Predator Project - The Mjolnir -
Smart effector is also an elegant solution, but with the dual extruder you pretty much have to eliminate effector tilt and in that case bltouch should also work reasonably well?
@bearer said in Predator Project - The Mjolnir -:
My experience with dual nozzles is that it's very difficult to prevent one from interfering with the printing by the other.
I wonder if the 'tiltability' of delta printers can be used to address it. E.g. on tool change, tilting the non active nozzle up such that it is not interfering with piezo measurement or printing by the other nozzle.
Hi Everybody, thank you for the suggestions and sharing your experiences.
what I learned is to say bye bye to my BLtouch (i will recycle it on my ender 3 )
I designed new bed support to place piezo (Precision piezo kit Ø20mm):
...and problably i will move to a new print head solution to prevent tilt issues:
i will design a special cooler to proceed with my liquid cooling idea and create a compact effector...
hope you like it and i'm on the right way now.. thanks guys!
I am waiting for the day when our 3D printers will be as pretty as their CAD renderings.
here we go....!
instead of what drawed before, I made (due to supplier wrong shipment) the Ø27 piezo support, probably more sensitive
here a short preview,
https://youtu.be/zSb38aC-XgElooks good:
But unfortunatelly I don't understand this mesh... really don't...
I will check again geometry and road lenght with a caliber...
wait for your comments
@thor3k, that height map with ridges at one end of the X direction turning into valleys at the other end is a beautiful example of the effects of backlash in the joints of a delta printer.
Try lubricating the joints.
Thank you dc42, I thought it depend of bad geometries.. is something I saw on first tests, I remember (se my first post) it goes better when I goes back from magnetic joints to the original ball eye rod joints..
I will check the lubrification on my mag balls...
Btw sticktion in the carriage or belts too loose would also cause that pattern in the height map.
Hi, how's this project going? I'm interested in the piezo mounts. Does the heated bed float on them or is it screwed down? Do you have a place you are putting the files as I would really like something similar for mine.
Thanks
@thor3k hi , I would make this mod too on my predator , can you share the stl file for mount the piezo Undermath ?
@thor3k I'd be interested in the mounts - would you mind sharing them?
