Toolboard v1.1 Accelerometer Orientation and Setup
i have a question about the new Toolboards.
I wanted to install the v1.1 today to test the new accelerometer.
how do i have to implement the code in my config that this orientation will work.
The VIN and Can are pointing towards the front. Mounted on the right side of my bmg like on the picture (v1.0 for example)
should it be something like this ?
only the Parameter I isnt clear for me at the momentM955 P122.0 I? S1000 R12
Regards Frederik
@dc42 Hello,
i´ve Read that guide here :
https://www.dropbox.com/s/hu2w5mk57l4zqpg/Accelerometer Orientation.pdfThis first picture match my position, only 90° turned vertical
@frederik would it the be I26 ?
@frederik one of the diagrams in that document should match your orientation exactly.
@dc42 thank you, it worked.
what could it be that my printer is loosing his PA setting at the start of a print ?
noticed it since the update to RRF 3.3RC3
; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"vcore" ; set printer name M669 K1 ; select CoreXY mode G4 S1 ; wait for Toolboard Synchronisation M569 P0.0 S1 M569 P0.1 S1 M569 P0.2 S1 M569 P0.3 S1 M569 P0.4 S1 ;M569 P0.5 S1 M569 P121.0 S1 M584 X0.1 Y0.0 Z0.2:0.3:0.4 E121.0 M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X160.80 Y160.80 Z811.00 E859.00 ; set steps per mm M566 X500.00 Y500.00 Z25.00 E2500.00 ; set maximum instantaneous speed changes (mm/min) M203 X30000.00 Y30000.00 Z2300.00 E5000.00 ; set maximum speeds (mm/min) M201 X2500.00 Y2500.00 Z75.00 E2500.00 ; set accelerations (mm/s^2) M906 X1700 Y1700 Z1500 E800 I50 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X410 Y395 Z390 S0 ; set axis maxima ; Position of Leadscrews M671 X1:215:429 Y1:429:1 S50 ;Position of Leadscrews ; Endstops M574 X1 S1 P"121.io2.in" ; configure active-high endstop for low end on X via pin 121.io2.in M574 Y2 S1 P"io0.in" ; configure active-high endstop for high end on Y via pin io0.in M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch M558 P9 C"^121.io0.in" H2.5 F140 T9000 ;R0.5 ; A10 B0 ; set Z probe type to bltouch and the dive height + speeds G31 P1000 X-28 Y-22 Z3.68 ; set Z probe trigger value, offset and trigger height ; Mesh Grid M557 X1:382 Y1:368 P5:5 ; define mesh grid (Abstand X:Y in mm - Sx:x / Punkte X:Y - Px:x) ; Volumetric Extrusion Filament Diameter (D) M200 D1.75:1.75 ; Print Monitor - Filament (N) and Nozzle diameter (D) M404 N1.75 D0.4 ; Bed Compensation Taper M376 H0 ; Height (mm) over which to taper off the bed compensation should be min 20x Times the mean error / 0 or ; Extrusion Override Factor to 90 % M221 S095 D0:1 ; Axis Skew Compensation ;M556 S100 X0.7 Y-0.2 Z0.6 ; Ringing Frequenz M593 F46.51 ;62.24 46.51 55.86 40.5 40 ; F-Freuenz P-Type 0_none 1_ZVD 2_ZVDD 3_EI2 4_DAA S-DampingFactor_ default 0.2 ; Duet Laser Filament Monitor M591 D0 P5 C"121.io1.in" R20:185 E5.0 A0 S0 ; Extruder0 Tolerance 20 to 150%, 5mm comparison length, diabled ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out7" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S200 ; set temperature limit for heater 0 to 160C M308 S1 P"121.temp0" Y"pt1000" ; configure sensor 1 as PT1000 on pin 121.temp0 M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M141 H1 M143 H1 S275 ; set temperature limit for heater 1 to 500C M308 S2 P"temp2" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin temp1 M950 H2 C"out8" T2 ; create chamber heater output on out2 and map it to sensor 2 M307 H2 B0 