3950 1% pullup thermistor is built-in ?
The Silicone heater bed I'm looking at says :- "3950 1% pullup thermistor is built-in"
Can't see that in the configurator type so any clues to how I would set it up ? -
Try the default first and see if it gives an accurate temp.
Do you have any other info on the bed heater or thermistor? -
@peter247 use T100000 B3950 C0 in your M308 command for the bed heater.
