[3.3.0-rc2] M3-M5 gcode action
@jay_s_uk yes, off-course
M452 C"!duex.e2" something like that, I haven't the whole line in head but it works well to engrave and everything, just the M3 that don't work as before. -
Please share the actual config.g and results of M122 please.
@phaedrux Off-course, here it is, sorry for the delay.
Config.g :; Configuration file for Duet ; executed by the firmware on start-up ; WorkBee Firmware Version 1.0.5 ; General preferences M452 C"!duex.e2heat" R255 F1000 S0 G90 ; Set absolute coordinates M453 ; Put the machine into CNC Mode ; Network M550 P"Atelier Vosgien CNC" ; Set machine name M552 S1 ; Enable network M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S0 M569 P2 S0 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M569 P4 S0 ; physical drive 4 goes forwards M569 P5 S0 M584 X0 Z3 A1 Y2:4 C5 ; set drive mapping M92 X640 Y640 Z800 A35.8 C8.8 ; Set steps per mm M350 X16 Y16 Z16 I1 A16 C16 ; Configure microstepping with interpolation M566 X150 Y150 Z250 A500 C500 ; Set maximum instantaneous speed changes (mm/min) M203 X2700 Y2700 Z2000 A6500 C6500 ; Set maximum speeds (mm/min) M201 X25 Y25 Z70 A250 C250 ; Set accelerations (mm/s^2) M906 X2200 Y2200 Z2000 I100 A2000 C2000 ; Set motor currents (mA) ; Axis Limits M208 X25 Y0 Z0 S1 ; Set axis minima M208 X645 Y1190 Z225 S0 ; Set axis maxima M208 A-3600:3600 C-3600:3600 ; Endstops M574 X2 P"!xstop" S1 M574 Y2 P"!ystop" S1 M574 Z2 P"!zstop" S1 M574 A0 C0 ; set active low and disabled endstops M558 P5 C"!^zprobe.in" A1 H2 F600 G31 P500 Z0 ; Tools ;M950 P0 C"exp.heater3" ;M563 P1 S"XYZ-Probe" ; Define XYZ Touch Probe Tool M563 P0 S"Spindle" M563 P1 S"Laser" ; Custom settings M575 P1 B57600 S1 ; Connection paneldue G92 A0 C0 ; prehome A et C M564 H0 ; Disable jog commands when not homed M140 H-1 ; Disable heated bed M911 S21.0 R23 P"G91 G1 Z3 F1000" ; Configure power loss resume M501 ; Load Stored Parameters T0
T1pre.g (enter laser mode)
M122 result
18/05/2021, 16:36:36 M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3RC2 (2021-05-11 14:55:01) running on Duet WiFi 1.02 or later + DueX5 Board ID: 08DJM-9178L-L4MSN-6JKFL-3SJ6M-TB3QR Used output buffers: 3 of 24 (23 max) === RTOS === Static ram: 23876 Dynamic ram: 75836 of which 0 recycled Never used RAM 14704, free system stack 116 words Tasks: NETWORK(ready,14.0%,223) LASER(notifyWait,0.0%,70) HEAT(delaying,0.0%,386) Move(notifyWait,0.1%,305) DUEX(notifyWait,0.0%,24) MAIN(running,85.9%,420) IDLE(ready,0.0%,29), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:31:19 ago, cause: software Last software reset at 2021-05-18 16:05, reason: User, GCodes spinning, available RAM 11672, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Step timer max interval 0 MCU temperature: min 31.8, current 32.2, max 32.7 Supply voltage: min 23.7, current 23.8, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Driver 0: position 34398, standstill, SG min/max not available Driver 1: position 60263, standstill, SG min/max not available Driver 2: position 180000, standstill, SG min/max not available Driver 3: position 0, standstill, SG min/max not available Driver 4: position 0, standstill, SG min/max not available Driver 5: position 0, standstill, SG min/max not available Driver 6: position 0, standstill, SG min/max not available Driver 7: position 0, standstill, SG min/max not available Driver 8: position 0, standstill, SG min/max not available Driver 9: position 0, standstill, SG min/max not available Driver 10: position 0 Driver 11: position 0 Date/time: 2021-05-18 16:36:35 Cache data hit count 4294967295 Slowest loop: 5.32ms; fastest: 0.17ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 0.9ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 9215, completed moves 9215, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === DueX === Read count 0, 0.00 reads/min === Network === Slowest loop: 201.01ms; fastest: 0.10ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 1 WiFi firmware version 1.25 WiFi MAC address ec:fa:bc:2d:e6:96 WiFi Vcc 3.38, reset reason Turned on by main processor WiFi flash size 4194304, free heap 27056 WiFi IP address 192.168.137.149 WiFi signal strength -62dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
@krohm-koala this could be linked to this bug.
Maybe try the version dc42 has linked to?
https://forum.duet3d.com/topic/23191/software-package-3-3-rc2-released/12?_=1621349459218 -
@jay_s_uk we will try, i'll keep you in touch
@jay_s_uk So, now we have a message that said "M3 commande not supported in machine mode laser"
maybe it's not supported anymore but it was really usefull for focus adjustement.. -
M3 commands with S parameter to set the laser power should still work in Laser mode.
@dc42 it's what it does before, we don't know why it doesn't work anymore, i only work on the machine in remote, the most of the time my friend do everything and tells me the result ^^ since we are on the last version, it doesn't work anymore, with the message ^^
@krohm-koala I can confirm I am also experiencing a problem with this - I've enabled laser mode with:
M452 C"duex.fan7" R255 F5000 S0 ; Laser Mode
which I've connected to the input of a spare relay module and I am unable to switch the pin using M3 S255. If I enable laser mode with the pin inverted "!duex.fan7" I can hear the relay switching at the start of Laser mode but I still can't control it.
@educatingsavvas Have you tried to do a G1 Xxxx Sxxx to try if it turn on with a mouvement? it work for us, i assume it'll work for you. Even if it doesn't stay On, you can engrave
@krohm-koala Hiya - I swapped over to a spare heater terminal and generated a test code with the Opt Lasers g-code generator and I can see the red LED flickering on and off - for an image raster. Preventing the M3 command to turn on the laser is a safety feature so that makes sense now.
@educatingsavvas it make sense but, when you want to adjust your focus, it's a bit difficult during a mouvement ^^
@krohm-koala said in [3.3.0-rc2] M3-M5 gcode action:
Does your laser have a Z-axis to adjust height? I'm planning for mine too - so eventually I'll do a test g-code that fine adjusts the laser height over multiple passes, and to than workout the offset from the top of the material being engraved/cut.
