problems with M280 P0 when heated bed active
@apak as a test can you try using bang bang mode on the heated bed to see if it is actually the PWM signal (and not, for example a power supply related issue).
@t3p3tony already tryed, also changing pwm frequency
@apak what was the result of using bang bang?
@t3p3tony same
@apak how are you powering the Duet and the Arduino? Where are the grounds connected together?My guess is that it is a ground noise issue.
@apak if its the same with bang bang then its not PWM related. What is the difference when the bed heater is on with bang bang and off?
@t3p3tony but only happens with the bed, not with the hotend¿?¿?
@apak said in problems with M280 P0 when heated bed active:
should I connect grond from the 24PSU to the 5V psu???
Yes, then the two systems are on the same potential.
Looks to me that they are already connected, through the black wire between the Arduino and the Duet.
@dc42 actually there is one wire from 5vPSU GND to arduino and another from duet exp.gnd to arduino..