S1.00 ; disable bang-bang mode for the chamber heater and set PWM limit M141 H2 ; map chamber to heater 2 M143 H2 S125 ; set temperature limit for heater 2 to 120C M308 S3 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin temp1 ;M950 H3 C" ;M141 H3 ; PID Parameters Bed for 100°C M307 H0 R0.680 C321.3 D2.40 S1.00 V24.1 ; PID Parameters Nozzle for 225°C M307 H1 B0 R2.391 C190.9:158.3 D7.17 S1.00 V22.4 ; PID Parameters for ChamberHeater 50°C M307 H2 R0.211 C426.7 D40.54 S1.00 V24.1 ; Fans M950 F0 C"121.out2" Q500 ; create fan 0 on pin 121.out2 and set its frequency M106 P0 C"Mosquito" S100 H1 T45 ; set fan 0 name and value. Thermostatic control is turned on M950 F1 C"121.out1" Q500 ; create fan 1 on pin 121.out1 and set its frequency M106 P1 C"Bauteil" S0 H-1 ; set fan 1 name and value. Thermostatic control is turned off ; Air Pump Control on SSR_3 M950 F2 C"out9" Q500 ; create fan 1 on pin 121.out1 and set its frequency M106 P2 C"Druckluft" S0 H-1 ; set fan 1 name and value. Thermostatic control is turned off ;Led Beleuchtung ; Zone 1 M950 F3 C"out2" Q500 ; create a output for led zone1 on out3 M106 P3 C"LED_1" S0.1 ; set output default to on ; Zone 2 M950 F4 C"out3" Q500 ; create a fan output for led zone2 on out4 M106 P4 C"Ausgang 3" S0 ; set output default to off ; Toolboard Buttons ;button0 LC1.121 ;M950 J4 C"121.button0" ; Input 4 uses io4 pin, inverted ;M581 P4 S1 C0 T2 R0 ; configure button for LED ON ; button1 LC1.121 ;M950 J5 C"121.button1" ; Input 5 uses io5 pin, inverted ;M581 P5 S1 C0 T3 R0 ; configure push button for LED OFF ; Tools M563 P0 S"Mosquito" D0 H1 F0:1 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M207 S0.6 F2400 Z0.00 ; FW Retraction Mosquito (S)-Retraction Dist. (F) Speed , (Z) ZHopHeight ; BMG Pressure Advance M572 D0 S0.050 ; Miscellaneous M501 ; load saved parameters from non-volatile memory M912 P0 S-15.8 ; MCU Temperature Calibration M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss T0 ; select first tool
@frederik what does M572 D0 report immediately before starting the print?
What does M572 D0 report if you start the print, wait for actual printing to start, and then send M572 D0?
@dc42 when i observed today correct, then it reportet before the print and after a initial power up the correct value of 0.050. At that Time the M572 was in line 43.
After starting the Print the extruder 0 showed 0.000 and the extruder 2 the correct value of 0.050
after manual triggering the command wiht 0.050 over the console again, it worked during the print. will test at the evening what happens when i restart a print without restarting the printer.
in my cura startcode is nothing except 3 lines for priming the extruder , nothing else
using firmware retractionthere i noticed that sometimes the retraction speed is at 1mm/s after a printer restart, even if the config setting is 2400mm/min.
at the moment a 6 hour print is running. after that i could start testing again
in cura are no Printer settings regarding the motion control like jerk, acceleration or linear advance. only priming and FW retract
@frederik your value based on the picture should be I06
@nuramori Thanks , i will try it with this values:
P121.0 I06 S1000 R12
Today i had a little bit time to investigate further with the PA Settings Problem.After a reboot, the Printer shows the right value of 0.050 after sending M572 D0 over the console.
When starting a print in Cura 4.9.1 , i send the M572 D0 again and get a Value of 0.000 ???
