Script to control Wemos from gcode using DSF
I spent some time on this earlier and thought I'd share my first success with it. This script is something we used with our printers prior to moving to Duet. It is a script I wrote (based off of a bit of info scraped off the internet of Wemo's undocumented API). It interfaces with local Wemo switches, plugs, and dimmers locally without the Cloud. The only caveat is that you have to know all the IPs for your wemos.. we just made dhcp reservations for all of ours.
The script primarily turns Wemos on and off; toggles; and can set dimmer brightness. It can also return the current values as well. However, for this post, I'm going to focus on the gCode implementation I just completed.
Note this service code originally gave me trouble as it turned out "%" had to be escaped as "%%". That may be beneficial for others wanting to implement similar scripts with parameter inputs.
I chose M5555. It has 3 inputs - I, C, & B. I is the IP address of the Wemo (or potentially hostname). C is the command. B is the brightness value for setting a dimmer.
Example usage
M5555 I"192.168.0.123" C"ON" ; turns on the Wemo M5555 I"192.168.0.123" C"OFF" ; turns off the Wemo M5555 I"192.168.0.123" C"TOGGLE" ; toggles the Wemo (if off, turn on | if on, turn off) M5555 I"192.168.0.123" C"SETDIMMER" B"50" ; sets dimmer to 50%
M5555.service code
[Unit] Description=Duet API listener for Wemo control After=duetcontrolserver.service Requires=duetcontrolserver.service [Service] ExecStart=/usr/local/bin/execonmcode -mCode 5555 -command "./scripts/wemo.sh %%I %%C %%B" Restart=always RestartSec=10 [Install] WantedBy=multi-user.target
#!/bin/sh # Wemo Control # Usage: ./wemo_control IP Command # Example: ./wemo_control 192.168.0.1 ON # ON/OFF/STATE/PORT/SIGNAL/GETDIMMER/SETDIMMER IP=$1 COMMAND=$2 BRIGHT=$3 PORT=49152 if [ $IP = "" ];then echo "Invalid Command" else PORTTEST=$(curl -s $IP:$PORT | grep "404") if [ "$PORTTEST" = "" ];then PORT=49153 fi if [ $PORT = 49153 ];then PORTTEST=$(curl -s $IP:$PORT | grep "404") if [ "$PORTTEST" = "" ];then PORT=49154 fi fi if [ $PORT = 49154 ];then PORTTEST=$(curl -s $IP:$PORT | grep "404") if [ "$PORTTEST" = "" ];then PORT=49155 fi fi if [ $PORT = 49155 ];then PORTTEST=$(curl -s $IP:$PORT | grep "404") if [ "$PORTTEST" = "" ];then PORT=0 fi fi if [ $PORT = 0 ];then echo "Wemo Unavailable on IP $IP" else if [ "$COMMAND" = "STATE" ];then curl -0 -A '' -X POST -H 'Accept: ' -H 'Content-type: text/xml; charset="utf-8"' -H "SOAPACTION: \"urn:Belkin:service:basicevent:1#GetBinaryState\"" --data '<?xml version="1.0" encoding="utf-8"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetBinaryState xmlns:u="urn:Belkin:service:basicevent:1"><BinaryState>1</BinaryState></u:GetBinaryState></s:Body></s:Envelope>' -s http://$IP:$PORT/upnp/control/basicevent1 | grep "<BinaryState" | cut -d ">" -f2 | cut -d "<" -f1 | sed 's/0/OFF/g' | sed 's/1/ON/g' elif [ "$COMMAND" = "ON" ];then curl -0 -A '' -X POST -H 'Accept: ' -H 'Content-type: text/xml; charset="utf-8"' -H "SOAPACTION: \"urn:Belkin:service:basicevent:1#GetBinaryState\"" --data '<?xml version="1.0" encoding="utf-8"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetBinaryState