Need help to config this probe
@tecno only probe types 8 and 9 are supported on toolboard. Use type 8 for IR probe. See https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Mini_differential_IR_sensor_by_dc42
Also, don’t think you need to invert probe with ! (exclamation mark). And connect to 3.3, not 5V. See https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board
OK done that but still G30 error
I can not find anything in gcode files to be edited. From where comes Z probe 0 ?
Anything missing in my config.g ?Cheers Bengt
@tecno have you tried, M280 P0 S10 ; deploy BLTouch and M280 P0 S90 ; retract BLTouch
Have you got a deployprobe.g and a retractprobe.g ? -
This IR Probe fixed nothing moving here
@tecno you set the probe number with the K parameter in M558. If undefined it defaults to probe 0.
Tried K0 K1 K2 still the same error
@tecno please post your current config.g, response to M122, and check your toolboard firmware version matches your mainboard version. And show a picture of your wiring.
probe works running home all but I can not calibrate
@tecno Please send
M122 B121
, post your homeall.g, and if possible post pictures of the IR probe wiring on the Toolboard.In your config.g:
M584 X2 Y1 Z3:4 E0 ; set drive mapping
You aren't using the toolboard extruder?
M574 X1 S1 P"!^121.io2.in" ; configure active-high endstop for low end on X via pin ^io3.in M574 Y1 S1 P"!^io0.in" ; configure active-high endstop for low end on Y via pin ^io0.in M574 Z1 S1 P"!!121.io1.in"
You don't need to enable pullup resistors (with ^ character) on X and Y, only Duet 2 using 'probe.in' need it.
On Z, this may be conflicting with the probe, change this toM574 Z0 S2
. This may cause your Z homing not to work, depending on how homeall.g and homez.g are configured. I expect these are not using G30 to home at the moment.; Z-Probe M558 C"121.io1.in" P8 H3 K2 F120 T6000 ; G31 P50
Use
K0
or leave the K parameter out entirely. If you really want to set the probe number, and set it to K2, then useG30 K2
when probing.M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 ... M308 S1 P"121.temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
You're using the RRF configuration tool's default thermistor. Find out what thermistors you actually have and update these lines for more accurate temperature readings.
Good morning Ian,
I am not using the toolboard extruder, bowden to get as light printhead as possible on my Chiron.Made the changes to M574, not working on Z lifts up Z and error Homing failed
M558 no K
M308 both work but how accurate Bed is Anycubic original and Hotend I do belive this is E3DV6 sold by them.
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat May 01 2021 17:31:12 GMT-0700 (Pacific Daylight Time)
G91 ; relative positioning
G1 H1 X-405 Y-405 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-405 Y-405 F240 ; move slowly to X and Y axis endstops once more (second pass)
G1 H2 X200 Y200 F3000
G1 H1 Z-455 F240 ; move Z down stopping at the endstop
G90 ; absolute positioning
G92 Z 1.35 ; set Z position to axis minimum (you may want to adjust this) ||||||||| tested 1.35 measured with slip gauges G1 Z0 goes down to bed with paper |||||||||
So this is where probe triggers.; homez.g
; called to home the Z axis
; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon May 10 2021 11:46:07 GMT+0200 (centraleuropeisk sommartid)
G1 H1 Z-455 F1800 ; move Z down until the endstop is triggered
G92 Z1.35 ; set Z position to axis minimum (you may want to adjust this)M122 B121
Diagnostics for board 121:
Duet TOOL1LC firmware version 3.3RC2 (2021-05-11 14:59:50)
Bootloader ID: not available
Never used RAM 4088, free system stack 0 words
Tasks: Move(notifyWait,0.0%,153) HEAT(delaying,0.2%,81) CanAsync(notifyWait,0.0%,66) CanRecv(notifyWait,0.0%,79) CanClock(notifyWait,0.0%,66) TMC(delaying,2.8%,57) MAIN(running,92.0%,339) IDLE(ready,0.0%,40) AIN(delaying,4.9%,62), total 100.0%
Last reset 00:15:19 ago, cause: power up
Last software reset time unknown, reason: AssertionFailed, available RAM 4592, slot 1
Software reset code 0x0120 ICSR 0x00000000 SP 0x20003cac Task Freestk 130 bad marker
Stack: 00000544 00023174 00019cb5 20003044 00016e33 20003044 00016505 20000ed0 00000000 00000001 0000828d 200071c8 200071c8 200071e0 00000000 20000f50 000116b3 00022530 000225e8 00021c40 00019c55 200071c8 200071c8 20000f50 00008405 200071d8 000009c6
Driver 0: position 0, 80.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 973, writes 9, timeouts 0, DMA errors 0, steps req 0 done 0
Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
Peak sync jitter 7, peak Rx sync delay 522, resyncs 2, no step interrupt scheduled
VIN: 24.6V
MCU temperature: min 18.0C, current 31.0C, max 31.1C
Ticks since heat task active 247, ADC conversions started 915818, completed 915817, timed out 0, errs 0
Last sensors broadcast 0x00000002 found 1 2 ticks ago, loop time 0
CAN messages queued 11066, send timeouts 0, received 8292, lost 0, free buffers 36, min 36, error reg 0
dup 0, oos 0, bm 0, wbm 0
Accelerometer detected: no
I2C bus errors 4619, naks 4619, other errors 4619Cheers
Bengt -
I think I´ve got it working sort of.
homeall.g
G90
G30; Z-Probe
M558 C"121.io1.in" P8 H10 F120 T6000 ;
G31 P50 X0 Y-36 Z1.35
M557 X15:400 Y15:400 S20 ; define mesh gridHope this will others having this promblem
Big thanks to the crew