Now i switched the PA command back up to Line 61 and will try how it behaves at the next small print.
config g at the moment:
; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"vcore" ; set printer name M669 K1 ; select CoreXY mode G4 S1 ; wait for Toolboard Synchronisation M569 P0.0 S1 M569 P0.1 S1 M569 P0.2 S1 M569 P0.3 S1 M569 P0.4 S1 M569 P121.0 S1 M584 X0.1 Y0.0 Z0.2:0.3:0.4 E121.0 M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X160.80 Y160.80 Z811.00 E859.00 ; set steps per mm M566 X500.00 Y500.00 Z25.00 E1500.00 ; set maximum instantaneous speed changes (mm/min) M203 X30000.00 Y30000.00 Z2300.00 E5000.00 ; set maximum speeds (mm/min) M201 X2500.00 Y2500.00 Z75.00 E2500.00 ; set accelerations (mm/s^2) M906 X1700 Y1700 Z1500 E800 I50 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X410 Y395 Z390 S0 ; set axis maxima ; Endstops M574 X1 S1 P"121.io2.in" ; configure active-high endstop for low end on X via pin 121.io2.in M574 Y2 S1 P"io0.in" ; configure active-high endstop for high end on Y via pin io0.in M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch M558 P9 C"^121.io0.in" H2.5 F140 T9000 ;R0.5 ; A10 B0 ; set Z probe type to bltouch and the dive height + speeds G31 P1000 X-28 Y-22 Z3.68 ; set Z probe trigger value, offset and trigger height ; Position of Leadscrews M671 X1:215:429 Y1:429:1 S50 ;Position of Leadscrews ; Mesh Grid M557 X1:382 Y1:368 P12:12 ; define mesh grid (Abstand X:Y in mm - Sx:x / Punkte X:Y - Px:x) ; Volumetric Extrusion Filament Diameter (D) M200 D1.75 ; Print Monitor - Filament (N) and Nozzle diameter (D) M404 N1.75 D0.4 ; Bed Compensation Taper M376 H0 ; Height (mm) over which to taper off the bed compensation should be min 20x Times the mean error / 0 or ; Extrusion Override Factor to 90 % M221 D0 S95 ; BMG Pressure Advance M572 D0 S0.045 ; Axis Skew Compensation ;M556 S100 X0.7 Y-0.2 Z0.6 ;Accelerometer Board- Orientation - sample frequenz in Hz - Resolution 8,10,12 M955 P121.0 I06 S1000 R12 ; Ringing Frequenz M593 F46.51 ;62.24 46.51 55.86 40.5 40 ; F-Freuenz P-Type 0_none 1_ZVD 2_ZVDD 3_EI2 4_DAA S-DampingFactor_ default 0.2 ; Duet Laser Filament Monitor M591 D0 P5 C"121.io1.in" R20:185 E5.0 A0 S0 ; Extruder0 Tolerance 20 to 150%, 5mm comparison length, diabled ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out7" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S200 ; set temperature limit for heater 0 to 160C M308 S1 P"121.temp0" Y"pt1000" ; configure sensor 1 as PT1000 on pin 121.temp0 M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M141 H1 M143 H1 S275 ; set temperature limit for heater 1 to 500C M308 S2 P"temp2" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin temp1 M950 H2 C"out8" T2 ; create chamber heater output on out2 and map it to sensor 2 M307 H2 B0 S1.00 ; disable bang-bang mode for the chamber heater and set PWM limit M141 H2 ; map chamber to heater 2 M143 H2 S125 ; set temperature limit for heater 2 to 120C M308 S3 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin temp1 ;M950 H3 ;M141 H3 ; PID Parameters Bed for 100°C M307 H0 R0.680 C321.3 D2.40 S1.00 V24.1 ; PID Parameters Nozzle for 225°C M307 H1 B0 R2.391 C190.9:158.3 D7.17 S1.00 V22.4 ; PID Parameters for ChamberHeater 50°C M307 H2 R0.211 C426.7 D40.54 S1.00 V24.1 ; Fans M950 F0 C"121.out2" Q500 ; create fan 0 on pin 121.out2 and set its frequency M106 P0 C"Mosquito" S100 H1 T45 ; set fan 0 name and value. Thermostatic control is turned on M950 F1 C"121.out1" Q500 ; create fan 1 on pin 121.out1 and set its frequency M106 P1 C"Bauteil" S0 H-1 ; set fan 1 name and value. Thermostatic control is turned off ; Air Pump Control on SSR_3 M950 F2 C"out9" Q500 ; create fan 1 on pin 121.out1 and set its frequency M106 P2 C"Druckluft" S0 H-1 ; set fan 1 name and value. Thermostatic control is turned off ;Led Beleuchtung ; Zone 1 M950 F3 C"out2" Q500 ; create a output for led zone1 on out3 M106 P3 C"LED_1" S0.1 ; set output default to on ; Zone 2 M950 F4 C"out3" Q500 ; create a fan output for led zone2 on out4 M106 