xmlns:u="urn:Belkin:service:basicevent:1"><BinaryState>1</BinaryState></u:GetBinaryState></s:Body></s:Envelope>' -s http://$IP:$PORT/upnp/control/basicevent1 | if [ "$( grep "<BinaryState" | cut -d ">" -f2 | cut -d "<" -f1 )" = "0" ];then curl -0 -A '' -X POST -H 'Accept: ' -H 'Content-type: text/xml; charset="utf-8"' -H "SOAPACTION: \"urn:Belkin:service:basicevent:1#SetBinaryState\"" --data '<?xml version="1.0" encoding="utf-8"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:SetBinaryState xmlns:u="urn:Belkin:service:basicevent:1"><BinaryState>1</BinaryState></u:SetBinaryState></s:Body></s:Envelope>' -s http://$IP:$PORT/upnp/control/basicevent1 | grep "<BinaryState" | cut -d ">" -f2 | cut -d "<" -f1 | sed 's/0/OFF/g' | sed 's/1/ON/g' else echo "ON" #Already On fi elif [ "$COMMAND" = "OFF" ];then curl -0 -A '' -X POST -H 'Accept: ' -H 'Content-type: text/xml; charset="utf-8"' -H "SOAPACTION: \"urn:Belkin:service:basicevent:1#GetBinaryState\"" --data '<?xml version="1.0" encoding="utf-8"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetBinaryState xmlns:u="urn:Belkin:service:basicevent:1"><BinaryState>1</BinaryState></u:GetBinaryState></s:Body></s:Envelope>' -s http://$IP:$PORT/upnp/control/basicevent1 | if [ "$( grep "<BinaryState" | cut -d ">" -f2 | cut -d "<" -f1 )" = "1" ];then curl -0 -A '' -X POST -H 'Accept: ' -H 'Content-type: text/xml; charset="utf-8"' -H "SOAPACTION: \"urn:Belkin:service:basicevent:1#SetBinaryState\"" --data '<?xml version="1.0" encoding="utf-8"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:SetBinaryState xmlns:u="urn:Belkin:service:basicevent:1"><BinaryState>0</BinaryState></u:SetBinaryState></s:Body></s:Envelope>' -s http://$IP:$PORT/upnp/control/basicevent1 | grep "<BinaryState" | cut -d ">" -f2 | cut -d "<" -f1 | sed 's/0/OFF/g' | sed 's/1/ON/g' else echo "OFF" #Already Off fi elif [ "$COMMAND" = "SETDIMMER" ];then curl -0 -A '' -X POST -H 'Accept: ' -H 'Content-type: text/xml; charset="utf-8"' -H "SOAPACTION: \"urn:Belkin:service:basicevent:1#SetBinaryState\"" --data '<?xml version="1.0" encoding="utf-8"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:SetBinaryState xmlns:u="urn:Belkin:service:basicevent:1"><brightness>'$BRIGHT'</brightness></u:SetBinaryState></s:Body></s:Envelope>' -s http://$IP:$PORT/upnp/control/basicevent1 | grep "<brightness" | cut -d ">" -f2 | cut -d "<" -f1 elif [ "$COMMAND" = "GETDIMMER" ];then curl -0 -A '' -X POST -H 'Accept: ' -H 'Content-type: text/xml; charset="utf-8"' -H "SOAPACTION: \"urn:Belkin:service:basicevent:1#GetBinaryState\"" --data '<?xml version="1.0" encoding="utf-8"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetBinaryState xmlns:u="urn:Belkin:service:basicevent:1"><BinaryState>1</BinaryState></u:GetBinaryState></s:Body></s:Envelope>' -s http://$IP:$PORT/upnp/control/basicevent1 | grep "<brightness" | cut -d ">" -f2 | cut -d "<" -f1 elif [ "$COMMAND" = "TOGGLE" ];then curl -0 -A '' -X POST -H 'Accept: ' -H 'Content-type: text/xml; charset="utf-8"' -H "SOAPACTION: \"urn:Belkin:service:basicevent:1#GetBinaryState\"" --data '<?xml version="1.0" encoding="utf-8"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetBinaryState