Duet2 WiFI, does not use static IP
And how do I get it to use Static IP
google search !
Duet 2 WiFi
To set a static IP address, use the 'I' parameter in your M587 command. ...
Use M552 S1 to turn on networking, and connect. -
In runonce.g
; runonce.g ; called after config.g. When it has been executed, it is automatically deleted! ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Apr 03 2021 11:58:00 GMT+0200 (centraleuropeisk sommartid) M552 S0 ; disable network G4 P500 ; wait half a second M552 S1 ; enable network G4 P1000 ; wait a second M587 S"MY_SSID" P"MY_WIFI_PASSW" I192.168.0.10 J192.168.0.1 K255.255.255.0 ; configure WiFi M552 S1
It does not seem to work
@tomasl send M587 without parameters to list the known SSIDs and static IP addresses.
@tomasl I got it to use a static ip in my routers setup. You can assign the duets Mac address to any ip you want. I have tp link and it's under dhcp address reservation.
@ross
Well, it is till DHCP, hence still dynamic IP. With the difference that the router sets the lease-period to "forever".
And I still want to use a proper static IP. -
@tomasl just out of curiosity what difference would there be? If you assign let's say 192.168.1.101 the way I did or a "proper static ip" assigned to the same local address.
@ross
Ultimately I dont want to use DHCP, only static assigned IP's. -
There should be nothing stopping you from using a static IP.
DC42 asked to check M587 on the 17th, were you able to do that yet?
Post your full config.g and the results of M122 please.
@phaedrux
No I havent been at my workshop yet, will do that this weekend. -
I had issues trying to set a static IP as well. I finally got it to work with some suggestions. The steps seems to be very picky. See this thread,
https://forum.duet3d.com/topic/22703/duet-3d-wifi-set-ip-address/7?_=1621469740585
