3D Printer Connectors - What's best for in-line connections?
@zapta said in [3D Printer Connectors - What's best for in-line connections?](/post
Apropos connectors, WhamBam came recently with an interesting 3D printer gantry connector system https://whambamsystems.com/mutant
Shame they can't design a belt drive correctly...
I know this is an old topic but I have a relevant update:
I started with Dupont style connections for the hot end heater for my 12V based printer. That caused all kinds of grief fairly quickly due to overheating of the connector (40W heater). I then went to a JST style interlocking connector. That worked for a while but is again causing failures due to overheating of the connector.
Up to now, these connectors where sourced from China .... and are costing me way more in frustration and spoiled prints than they are worth.My next and hopefully final connector style will be a genuine Molex Microfit 3.0 connection system sourced from Digikey. I just had a print abort after about 4 hours of printing and it just isn't worth the pain and suffering any more.
Even at ten times the price of the China product, it's worth it if it fixes this mess! -
@jens55
dc42 also suggested to use the MicroFit 3.0, but I couldn't find a reseller (accepting paypal) with all the required parts in Stock. I guess, the German/EU components-market is empty, due to the well known issues. (and the supercontainership blocking Suez-channel forever) -
@o_lampe All my printers use Microfit 3.
In the UK I can get them from CPC, Farnell and if I have a big enough order Mouser.I use DuPont for things like accelerator where it is not a permanent fixture.
@o_lampe
Reichelt.... -
@o_lampe said in 3D Printer Connectors - What's best for in-line connections?:
... supercontainership blocking Suez-channel forever
Now it's the canal that blocks the ship
https://www.youtube.com/watch?v=FESrIXpsQJc
There is a general shortage of electronic components to a point that car manufacturer dropped features or stopped production because they can't get the chips they need.
https://www.youtube.com/results?search_query=car+chip+shortage
Did it affected Duet3D in any way?
@jens55
dc42 also suggested to use the MicroFit 3.0, but I couldn't find a reseller (accepting paypal) with all the required parts in Stock. I guess, the German/EU components-market is empty, due to the well known issues. (and the supercontainership blocking Suez-channel forever)There appear to be plenty on eBay. https://www.ebay.de/sch/i.html?_nkw=molex+microfit
That's where I was looking. The problem was the crimp connectors for both housings. I'd have had to buy from here and there to scratch everything together. -
Hi All,
I've been thinking about these for allowing me to make my printer more modular. A single connection to the radial axis that holds both the radial and extruder motors and all of the hot end connections. That way I could remove it for transportation, assuming I created locating features for easy realignment.I use an SSR for the hotend heater cartridge so power could be run separately if the connector isn't up to it, although the listing does suggest high power capacity but i haven't found a comprehensive data sheet yet.
Any thoughts?
Cheers
Barry M -
@cncmodeller
Those AMP connectors are huge compared to MicroFit. Doesn't matter, if they don't sit in the cable-chain. -
That's where I was looking. The problem was the crimp connectors for both housings. I'd have had to buy from here and there to scratch everything together.Have you tried https://de.farnell.com/search?st=molex microfit ?
@o_lampe yeah they were intended as a single bulkhead connection mounted on the structure of my radial axis assembly.
