HELP! Duet 2 WiFi Configuration and DWC Upload???
@pcnoobneedsmajorhelp said in HELP! Duet 2 WiFi Configuration and DWC Upload???:
Is there anyway to reset the BLTouch without having to reboot the printer?
Yes there is. Check the BLtouch manual for your version for the reset command.
https://www.antclabs.com/manual
Likely
M280 P3 S160 I1
in your case. -
I don't have a DueX board
Important: In the M280 commands in the following, leave out the I1 parameter if the BLTouch is connected to a servo output on a DueX board.
and I'm running RepRap 2.05
so you're saying to leave out the I1
correct?
Thanks,
-Carson
correct?What? No. Where do you think I'm saying that?
All the M280 commands that need to be changed are only in the deploy and retract files, right?
Not sure what's missing/what I'm doing wrong
Your M557 command is invalid. I think it's because you have the max and min values reversed.
I don't know, that's why I asked. all you said was
Likely M280 P3 S160 I1 in your case.
and I was asking about the mesh bed
I thought the link was referring to the reset and the command was referring to why my Probing for the height map wasn't working
I hadn't seen that post yet. I was replying to the question about resetting the bltouch without rebooting.
I have them reversed because when my X and Y are homed, their "0" values are actually 229.5 and 231.1
Ah, got it.
The firmware doesn't see if that way. It just wants the minimum extent and the maximum extent.
Please send M98 P"config.g" and see if it complain about it. Or just copy and paste your M557 line into the gcode console and see if it complains.
There you go. Flip your values for X and Y and try again.
It seems to not be going all the way to the left and way too far to the right
Should I add (-) somewhere idk I'm just guessing
How did you measure the XY offset of the probe from the nozzle?
Keep that offset in mind when you set the M557 range. If you try and probe a point that it can't reach because of the offset it will give you that error.
You can also just use a full zero to max range for M557 and just let it skip the points it can't reach. Other than the warnings popping up it will still generate a heightmap for the area that it can reach.
After a couple hours of tuning I got this height map. Do you think its good enough, or should i keep adjusting the bed and do another height map?
This was done with my heaters on
And this was the one I did with the heaters off
Thanks,
-Carson
Those look pretty good actually. If you want to test the effectiveness of the mesh compensation try printing something like this
Ok. I can print that now, right? So, like no more setting up the mesh compensation, or saving it to the SD Card?
What is the Z=0 datum for? Is that just if I want to use a different height map?
Before I checked my points with the probe, I would home Z and then bring the bed down 6.5mm and command the probe. Is that the Z datum? Z at 0 or at 6.5?The only other thing on the Mesh Bed Compensation page is Compensation Taper. Do I need to mess with that at all, or no?
I found this a while back. Does it apply to me? or is it the same thing I'm doing currently?
https://duet3d.dozuki.com/Wiki/Setting_up_automatic_probing_of_the_print_bed
Thanks,
-Carson
