Proud to have an Duet3 6HC ! But is not working
@uneumann36 said in Proud to have an Duet3 6HC ! But is not working:
There is only one thing what i Wang to asked you,
Can i post my config datas, that someone of you have a look on it if i can use my Printer with this settings?Yes you can share your files and we can take a look.
Thank you , here is my config. :
; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu May 20 2021 07:20:18 GMT+0200 (Mitteleuropäische Sommerzeit); General preferences
G21 ; Units in mm (mm)
M550 P"Ender 5 Duet 3" ; set printer name; Network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0.1 S0 ; physical drive 0.1 goes backwards
M569 P0.3 S0 ; physical drive 0.3 goes backwards
M569 P0.4 S0 ; physical drive 0.4 goes backwards
M569 P0.5 S0 ; physical drive 0.4 goes backwards
M584 X0.0 Y0.1 Z0.2 E0.3:0.4:0.5 ; set drive mapping
M350 X16 Y16 Z16 E16:16:16 I1 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z400.00 E422.76:422.76:422.76 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X5000.00 Y5000.00 Z250.00 E4000.00:4000.00:4000.00 ; set maximum speeds (mm/min)
M201 X1500.00 Y1500.00 Z250.00 E3000.00:3000.00:3000.00 ; set accelerations (mm/s^2)
M906 X1200 Y1200 Z1200 E1000:1000:1000 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X220 Y220 Z300 S0 ; set axis maxima; Endstops
M574 X1 S1 P"io3.in" ; configure active-low endstop for low end on X via pin io0.in
M574 Y1 S1 P"io1.in" ; configure active-low endstop for low end on Y via pin io2.in; Z-Probe
M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
M558 P9 C"^io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M307 H1 ; enable bang-bang mode for the bed heater and set PWM limit
M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
M307 H1 R3.650 C118.5 D4.66 S1.00 V23.8 ; disable bang-bang mode for heater and set PWM limit
M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
M308 S2 Y"drivers" A"DRIVERS" ; configure sensor 2 as temperature warning and overheat flags on the TMC2660 on Duet
M308 S3 Y"mcu-temp" A"MCU" ; configure sensor 3 as thermistor on pin e1temp for left stepper
M950 F2 C"out6" Q500 ; create fan 2 on pin fan2 and set its frequency
M106 P2 H2:3 L0.15 X1 B0.3 T35:45 ; set fan 2 value; Tools
M563 P1 D1 H1 F0 ; define tool 1
M563 P2 D2 H1 F0 ; define tool 1
G10 P2 X0 Y0 Z0 ; set tool 1 axis offsets
G10 P2 R0 S0 ; set initial tool 1 active and standby temperatures to 0C; Custom settings are not defined
M575 P1 S1 B57600 ; enable support for PanelDue -
And here my tfree , tpost and tpre datas :
; tfree0.g
; called when tool 0 is freed
; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu May 20 2021 07:20:18 GMT+0200 (Mitteleuropäische Sommerzeit)M83 ; relative extruder mode
G1 E-40 F8000 ; retract 40mm; tpost0.g
; called after tool 0 has been selected
; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu May 20 2021 07:20:18 GMT+0200 (Mitteleuropäische Sommerzeit)M116 P0 ; wait for tool 0 only to reach operating temperature
G1 E40 F8000 ; undo retraction; tpre0.g
; called before tool 0 is selected
; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu May 20 2021 07:20:18 GMT+0200 (Mitteleuropäische Sommerzeit) -
I hope my self adjusted settings are ok.
@uneumann36 A couple of comments:
You don't need to enable the pullup resistor on the Duet 3. Remove ^ from the above line.
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 ... M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
You are using the default thermistor settings. What hotend are you using for the 3-into-1? Check what thermistor it comes with, and change the M308 line accordingly for better temperature accuracy.
For the bed thermistor, I think the Ender 5 uses the Marlin default thermistor 1 setting (100k Epcos). Change the B value in the M308 line for the heated bed to B4092.
I can't comment on your tool change macros; 3-into-1 hot ends often require a lot of tuning to get the filament change smooth.
@droftarts
Thank you very much for your advise.What do you mean with :
You are using the default thermistor settings. What hotend are you using for the 3-into-1? Check what thermistor it comes with, and change the M308 line accordingly for better temperature accuracy. ?
It is the same like origin in Ender5
Or do i understand something wrong? -
@uneumann36 The default setting for thermistors in the RepRapFirmware configuration tool is B4138. I don't think anyone uses this thermistor any more.
I think some Ender 5 come with E3D hot end. If yours is standard, then like the bed, change the B value in the M308 line for the hot end to B4092.
Perfect, i will try this in the evening.
Thank you -
@droftarts
HiSo i try your advise.
About the thermistors , all settings are good.But when i delete the Line :
M558 P9 C"^io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speedsThen the BLT is not working and DWC show the failure :
G28 Z
Error: in file macro line 8: G30: Z probe 0 not found
Error: Homing failed -
@uneumann36 I didn’t say to delete the line, just delete the ^ character! So line should be:
M558 P9 C"io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
@droftarts
Oh sorry,
Then I got it wrongThank you
Works well