P4 C"Ausgang 3" S0 ; set output default to off ; Toolboard Buttons ;button0 LC1.121 ;M950 J4 C"121.button0" ; Input 4 uses io4 pin, inverted ;M581 P4 S1 C0 T2 R0 ; configure button for LED ON ; button1 LC1.121 ;M950 J5 C"121.button1" ; Input 5 uses io5 pin, inverted ;M581 P5 S1 C0 T3 R0 ; configure push button for LED OFF ; Tools T0 M563 P0 S"Mosquito" D0 H1 F1 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M207 S0.65 F2400 Z0.00 ; FW Retraction Mosquito S-Dist F-Speed Z-HHeight ;M572 D0 S0.065 M501 ; load saved parameters from non-volatile memory M912 P0 S-15.8 ; MCU Temperature Calibration M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set params for PowerLoss
M122 and M122 B122 after rebooting and Homing the board:
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.3RC3 (2021-05-26 12:29:42) running on Duet 3 MB6HC v1.01 or later (SBC mode) Board ID: 08DJM-956BA-NA3TN-6J9DL-3S46S-99AUT Used output buffers: 4 of 40 (11 max) === RTOS === Static ram: 150784 Dynamic ram: 62736 of which 12 recycled Never used RAM 140660, free system stack 126 words Tasks: SBC(ready,6.7%,298) HEAT(delaying,0.0%,295) Move(notifyWait,0.0%,266) CanReceiv(notifyWait,0.0%,773) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,8.1%,59) MAIN(running,85.0%,922) IDLE(ready,0.1%,29), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:03:30 ago, cause: software Last software reset at 2021-06-02 21:27, reason: User, none spinning, available RAM 140660, slot 2 Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 Step timer max interval 132 MCU temperature: min 38.2, current 38.4, max 54.7 Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0 Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Driver 0: position 69144, standstill, reads 52829, writes 23 timeouts 0, SG min/max 0/235 Driver 1: position 60461, standstill, reads 52829, writes 23 timeouts 0, SG min/max 0/242 Driver 2: position 5012, standstill, reads 52829, writes 23 timeouts 0, SG min/max 0/128 Driver 3: position 0, standstill, reads 52829, writes 23 timeouts 0, SG min/max 0/132 Driver 4: position 0, standstill, reads 52829, writes 23 timeouts 0, SG min/max 0/126 Driver 5: position 0, standstill, reads 52842, writes 11 timeouts 0, SG min/max 0/0 Date/time: 2021-06-02 21:31:10 Slowest loop: 174.76ms; fastest: 0.03ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, maxWait 65943ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 39, completed moves 39, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 3], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 2 -1 -1 -1 Heater 0 is on, I-accum = 0.3 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Filament sensors === Extruder 0: no data received === CAN === Messages queued 1953, send timeouts 0, received 2731, lost 0, longest wait 2ms for reply type 6048, peak Tx sync delay 206, free buffers 49 (min 48), ts 1052/1051/0 === SBC interface === State: 4, failed transfers: 0 Last transfer: 3ms ago RX/TX seq numbers: 7616/7616 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x2c8bc Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.3-rc3 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 36.71 Codes per second: 0.87 Maximum length of RX/TX data transfers: 4192/888 6/2/2021, 9:30:49 PM M572 Extruder pressure advance: 0.045
M122 B121 Diagnostics for board 121: Duet TOOL1LC firmware version 3.3RC3 (2021-05-26 12:30:20) Bootloader ID: SAMC21 bootloader version 2.2 (2021-01-16b1) Never used RAM 3164, free system stack 2743 words Tasks: Move(notifyWait,1.4%,91) HEAT(delaying,3.5%,99) CanAsync(notifyWait,0.0%,55) CanRecv(notifyWait,0.5%,75) CanClock(notifyWait,0.5%,66) TMC(notifyWait,73.1%,57) MAIN(running,306.3%,343) IDLE(ready,0.0%,40) AIN(delaying,126.9%,142), total 512.1% Last reset 09:55:49 ago, cause: power up Last software reset time unknown, reason: AssertionFailed, available RAM 4592, slot 1 Software reset code 0x0120 ICSR 0x00000000 SP 0x20003cac Task Freestk 130 bad marker Stack: 00000544 00023174 00019cb5 20003044 00016e33 20003044 