CoreXY or Cartesian which is better ?
@oliof said in CoreXY or Cartesian which is better ?:
CoreXY may be easier to build, but it's ultimately (pun intended) harder to square.
Do you talk about belt tensioning?
TBH, I made up an easy to implement "belt tension-equalizator". But never felt the urge to implement it.
Lazyness: 1
Difficult to square: 0 -
@o_lampe no, I mean getting the frame square, especially when using aluminum extrusions. Belt tension is another issue, looking forward to see your fix (-:
@hiroaki said in CoreXY or Cartesian which is better ?:
@fcwilt What is the lead of screws of yours?
I don't understand the question. The one printer I mentioned, in response to your post about having all screw drive, has all belt drives.
What do you think about the E3D motion system in that regards?
@phaedrux CoreXY may be easier to build, but it's ultimately (pun intended) harder to square. An ultimaker style sheet-based box printer is more or less self-squaring ...
Can you provide a link to a design like that?
You don't "tune" belt tension in a corexy printer. The exact and even the relative tensions of the belts isn't important (of course, you don't want them flopping around and you don't want them so tight that they destroy the motor bearings). All that matters is that the x and y axes are square when you're finished. That's easily verified in different ways depending on how your machine is built. The way most corexy mechanisms are laid out, the belts will be about the same tension when the axes are square.
It can be pretty easy to align the linear guides in a corexy printer if you build the xy mechanism on a flat plate. That's probably true of any other xy motion system, too.
You can design any printer to be easy to align or alignment can be an afterthought, and then you suffer the consequences.
@mrehorstdmd I understand! Thank you!
@hiroaki I don't use T8 lead screw (too slow), I use Igus high helix lead screws. I will never be as fast as the corexy guys, but I have no belts.
@tinken I see, how much is the lead ?
@tinken said in CoreXY or Cartesian which is better ?:
Too slow for what?
but I have no belts.How do you keep your pants up?
@fcwilt said in CoreXY or Cartesian which is better ?:
suspenders obviously.
@fcwilt Who needs pants...
@hiroaki I think they cost about $40 per meter.
I think you are best off with a corexy printer. My printers are expensive, extremely accurate for long periods of time without adjustment. But they are slow, 160mm/s max.
Since when is 160 slow? I limit mine to 90.
@fcwilt I bet you could go 300 if you wanted to..?
I only print nylon, so realistically, my maximum is 25-55. To me it's like watching paint dry in Antarctica. -
@tinken Hello No no, My question is the length for one rev of the screw....
Ultimaker Original.
In my opinion, a simple Cartesian design is the best choice.
I have come to this conclusion after designing and building 7 high-end printers in CoreXY, Hbelt, Cartesian and Markforged-Style configurations. I have not yet tested the new scurve acceleration feature on a cartesian printer, but I recon it can overcome the added vibration of the extra moving mass.
CoreXY, H-Belt, Markforged etc.
Pros:
- Less moving mass
Cons:
Longer belts always add "springiness" to the system
Higher number of belt idlers, that each add a little "wobble" to the system, since even good idlers are often far from running perfectly true
More idlers mean more parts and also higher wear on the belt since it is bend back and forth around multiple radii.
The necessary interpolation of X and Y Moves drastically limit the top speed of diagonal moves
Can take a lot of fiddling until all motors move in the right way
Cartesian:
Pros:
Higher top speed
Belts are as short as possible
Belts are only bend in one direction ->reduced wear
Fewer parts and very simple
Super easy setup
Cons:
higher mass
extra wiring for the moving motor
@maxgyver Hello.
Thank you for your advise. Itβs very helpful !!! -
@maxgyver said in CoreXY or Cartesian which is better ?:
Cons:
Have you any data to back up these "cons"? The last two are particularly suspect.
I certainly have not found these "cons" to make any noticeable difference between my printers.
