HELP! Duet 2 WiFi Configuration and DWC Upload???
your homez will only work correctly after X and Y have been homed first. Are you still using M564 to allow unhomed movement?
Not during that test
Just tested it after homing X and Y and other that the probe deploying we're all good. Isn't it supposed to not deploy so that Z can hit 0 so the nozzle is almost touching the bed?
Ok fixed that. I had Z set to 10 rather than zero. Ok homeall.g and homez.g are working
So I'm trying to level the bed the best I can before I do the height map, but every time I trigger the BLTouch with G30 S-1, although it gives me the Z reading I need it just continues to blink red and I'm having to turn off my printer and turn it back on to get the BLTouch to reset so I can do another Z test. Is there anyway to reset the BLTouch without having to reboot the printer?
Ended up just rebooting the printer like a million times haha. Next I entered the values to define mesh size and spacing. Afterwards I got this error when I went to command the probe
Here are the values I entered
Here are my Homed location values
Not sure what's missing/what I'm doing wrong
Thanks,
-Carson
@pcnoobneedsmajorhelp said in HELP! Duet 2 WiFi Configuration and DWC Upload???:
Yes there is. Check the BLtouch manual for your version for the reset command.
https://www.antclabs.com/manual
Likely
M280 P3 S160 I1
in your case. -
I don't have a DueX board
Important: In the M280 commands in the following, leave out the I1 parameter if the BLTouch is connected to a servo output on a DueX board.
and I'm running RepRap 2.05
so you're saying to leave out the I1
correct?
Thanks,
-Carson
correct?What? No. Where do you think I'm saying that?
All the M280 commands that need to be changed are only in the deploy and retract files, right?
Your M557 command is invalid. I think it's because you have the max and min values reversed.
I don't know, that's why I asked. all you said was
Likely M280 P3 S160 I1 in your case.
and I was asking about the mesh bed
I thought the link was referring to the reset and the command was referring to why my Probing for the height map wasn't working
I hadn't seen that post yet. I was replying to the question about resetting the bltouch without rebooting.
I have them reversed because when my X and Y are homed, their "0" values are actually 229.5 and 231.1
Ah, got it.
The firmware doesn't see if that way. It just wants the minimum extent and the maximum extent.
Please send M98 P"config.g" and see if it complain about it. Or just copy and paste your M557 line into the gcode console and see if it complains.
There you go. Flip your values for X and Y and try again.
It seems to not be going all the way to the left and way too far to the right
