How precise is Haydn diagonal rods when assembled
I would like to point out that ball studs are not ideal. They can have the difference in their diameters as much as 0.1mm that was in my case. Specified length of my rods are matched to within 0.02mm. But I suppose that length is calculated value for the nominal diameter of the balls. Combining the rods with the ball I get discrepancy in the length of final assemblies.
Yeah Doug is spot on to say 0.1mm is definitely not good. You can get away with that if its a difference between one arm pair and another. But it will show up as an obvious inaccuracy if its within one arm pair.
If you know the ball diameters (and they are actually spherical) and you know the rod lengths, I'd be very keen to see the effect of matching them precisely to get exactly the same arm lengths all around to 0.01mm precision.
Real world difference in your prints - zero! But it will be satisfying in the quest for perfection.
I no longer have the lengths marked on my arms, I foolishly removed the stickers. Does anyone know a clever way to measure them? I have 300mm calipers?
you will need 2 3/8 inch Diam ball bearings, you measure one of them and zero you callipers at that point (Ie 3/8 inches) then attach the balls one at each end of the rod and measure it you now have the true length of that rod repeat for all of them.
Doug.
I also have 300 mm callipers but could do with some 500 mm ones I could then verify my home assembled arms?
Thanks Doug that makes sense but I have 360mm arms and 300mm calipers, so what I wondered is whether there is a trick to measure something that is longer than the calipers? I could use the metal rod that protrudes from the caliper, but how to measure to high accuracy like this I don't know.
I really have 3 balls that deviate as much as 0.1mm from the rest of set so I will get one pair imperfect anyway. Hope another twelve ball studs will solve the problem.
As we are interested onley in rod length differences I think you can butt (sorry if it not right verb in English) one end of a rod into something hard and take measurement using the arm of calipers on another end of the rod and the end of the depth measuring stick on the other side. You get a virtual size of rods but their differences will be real.
Where are you based? I have 24 balls in total. If I get chance I measure them and work out which 12 I need, I will let you know what sizes the remaining 12 are and we can swap if you like? Depends on where you are based.
As for measuring technique it might work but be trusted to be accurate to 0.01mm? I'm not so sure.
Maybe 500mm calipers might have to be on the Christmas list.
You couldn't unfortunately. Do you know any friendly engineering companies that may loan you a 350-375mm micrometer for a day
another way is that you could make a jig with a bit of timber (OR extrusion if your quick) set an end block up fixed at one end then a sliding but fixable block at the other locate an arm adjust the slider for a good fit. then using another block of say 100mm long in the gap measure with the inside jaws of your callipers add in the block length (Having first calibrated your callipers to allow for one ball) and you will have your rod length. -
I will have to get my 25mm micrometer out and start checking my balls now I have 18 extras.
Its always recommended to check your balls from time to time (sorry I couldn't resist).
I do have a friendly engineering company nearby so I might pursue that option.
Thank you for your kind offer but afraid it is impossible. I am in Russia.
Regarding to the measuring technique if you can make a simple jig I think it gives the same result as direct measuring with calipers assuming this is made accurately. You can't just get absolute value of the length but it is not relevant for the case. -
I have these parts in three of my printers.
The bed calibration was spot on and and they print just fine.
You may have nothing to worry about.
Thank you for your response. Maybe 0.1mm is not a big difference indeed for Delta. But I am apt to get another set of ball studs. Anyway they can be used for making other heads, laser graver for example.
Okay so I checked my balls (sorry)
Of the 6 spare ones I have not attached to a running printer
9.38mm x1
9.40mm x2
9.48mm x1
9.50mm x2I will check the other 12 that are currently deployed whenever I get chance, and then get the arms measured accurately, and see if a "perfect" combination can be found.
Haydn had these parts made - given his attention to detail I would not think he would be selling parts that did not perform as intended.
Ask him if you have doubts.
9.38mm x1
9.40mm x2
9.48mm x1
I'll raise this with Haydn - looks like he may be making the arms to significantly closer tolerances than his supplier makes the ball studs.
Hi Frederick,
I know they work and I know Haydn puts in a lot of effort to make the arms very precise.
But the balls are not that precise.
Personally I consider this an opportunity to match balls to arms to get even more precision.
I know he bought 1000 or so of the ball studs in a job lot. All he has to do if he can supply 6 rods exactly the same length is supply 12 balls of the same diameter. But since the rods will vary by up to 0.05mm maybe he would be willing to tape two balls to each rod to equalise the total length.
Simon.
9.38mm x1
9.40mm x2
9.48mm x1
Sure as I said earlier it's very marginal, and I suspect it will have almost no practical consequences, but then we go to extreme lengths for precision so measure your balls people!
Come to think of it, is it diameter we need to be measuring alone, or distance from the mounting face of the ball stud to the end of the ball?
Well IMHO what we should really be measuring is probably not possible without Laboratory equipment and that is the distance from the rotational centre of the ball and the mating face to the rod end spherically God knows how you would do that tho.
Doug
