(3.3RC3) Duet 3 Mini 5 PanelDue Errors after Upgrade
Since the past RC update, we have been getting a bunch of errors on the PanelDue when attempting to use any functionality on the PanelDue, IE homing, macros, movement, anything really. We are getting some really odd messages, some not really understandable either. Please see photos for details on errors and etc. Version 3.3RC3 on Duet 3 Mini 5 and v3 PanelDue on 3.2.11. I'm in CNC mode and its really unusable but if I use web interface only, I do not receive any errors in console, but they do keep popping up on the PanelDue as machine is running various move commands from web interface.
Just FYI, cabling to the PanelDue are routed via shielded twisted pairs from PanelDue to chassis on Duet 3 Mini via gs16 connectors properly shielded to earth ground. I suppose it could certainly be cabling issue but it was all completed roughly month ago and this issue just started with update to latest 3.3RC3, and that's a bit odd to me.
Please let me know if any additional info is needed.
Thanks in advance for any help!Just to be clear: these "Responses" pop up no matter is movement is completed via web interface or if movement commands are issued from PanelDue. These cannot be seen from the web interface BTW.
Thanks for the report. We've had one other user have similar bad command errors with 3.3 RC3.
Can you show a photo of the wiring? What is the length of the cable? Can you measure the resistance of the conductors?
@bitminter the "Mtp9" is a corruption of "M409" with an additional bit converting the "40" to "tp" on each of those two characters. So it looks like the PanelDue cable is picking up interference. Does it run anywhere near a stepper motor cable?