00016505 20000ed0 00000000 00000001 0000828d 200071c8 200071c8 200071e0 00000000 20000f50 000116b3 00022530 000225e8 00021c40 00019c55 200071c8 200071c8 20000f50 00008405 200071d8 000009c6 Driver 0: position 2749860, 859.0 steps/mm, standstill, SG min/max 0/496, read errors 0, write errors 0, ifcnt 35, reads 41677, writes 35, timeouts 0, DMA errors 0, steps req 6992002 done 6992002 Moves scheduled 43088, completed 43088, in progress 0, hiccups 0, step errors 0, maxPrep 788, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0 Peak sync jitter 0/6, peak Rx sync delay 240, resyncs 0/4, no step interrupt scheduled VIN: 24.1V MCU temperature: min 19.9C, current 63.7C, max 91.8C Ticks since heat task active 214, ADC conversions started 35621485, completed 35621484, timed out 0, errs 0 Last sensors broadcast 0x00000002 found 1 219 ticks ago, loop time 0 CAN messages queued 448969, send timeouts 0, received 366694, lost 0, free buffers 37, min 35, error reg 440000 dup 0, oos 0/0/0/0, bm 0, wbm 0 Accelerometer detected: no I2C bus errors 4481, naks 4481, other errors 4481 === Filament sensors === Interrupt 5726621 to 0us, poll 8 to 3604us Driver 0: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
The same M122 right now after starting the Print:
@frederik please share the Cura-generated print file.
UniversalFace_with FW Retraction.gcode
UniversalFace_without FW Retraction.gcode
it is the same base STL only the checkbox FW Retraction is enabled or disabled
@dc42 I think i foäund the Problem, i didnt even know that there was a seperate plugin installed calle Linear Advance Feature. The checkbox was hidden under the Material Tab
I deinstalled the plugin and slice the file again to check if the Value will be overwritten again
@frederik Glad you found it.
M572 S0.000000 D0 ;added by LinearAdvanceSettingPlugin
@phaedrux Yeah, as i saw that line i was a little bit shocked, because as i switched to FW Retract, i double checked every settings in the Printer Settings Menu, and was happy that it worked, but musst have overlooked that Line
You did a really nice Job with that Guide, thanks for that. Is that your Printer in the Pictures ?
What is that for a design ? your own or something publicly available ?Kindly Regards
Frederik -
@phaedrux i dont know if it is worth to open a new thread for this:
Is it possible with the Toolboard v1.1 , that i can programm the 2 buttons on the front for different actions like:
Button 1 Extrude
Button 2 RetractButton 1 heater output 2 on/off
Button 2 heater output 3 on/offButton 1 call makro 1.g (load Filamaent)
Button 2 call makro 2.g (unload)only for example purposes
Power Distribution on the V1.1
I would like to test a inductive Probe on my flexsteel plates that would need 24V (VIN) , because i slowly getting problems with deformed probing pins because of the temps when printing PC at 120°C bed and 70°C chamber
it is a Normal Open switching on.
how should i wire it to the IOs ?
could i get the + from VIN and only use the signal wire / - for the trigger ?TIA Frederik
@frederik you may consider Pinda probe , it is 5 v
@frederik that’s my printer. It originally started out as a BLV cube, but I’ve done many modifications even from the onset, with blind joints and structural improvements. The extruder is my own design, as is the triple independent z axis implementation. Quite of a few aspects of it are shared, especially the extruder design on GitHub.
@nuramori thansk for the answer looking good
is that a mosquito aqua in combination with a orbiter ? a few people use also the combination from mosquito air and the orbiter on the EVA Carriage System. They work really well. Do you also use a single 120mm radiator with fan for you cooling loop ? i´m thinking what would the best way to integrate the Extruder STepper Motor and Toolboard somehow to the cooling loop. Printing the most Time at around 75°C in the chamber PC , Abs or Abs-PC Parts. Until now i didnt get any Errors or Warnings regarding the temps. Im real curious how long they will last
