Duet3D PCB delta printer effector sneak preview
I had 50mm for some time, but I like the 40mm compact size, same as classic 40mm fans, but it can be put alongside the e3d for a narrow design. If you take time to search you'll find ones with more than 10CFM
A 40mm blower fan would certainly fit better than 50mm. I had ordered the 50mm, as it is what it on the Prusa i3 MK2 I have, and it does a fantastic job. If I can find a 40mm with a healthy CFM, that would certainly fit better on my T3P3 Kossel Mini.
Here's one possible contender (at 12V) - showing 9.5 CFM.
John
Thanks. Been looking for a fan like that for a while.
Not having a board, that is kinda tricky, but I think it is OK, looking at the photos.
Thanks for the measurements.I hope this helps a bit more:
@__Tony__ <–--------------------------------------
The Last missing part of the puzzle (for me anyway) I have highlighted, I need the distance from the centre of the hole to the short edge of the effector
Please accept my apologies if it's out there and I have missed it
@CaLviNx:
Tony Last missing part of the puzzle (for me anyway) I have highlighted, I need the distance from the centre of the hole to the short edge of the effector
By calculation I would say 6.64mm the long side is 66.5 and the spacing is 55 so that is 5.75mm to the corner so I reckon the calc is 5.75/cos30+ the distance you are asking for.
Doug
@CaLviNx:
You can print https://duet3d.com/wiki/Smart_effector_and_carriage_adapters_for_delta_printer#SmartEffector_SMT_Component_Clearances on a printer (plain old paper printer of course) , calculate a scale from any known size (distance for the ball stud holes for example) and measure any things you want.
Based on the known dimensions, and the schematics shown, it would be between 7.8-8mm
It's time for me to prepare wiring
so I've got a 2 wires PT100, with everything under 24v, from what I see I can use one of my 6 wire cable for Molex KK, 22AWG will do the job.
But what about the Molex Microfit, I would like to use the same cable but could I use a 22AWG for the extruder heater ? I currently have a 40w 24v cartridge, from my point of view it's OK, but I'll prefer a second advice
1.7A current is well within ampacity of 22AWG for chassis wiring. And voltage drop of 0.2V is not much of concern for the case.
My plan was to use fairly thin 8 core multicore cable for the signal connection (4 wire PT100 connection from the effector back to the Duet), and use the same cable for the heater/fan connector with 2 conductors in parallel for each of the heater wires. In the end I didn't change the heater and fan wires because they were already working well. I can't remember what gauge the conductors were, but the resistance per conductor was just under 0.1ohm per metre.
@CaLviNx:
x = 5.75 * sqrt(2) * cos(15) ~= 7.8546460717605222188914082318294
I had the dimensions worked out, I just wanted Tony's confirmation.
And suddenly a lot of non Tony's jumped in !!!!
For the cabling, I was planning on using 6 core 22awg for the heater and fan connections,
and then for the PT100 and probe connections, I have lots of stranded cat 6 that I can use. Hopefully, the probe and the PT100 won't interfere with each other? Any thoughts?
The probe and the PT100 signals don't interfere with each other. The 8-core cable I used was this http://uk.rs-online.com/web/p/multicore-industrial-cable/6604052/?sra=pstk.
David, how about crimping two wires in one Microfit pin, does it fit?
Just to be sure; So you particularly recommend against tinning only on the ends of the cables from PSU that power the board, not on the 24V (or 12V?) terminals going from the board to the heaters?
In reference to third paragraph at Wiki: Power wiring
It's best not to tin any of the wires that you are going to put into the terminal blocks. Crimp the ferrules supplied on the ends instead. It's OK to use pre-tinned copper wire because the tin coating is so thin.
In practice, tinning the ends of the heater wires before putting them in the terminal block is not so likely to cause problems, because they heat up less than for the VIN terminal block.
If you have tinned any wires before putting into the terminal blocks, tighten up the screws after every few hours of use. Eventually the solder will have moved out of the way and the screws will stop loosening.
I used 2 lengths of Stranded Cat5e UTP on mine with the heater connections using 2 pairs work fine.
Doug
Did they go up on the site and all sell out already ?
No they are on the site ready for stocks to arrive hopefully early next week
@CaLviNx:
If you wanted to ask only Tony, maybe you should email or PM him. This dimension is likely a result of other dimensions, and their tolerances. I imagine the tolerances are +/-0.1 mm, so the answer you are seeking is not a fixed value.
@CaLviNx:
Good spot
Its 8mm I will update the documentation when i get a chance.
bot yes there are tolerances to all dimensions which i have not specified in my diagrams because i have not measured them over a batch of boards.