xmlns:u="urn:Belkin:service:basicevent:1"><BinaryState>1</BinaryState></u:GetBinaryState></s:Body></s:Envelope>' -s http://$IP:$PORT/upnp/control/basicevent1 | if [ "$( grep "<BinaryState" | cut -d ">" -f2 | cut -d "<" -f1 )" = "1" ];then curl -0 -A '' -X POST -H 'Accept: ' -H 'Content-type: text/xml; charset="utf-8"' -H "SOAPACTION: \"urn:Belkin:service:basicevent:1#SetBinaryState\"" --data '<?xml version="1.0" encoding="utf-8"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:SetBinaryState xmlns:u="urn:Belkin:service:basicevent:1"><BinaryState>0</BinaryState></u:SetBinaryState></s:Body></s:Envelope>' -s http://$IP:$PORT/upnp/control/basicevent1 | grep "<BinaryState" | cut -d ">" -f2 | cut -d "<" -f1 | sed 's/0/OFF/g' | sed 's/1/ON/g' | sed 's/Error/OFF/g' else curl -0 -A '' -X POST -H 'Accept: ' -H 'Content-type: text/xml; charset="utf-8"' -H "SOAPACTION: \"urn:Belkin:service:basicevent:1#SetBinaryState\"" --data '<?xml version="1.0" encoding="utf-8"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:SetBinaryState xmlns:u="urn:Belkin:service:basicevent:1"><BinaryState>1</BinaryState></u:SetBinaryState></s:Body></s:Envelope>' -s http://$IP:$PORT/upnp/control/basicevent1 | grep "<BinaryState" | cut -d ">" -f2 | cut -d "<" -f1 | sed 's/0/OFF/g' | sed 's/1/ON/g' | sed 's/Error/ON/g' fi elif [ "$COMMAND" = "SIGNAL" ];then curl -0 -A '' -X POST -H 'Accept: ' -H 'Content-type: text/xml; charset="utf-8"' -H "SOAPACTION: \"urn:Belkin:service:basicevent:1#GetSignalStrength\"" --data '<?xml version="1.0" encoding="utf-8"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetSignalStrength xmlns:u="urn:Belkin:service:basicevent:1"><GetSignalStrength>0</GetSignalStrength></u:GetSignalStrength></s:Body></s:Envelope>' -s http://$IP:$PORT/upnp/control/basicevent1 | grep "<SignalStrength" | cut -d ">" -f2 | cut -d "<" -f1 elif [ "$COMMAND" = "PORT" ];then echo "$PORT" else echo $COMMAND fi fi fi
@oozeBot I forked this from the previous SBC topic as it stands alone as something useful.
Would add that you need execonmcode installed!
Hello @oozebot
I think I understand what your script is doing, but unfortunately I have absolutely no idea what I have to change to make it work with my Shelly.
In my theory, I just want to call a web address. I don't actually need the different parameters.
It should just be turned off stupidly.I think only the web call (http://192.168.1.47/relay/0?turn=off) would have to be stored in the wemo.sh.
Unfortunately, I don't know whether I need the curl, content-type, charset etc either. i have no idea about these things -
anybody can help me with a hint
@CrazyCreator - this is untested, but all you need is something like the following. Google curl for more info.
#!/bin/sh curl -s 'http://192.168.1.47/relay/0?turn=off' > /dev/null
@crazycreator the script can go most anywhere in the file system. If you look close at the service script I provided above, youโll see we use a folder named โscriptsโ off the root.
@oozebot
Many thanks for the answer .. now I can try -
@oozebot
I could kiss you right nowIt works absolutely perfectly.
I now have a real physical switch on the printer to turn it on and off and can still switch it off automatically at the end of a print
Love it
