and copied my current file structure to it. Printed a bracket for my new printer build and it worked great. It was a fairly small print, only 3-4 hours, but it printed with no issues.
I guess this is resolved, unless it magically reappears later! Thanks for the help.
@mrawesome987 thanks for the update. I think the firmware must have been stuck in a loop in the Atmel/Microchip SD card driver waiting for the hardware to become ready; although in theory the transfer should time out instead.
