HELP! Duet 2 WiFi Configuration and DWC Upload???
So when I try to disable the axis limits, I can control them by the DWC but they aren't actually disabled because I cant move the printer head will my hand freely, as if the motors are still engaged.
I figured out my X and Y probe offsets for G31. I read somewhere that the heater cartridge could possibly interfere with the BLTouch. Would that happen with the distance that the probe is at, for me?
Do my homeall.g and homez.g look? good?
Here are my DeployProbe and RetractProbe files
Code
Code
Should I delete the deploy probe and retract files from the macros folder?
Thanks,
-Carson
@pcnoobneedsmajorhelp said in HELP! Duet 2 WiFi Configuration and DWC Upload???:
Well yes, M564 won't disable the motors, it just lets you command the motors with the jog buttons even though you haven't homed yet.
It looks like you're missing the .g file extension on your deploy and retract files.
What is the .g file extension?
Oh never mind I know what your saying. Everything else looks good though right?
Now I move onto mesh bed compensation, right?
Success. M401 and M402 work when commanded
Before you can get on to mesh compensation you'll need to confirm that G30 is working as intended and that homeall/homez are working. Then yes, you can move on to mesh compensation.
homez.g is crashing on the X and Y axis and then when the bed hits the probe the goes down about 1mm before the X and Y crash again into the back right corner
not sure what to do?
Maybe remove X and Y positions in the G1 command?
your homez will only work correctly after X and Y have been homed first. Are you still using M564 to allow unhomed movement?
Not during that test
Just tested it after homing X and Y and other that the probe deploying we're all good. Isn't it supposed to not deploy so that Z can hit 0 so the nozzle is almost touching the bed?
Ok fixed that. I had Z set to 10 rather than zero. Ok homeall.g and homez.g are working
So I'm trying to level the bed the best I can before I do the height map, but every time I trigger the BLTouch with G30 S-1, although it gives me the Z reading I need it just continues to blink red and I'm having to turn off my printer and turn it back on to get the BLTouch to reset so I can do another Z test. Is there anyway to reset the BLTouch without having to reboot the printer?
Ended up just rebooting the printer like a million times haha. Next I entered the values to define mesh size and spacing. Afterwards I got this error when I went to command the probe
Here are the values I entered
Here are my Homed location values
Not sure what's missing/what I'm doing wrong
Thanks,
-Carson
Yes there is. Check the BLtouch manual for your version for the reset command.
https://www.antclabs.com/manual
Likely
M280 P3 S160 I1
in your case. -
I don't have a DueX board
Important: In the M280 commands in the following, leave out the I1 parameter if the BLTouch is connected to a servo output on a DueX board.
and I'm running RepRap 2.05
so you're saying to leave out the I1
correct?
Thanks,
-Carson
correct?What? No. Where do you think I'm saying that?
All the M280 commands that need to be changed are only in the deploy and retract files, right?
Your M557 command is invalid. I think it's because you have the max and min values reversed.
I don't know, that's why I asked. all you said was
Likely M280 P3 S160 I1 in your case.
and I was asking about the mesh bed
I thought the link was referring to the reset and the command was referring to why my Probing for the height map wasn't working
I hadn't seen that post yet. I was replying to the question about resetting the bltouch without rebooting.
